Old 08-14-2009, 08:02 PM   #1
Default Ufer Ground to Electrical Service
I would like to heard from follow Electricians, there best method of install-
ing a Ufer Ground system. Here not all electrician install it the same way.
Please note I am talking about single family home here.
Thanks for any and all comments.
partimer31 is offline   Reply With Quote
Old 08-14-2009, 08:09 PM   #2
I like to have a piece of the rebar turned up in a convenient spot so I can run my ground to it. Keeps me from having to mes around in the slab.
Old 08-14-2009, 09:07 PM   #3
Excellent way to do it.
I'd love to invent some method of drilling a slab and making a connection..
I void warranty's
Old 08-14-2009, 09:09 PM   #4
I like to do the same thing, except I substitute the rebar with a ground rod. I worry about the rebar corroding over time.
Old 08-14-2009, 09:18 PM   #5
Licensed Journeyman
nolabama's Avatar
i would want it ramset style- instead of drilling
Old 08-15-2009, 01:50 PM   #6
brain John. "I void warranty's" love it, made me laugh, you must be a comic at heart.
Old 08-15-2009, 02:37 PM   #7
I think there is an AMPact die to put a tap on a rebar with the shot shell.
Old 08-17-2009, 01:11 PM   #8
out here in beautiful california in a new or remodel situation where we have concrete work going in we have the rebar guys put a 20 foot minimum #4 rebar turned up in a good place near out panel or sub panel for attachement of an apporopriate ground wire tap/acorn
phillip in sd
San Diego Electrician
Electrician In San Diego
San Diego Electrical Contractor
619-417-7183
www.thesandiegoelectrician.com
rackman is offline   Reply With Quote
Old 08-17-2009, 02:49 PM   #9
Default concret encased electrode
Follow electrician, here something you might want to read if you do work
in the State of New Hampshire.
They have put out a Technical Bulletin on Concrete-Encased Electrode,
it dated; Septemer 9, 2005.
I Google onto by typing in: STATE OF NEW HAMSHIRE DEPARTMENT OF
SAFETY, Application of 250.50, Grounding, Electrode System..
I don't work in New Hamshipre so I am wonder if this Tech. Bulletin
still is applicable.
Old 08-17-2009, 03:31 PM   #10
A ground rod is not nearly adequate to serve as a CCE.
(3) Concrete-Encased Electrode.
An electrode encased by at least 50 mm (2 in.) of concrete, located horizontally near the bottom or vertically, and within that portion of a concrete foundation or footing that is in direct contact with the earth, consisting of at least 6.0 m (20 ft) of one or more bare or zinc galvanized or other electrically conductive coated steel reinforcing bars or rods of not less than 13 mm (1/2 in.) in diameter, or consisting of at least 6.0 m (20 ft) of bare copper conductor not smaller than 4 AWG. Reinforcing bars shall be permitted to be bonded together by the usual steel tie wires or other effective means. Where multiple concrete-encased electrodes are present at a building or structure, it shall be permissible to bond only one into the grounding electrode system.
Old 08-17-2009, 03:51 PM   #11
Seen your member
Originally Posted by Speedy Petey View Post
A ground rod is not nearly adequate to serve as a CCE. ...........
CEE.
This message is hidden because Forgery, JackBoot, LawnGuyLandSparky, milehiwire and user 5941 are on your ignore list.
Old 08-17-2009, 03:58 PM   #12
Toronto Sparky's Avatar
Cadweld rarely corrodes
Don't fight .. Play nice!
Old 10-08-2009, 04:31 PM   #13
Installing ground rods is not difficult but proper procedures must be followed and the resulting rod(s) should be checked for performance. Testing for resistance by the fall of potential method is the only way to be sure what looks good is good, a low resistance ground.
________________________
electrical services california
greenthumb25 is offline   Reply With Quote
Old 10-08-2009, 09:08 PM   #14
Default Ufer
I have been around a long time. I have never seen the acronym "UFER". What is that? It might be legit, bit I"ve been out of construction a long time.
RIVETER
Old 10-08-2009, 09:15 PM   #15
That Guy
Mr. Sparkle's Avatar
Click HERE.
Yeeesssssss, finally got to use it! Hooray!
"Whenever you find yourself on the side of the majority, it is time to pause and reflect."
Mark Twain
Old 10-08-2009, 09:24 PM   #16
[quote=Speedy Petey;110175]A ground rod is not nearly adequate to serve as a CCE.
Sure it is. Sorry so late in responding, but I just saw this. Your definition tells why it's o.k.
Old 10-08-2009, 09:32 PM   #17
Default Bonding
Where does the code say that only one electrode system must be bonded to the electrical system?
RIVETER
Old 10-08-2009, 09:57 PM   #18
Well sure, if the ground rod is 20' long then yes, it can serve as a CEE.
What I meant was one ground rod would NOT qualify as a CEE.
Old 10-08-2009, 09:58 PM   #19
I personally don't understand the question.
Old 10-08-2009, 09:59 PM   #20
Or you can just sink a second rod and not worry about testing.
Ufer ground James Con General Electrical Discussion 14 12-04-2009 08:45 PM
Ufer Ground? normel NEC Code Forum 76 08-02-2009 08:51 PM
50 Volts Neutral to Ground and 50 Volt Hot to Ground... DarkDune Residential Electrical Forum 6 06-25-2009 09:56 PM
Electrical connection question --Over-head electrical works SarahJennifer UK Electrical Forum 6 03-02-2009 10:32 AM
Ufer ground in detached garage. Bkessler General Electrical Discussion 4 09-18-2007 05:46 AM
