Use of stranded wire. - Electrician Talk - Professional Electrical Contractors Forum
Old 02-15-2011, 11:55 AM   #1
Default Use of stranded wire.
310-3 states #8 or larger shall be standed. But it does'nt say # 8 or smaller can't be stranded. Is there a clear code reference thats denies the use of stranded wire in the smaller sizes ? I have recently been called on using stranded wire, even though i make pigtails for devices using fork terminals and a greenlee crimper. Small shop so pre-fab is a way of life for me. And out here the supplier i do business with has a back stock of stranded wire i'm getting it at killer price. In retrospect job specs always refer to 310-3 in the general notes. Seems black and white to me but could this reference be subject to interpretation? Any input would be greatly appreciated. Doug Larsen (Larsen Electric) Guam, USA
zinsco1 is offline   Reply With Quote
Old 02-15-2011, 12:25 PM   #2
Rewards Points: 3,855
There is no code prohibition against it. Matter of fact, on commercial work, it would be difficult to find solid wire unless it was a small quantity purchased specially for receptacle circuits. There are some screw terminals that have a particular prohibition against stranded, but barring that, there's nothing anywhere against stranded in smaller gauges. Maybe a job spec.
zinsco1 (02-15-2011)
Old 02-15-2011, 12:54 PM   #3
Rewards Points: 502
Can't imagine NOT using stranded wire. It's capable of carrying more amps (more surface area), less likely to get damaged in a pull, easier to handle, and weighs less than solid wire.
Ask where in the NEC that it says solid is better than stranded, not going to happen. Where in the spec's does it have a call out for solid?
The only place I actually like solid is on a device, then, even there, I think electrically, it's inferior to stranded.
Don't let fear be your guide!
Rockyd is offline   Reply With Quote
The Following User Says Thank You to Rockyd For This Useful Post:
Old 02-15-2011, 01:38 PM   #4
Ax grinder
raider1's Avatar
Rewards Points: 1,080
I know what you are trying to say, but would like to point out that small conductors like 10 and 12 AWG have the same ampacity, according to the NEC, whether or not they are stranded or solid.
Chris
Old 02-15-2011, 05:08 PM   #5
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,876
Solid wire is a bit cheaper by the roll than stranded wire. I was brought up in the trade using pipe and wire which was always 100% stranded.
I only encountered solid wire during residential service work.
I still consider solid wire inferior for some reason.
The Following User Says Thank You to Suncoast Power For This Useful Post:
zinsco1 (02-16-2011)
Old 02-15-2011, 05:18 PM   #6
As solid is spec'd on every school I have worked on, I finally got a chance to ask an engineer why he kept speccing it.
His answer was that it was the only splice that ever held up on the 25 year test for tight splices without loosening or loosing integrity.
Told him after that, that if he hadn't had a good answer, I was going to smack him for spec-cing in for no good reason.
The Following User Says Thank You to JohnR For This Useful Post:
Old 02-15-2011, 05:29 PM   #7
Jlarson's Avatar
Rewards Points: 3,048
Stranded is defiantly better. I've probably pulled miles of solid 14, 12, and 10 into conduit and that is no picnic.
And you should have no problems landing stranded onto devices, most are UL listed for solid or stranded.
The Following User Says Thank You to Jlarson For This Useful Post:
Old 02-15-2011, 05:29 PM   #8
BBQ
Salty Member
BBQ's Avatar
A couple of points
There are air spaces in stranded meaning if the outside diameter remanded the same the ampacity would drop due to less copper.
Stranded conductors of the same AWG are larger than solid.
From table 8
12 AWG stranded 0.092" diameter
12 AWG solid 0.081" diameter
walkerj (02-15-2011)
Old 02-15-2011, 05:36 PM   #9
drsparky's Avatar
Rewards Points: 484
The only solid I ever use is Cat 3 and 5. I don't do residential.
Old 02-18-2011, 07:33 PM   #10
Professional Nit Picker
manchestersparky's Avatar
Rewards Points: 1,640
When I was in the field I used solid on every project unless spe'd otherwise. In my area you'll see more solid then stranded.
I hated using stranded myself
Anything Worth Doing ....
Is Worth Doing Right
Old 02-18-2011, 10:17 PM   #11
zap
tates1882's Avatar
Rewards Points: 822
Did they provide a code ref?
#12 solid is the only way to go. #10 or larger stranded is easier to deal with.
Old 02-18-2011, 11:32 PM   #12
Rewards Points: 4,420
I like pulling tw from the square cardboard boxes..........
It would have been impossible for us to develop our plan for the world if we had been subject to the bright lights of publicity during those years. David Rockefeller
Shockdoc (06-09-2012)
Old 02-18-2011, 11:50 PM   #13
Just Dealing With it....
Shado's Avatar
Rewards Points: 502
Now you are bringing back some painful memories......especiallly when the box got wet and fell apart.
- Dave ........
Shado is offline   Reply With Quote
Old 02-19-2011, 12:22 AM   #14
sparks134's Avatar
Don't tell me they still make those somewhere.
Dislike!
sparks134 is offline   Reply With Quote
Old 02-19-2011, 12:24 AM   #15
Les Voltage
Odd reading all the different views about this subject. We do lots of Govt work and it seems stranded is a major no no here. It also seems that most all other work in the area is the same now too. I think lots of the non govt work are using the same spec book more or less for every job, or generic version. I doubt I could go Monday morning and find more than a few rolls of stranded #12 from out top 3 SH...
Old 02-19-2011, 12:43 AM   #16
Semper Fidelis
Originally Posted by BBQ View Post
A couple of points
From table 8
Bob, We were taught that electrons flow along the surface for some reason. I would expect stranded conductors to have more surface area than solid.
The Following 2 Users Say Thank You to Suncoast Power For This Useful Post:
jmsmith (05-29-2012), stump1000 (05-30-2012)
Old 02-19-2011, 04:15 AM   #17
Rewards Points: 2,202
He is full of crap IMO, this spec is included because it was always there and the engineer is too lazy to remove it when he cuts and paste the spec into a new school.
The Following 2 Users Say Thank You to brian john For This Useful Post:
Rockyd (02-20-2011)
Old 02-19-2011, 09:58 AM   #18
Rewards Points: 262
Only at high frequency compared to the diameter of the wire.
For a 12AWG it starts above 20 kHz.
For a 2 inch diameter cable it's at 60 Hz.
As the frequency increases more and more current moves towards the surface.
Although it's caused by the wires self-inductance, the change is resistive.
Speedskater is offline   Reply With Quote
The Following User Says Thank You to Speedskater For This Useful Post:
duckhunter29 (06-07-2012)
Old 02-19-2011, 10:09 AM   #19
mattsilkwood's Avatar
Rewards Points: 2,006
I love solid wire. It works great for tying ladder and stuff down.
A man that will not read has no advantage over a man that can not read.-Mark Twain
Old 02-19-2011, 06:12 PM   #20
stranded vs. solid If you looK in chapter 9 table 8 you'll see that their is a different resistance value for solid and stranded. Stranded wire when calculating voltage drop has a slightly higher resistance per 1000'.I know that voltage drop is not a code requirement and only a informational note, but if you have a specific peice of electronic equipment voltage drop could be important. The skin effect on these smaller wires is usually not a factor.
desar is offline   Reply With Quote
Stranded or solid 12 awg wire? calimurray General Electrical Discussion 99 06-16-2014 12:23 AM
Terminating stranded wire on breaker Conduit Phil General Electrical Discussion 11 04-15-2010 06:21 PM
Ideal wirenuts on stranded wire. 220/221 General Electrical Discussion 43 04-04-2010 05:46 PM
Stranded wire on receptacles bobelectric General Electrical Discussion 37 02-20-2010 03:36 PM
stranded wire Ejw NEC Code Forum 6 03-16-2009 12:15 AM
