11-13-2009, 06:31 PM
west virginia jourymans test?
I am taking the test next month codes are no prob for me the only thing I am worried about is the calculations can any one help me and tell me what type of questions they are to help me study better
11-13-2009, 07:16 PM
Look into Tom Henry calculation book, Ohm Law book and transformer book.
Good Luck !!!!!!! ( really ) let us know how it goes
11-13-2009, 08:59 PM
There is a whole book on Ohms Law? Geez, just write it on the bottom of your shoe.
11-13-2009, 09:03 PM
haha E=I/R everything else can come off that. Never can memorize all the power ones though
11-13-2009, 09:27 PM
lol, however it also has voltage drop calc
11-14-2009, 11:04 AM
Licensed Pro
Calculations = box fill, conduit fill, dwelling/non-dwelling load calculations, derating conductors, motors, ampacity, parallel conductors, and electric oven cooking equipment.
Just a small portion of the journeymen's examination.
Vince Lombardi
11-14-2009, 11:12 AM
junior member
Annex D is a good place to start.
11-14-2009, 12:23 PM
Licensed Journeyman
I just took the ICC journeyman test, admind my parsons view. It had very few true calculations on it. It did however have the box fill and the ohms law calcs. It did also have a noodle feeder size calc.
11-20-2009, 03:07 PM
It's been a long time since I took it ('95), but there were only 5 calculations. Resi loads, and wire sizing were the ones I remember.
You may want to call American Contractors Exam Services.
Where did we go back to before the drawing board was invented?
12-07-2009, 07:01 AM
well I test in a hour or so.
12-07-2009, 08:55 AM
Good Luck, were are you testing at?
I void warranty's
12-07-2009, 02:10 PM
I tested in Martinsburg
12-07-2009, 03:46 PM
That's were I took my test at a VOTECH school. Was a long hard test.
I void warranty's
12-07-2009, 03:51 PM
west virginia has a test ? when did they start doing inspections ?
Chuck Norris sleeps with a night light. Not because Chuck Norris is afraid of the dark, but the dark is afraid of Chuck Norris.
12-07-2009, 06:10 PM
I took the second round of testing in West VA, I want to say late 80's early 90's.
I void warranty's
12-07-2009, 07:10 PM
it was a fairly easy test the virginia test is harder. from what I have been told
12-07-2009, 08:35 PM
#18
We must have taken different test I thought the VA test was a cake walk, nothing to it. The West VA test I took was 75% fire alarm questions. Something I NEVER work on.
I void warranty's
12-08-2009, 09:40 AM
#19
not a single fire n the whole alarm ? o the test
12-08-2009, 12:40 PM
#20
A Member
I recently took the Oklahoma jman test. If its psi it might be the same format... if its not a masters there was hardly any true calculations in it, even tho it says calculations, it was nothing that required me to do alot of math. With that said, the most important thing was speed. Using the glossary is KEY, but use the page numbers and flick through the bottom. Itll help your speed. Try not to go by the code references like 340.17, they're a little slower to find. And the glossary gets pretty detailed on the sections, be ready to use it to target the area the question is asking.
And also check out mike holts website. He has videos over commercial calcs, motor calcs, fill calcs, etc. almost everykind dealing with electricians. I watched a good part of relevent videos from his site and knew how to do about every calculation in the code book by the time I was ready to take the test. I maybe used the knowledge I gained from it 2 or 3 times.
Reason: Wasn't finished.
