Wiring a residential pole barn, can you use NM? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-20-2011, 10:59 AM   #1
Rewards Points: 2,000
Default Wiring a residential pole barn, can you use NM?
I did one of these a while back and surface mounted EMT. Going to bid one today and was thinking if there was any way to use NM.
The construction on these seems to be 6x6 poles, 2x6 horizontal stringers, couple inches of insulation with the metal sandwiched on to it.
Was wondering if anyone has every used NM on one of these? Would be getting a finished surface. I'm more than inclined to bid this one for surface mount EMT.
Any thoughts?
Old 02-20-2011, 11:47 AM   #2
Rewards Points: 502
Horses chew! Anywhere a horse can chew on your work, it needs to be protected by a METAL pipe.
Don't try to fix the horse, just make it so that he can't hurt himself.
EDIT - Metal pipe anywhere the horse can get at the conductors...like down to the water tank, and own pulls that have receptacles, or switches. Make sure whatever you use, is also chicken$hit proof. I'm serious about the crap, chickens roosting where it's warm are going to take a dump on your cable/ raceway, plan accordingly.
Don't let fear be your guide!
Rockyd is offline   Reply With Quote
Old 02-20-2011, 11:56 AM   #3
Rewards Points: 416
You need to look at art.547
547.5 Wiring Methods.
(A) Wiring Systems. Types UF, NMC, copper SE cables, jacketed Type MC cable, rigid nonmetallic conduit, liquidtight flexible nonmetallic conduit, or other cables or raceways suitable for the location, with approved termination fittings, shall be the wiring methods employed. The wiring methods of Article 502, Part II, shall be permitted for areas described in 547.1(A).
FPN: See 300.7, 352.44, and 355.44 for installation of raceway systems exposed to widely different temperatures.
Old 02-20-2011, 02:24 PM   #4
There's no horses.. Just a pole "shop". Barn wasn't quite the correct term. I'm more curious about if NM could be fished behind the beams and be "legal". Not going to use it. More theoretical at this time.
Old 02-20-2011, 02:52 PM   #5
zap
tates1882's Avatar
Rewards Points: 758
Around here its allowed but is has to be cover up to 8'. Then it can be exposed. a lot of times the gc will use osb sheeting up to eight' then we use a flash ring at each box the make it legal with a combustible surface.
Old 02-20-2011, 02:56 PM   #6
How do you get around the 1 1/4" stapling from the face of the 2x6? And is there any issue with the NM being right up against the siding?
Old 02-20-2011, 03:13 PM   #7
NRA Member
backstay's Avatar
Rewards Points: 810
Pole barn not horse barn
Rockyd (02-20-2011)
Old 02-20-2011, 03:29 PM   #8
zap
tates1882's Avatar
Rewards Points: 758
I didn't but I have never been called on it either. I not sure if the inspector lets go because the metal is already in place by the time its rough in or what. I have had four different inspectors OK NM in a pole barn though.
On a side note, if you keep all the horizontal runs above the 8' level it won't matter about the 1 1/4" rule because its exposed.
Old 02-20-2011, 03:31 PM   #9
Do you cut holes in the insulation for your bracket boxes then mount them to the 2x6 then mud ring?
Old 02-20-2011, 03:48 PM   #10
zap
tates1882's Avatar
Rewards Points: 758
Originally Posted by nitrous View Post
Do you cut holes in the insulation for your bracket boxes then mount them to the 2X6 then mud ring?
I have done it that way, also I have had the CG drill holes in the osb and pull out the NM loops. So I can put a 4sq box with raised cover for the device on the surface of the obs. I prefer the latter way because you don't effect the R value of the insulation. Alot of times they will fur out the wall so I use plastic nail ons.
Old 02-20-2011, 03:49 PM   #11
Just wondering if there is enough depth for nailers?
Old 02-20-2011, 03:59 PM   #12
zap
tates1882's Avatar
Rewards Points: 758
Whats a nailer? nail plate?
Old 02-20-2011, 04:01 PM   #13
Plastic nail on box, slang term.
Old 02-20-2011, 04:30 PM   #14
zap
tates1882's Avatar
Rewards Points: 758
Depending on what size osb and how picky the owners are about looks than yes a nail on would work. Also if the box is beyond flush than it would eliminate the need for a flash ring/box extension/goof ring for the osb. A shallow handy with bracket might be the best choice if you want to be behind the osb.
Old 02-20-2011, 04:33 PM   #15
I'm just hunting for ideas.. I really am not keen on NM and boxes in that style of construction. Not much room when you have a 2x6 on it's side for your wall space.
Old 02-20-2011, 04:44 PM   #16
zap
tates1882's Avatar
Rewards Points: 758
MC or ENT both would be cheaper eaiser then pipe.
Old 02-20-2011, 04:49 PM   #17
Once the walls are up you're into surface mount at that point. Thing is that running in the wall going vertical you have to run your wire in the sheetmetal channel. Isn't that a code issue? Anyways.. thanks for the insight.
Old 02-20-2011, 05:14 PM   #18
zap
tates1882's Avatar
Rewards Points: 758
Shave a channel 1/4" to 3/8" in the 2x6 and nailplate.
Old 02-20-2011, 11:45 PM   #19
I've pretty much decided it's hack to use NM unless the walls get firred out. I was just trying to kick around different ideas. Then you have to try and fish it around your corner posts. Seems like a real PIA.
MC Cable use in residential house wiring hayan453 General Electrical Discussion 104 03-08-2013 06:46 PM
Residential wiring class AWKrueger General Electrical Discussion 7 12-13-2009 10:40 AM
gfi in a barn roach1521 General Electrical Discussion 15 09-03-2009 09:43 PM
Seeing two sides of the residential wiring coin. jrhelectrical General Electrical Discussion 52 05-19-2009 11:15 PM
Residential Wiring Samar General Electrical Discussion 9 07-10-2007 06:27 PM
