Old 09-25-2009, 12:03 PM   #1
Default Do i need a dedicated conduit?
Hi,
We are building a canopy with the solar on top. Canopy has two sides and there is a cavity between them. This cavity to be used for gutter. The combiner box where we combine all our wires is on one side only. It means that we need to run our PV wires across this cavity under the gutter. See drawing part 1.
My question is: Can i run those wires exposed or i need to install the conduit? See drawing part 3. Drawing part 2 showing canopy view.
Thank you for your help.
Lithium is offline   Reply With Quote
Old 09-25-2009, 02:23 PM   #2
rexowner's Avatar
Well, 690.32(E) says, "When direct current photovoltaic
... circuits...are run inside a building or structure,
they shall be contained in metallic raceways or enclosures...
from the point of penetration of the surface of the building
or structure..."
(2005 NEC)
You could make a tortured argument about the meaning
of "inside", but IMO, it should be in conduit.
rexowner is offline   Reply With Quote
Old 09-30-2009, 02:20 PM   #3
or structure..."
(2005 NEC)
Thank you.
Old 09-30-2009, 04:27 PM   #4
rexowner's Avatar
You're welcome, and thank you for helping me get close
to 100 posts.
Re-useing old conduit. JTMEYER Code Violation Discussion 25 11-09-2009 04:38 PM
Conduit for UPS bman4523 Code Violation Discussion 7 02-05-2009 12:08 PM
ice in conduit te12co2w General Electrical Discussion 34 01-23-2009 09:47 PM
Dedicated to your employer? threewire General Electrical Discussion 14 02-20-2008 10:54 PM
conduit in wet location JohnJ0906 NEC Code Forum 4 05-15-2007 09:43 PM
