Old 03-04-2008, 04:32 PM   #1
sparkysteve's Avatar
Default "Flame Spread Rating" of NM Cable???
Anyone know where I can find this? The mech. inspector wants to see it because we have a 14-2 running horiz. through an apartment bedroom wall with an air transfer it it. The forced air HVAC system has a main return in the living room. And in the bedroom/hallway wall they have transter grilles for relief air. One is on the bedroom side close to the floor, and the other is in the hall near the ceiling. They just use the stud space LIKE a return. Usually they just put them straight through the wall down low, but the owner is worried about noise transfer, thus the different heights. If it has a flame spread rating of 5 or less it can stay according the the Mech. inspector. I argued that it wasn't an actual return just an air transfer. The romex is Southwire brand, and I've been all over their website and can't find anything. Any help would be great.
sparkysteve is offline   Reply With Quote
Old 03-04-2008, 06:14 PM   #2
you probably need to download the cut sheet from the manufacturer of the wire that you bought. It should have the flame spread rating and smoke rating for the jacket insulation.
oops, maybe not. try your salesman and see if he can get you something. I just looked up on southwire and there's nothing on the data sheet. (I don't do resi - is romex allowed to be run in environmental air areas ?)
nakulak is offline   Reply With Quote
Old 03-04-2008, 08:17 PM   #3
Originally Posted by sparkysteve View Post
Anyone know where I can find this? The mech. inspector wants to see it .......
Seriously?
Seems a bit anal if you ask me.
Yes, perpendicularly. 300.22(C) Exc.
Old 03-04-2008, 09:22 PM   #4
Seriously?
That's what I thought. I called our office and they were putting a call in to our supplier. I was just curious and wanted to find it.
Old 03-06-2008, 02:58 PM   #5
Bkessler's Avatar
It's not the inspector in troy is it? Because I've had issues with that guy in the past.
When ls lunch
Old 03-06-2008, 08:07 PM   #6
Nope, Allendale Twp. MI
Old 03-09-2008, 12:14 AM   #7
rbj
Anyone know where I can find this? If it has a flame spread rating of 5 or less it can stay according the the Mech. inspector. I argued that it wasn't an actual return just an air transfer. The romex is Southwire brand, and I've been all over their website and can't find anything. Any help would be great.
Hi Sparkysteve,
I have Southwires wire and cable handbook. The only tests listed are for verticle flame spread and references to Limited Smoke (LS) ratings that you would see in plenum Cat.5 cables. You would need to contact the Southwire technical rep for a distinct read on this.
I believe the inspector is worried about vertical smoke spread occurring in the particular wall bay the Mechanical sub is using for ventilation. That is the AHJ's call unfortunately. If the wall is closed, I would put a cut-in in the adjoining bay and fish a vertical run looped over and by-passing the ducted bay to the next outlet in that BC. rbj
spelling
rbj is offline   Reply With Quote
Old 03-11-2008, 09:19 PM   #8
Can you sleve it in emt and firestop or duxseal it
cmec is offline   Reply With Quote
Old 03-12-2008, 06:33 AM   #9
rbj
That would be the AHJ's call. Re-routing is easier if the wall is open, then there is no question of compliance. rbj
CEC question -- running conductors "square" with building lines Animal Other Codes and Standards 7 12-23-2008 03:53 PM
What does a union "transportation systems electrician" do here in California? sickytwisted Union Topics 4 11-30-2008 07:11 PM
Dont miss "Worlds toughest fixes" tonight! JRent General Electrical Discussion 3 10-02-2008 10:41 AM
New Square D Homeline "old work" load center wirenut1110 Tools, Equipment and New Products 5 07-14-2008 08:09 PM
Replace "Potentiometric Null Tester" with Fluke 87 or later model? Joe O'Brien General Electrical Discussion 2 06-28-2007 10:56 AM
Electrician Talk © 2006 - 2010 The Building Network LLC
