Old 10-09-2009, 04:46 PM   #1
Question Hardwiring DC power supplies
Hi There
First post. I run a company called Photoglow and we make illuminated panels for image and direct lighting. I want to introduce a product that has LEDs to illuminate 2 x 2 ceiling tiles. One model takes 12V less than 1amp. Other model takes about 12V 5 A.
I usually use small plug in switching power supplies for power. I know this wont work to code in a ceiling. Anybody out there know a way to get this DC to my units in a commercial ceiling code.
Thanks!
ed sinofsky
glowmaster.
glowmaster is offline   Reply With Quote
Old 10-09-2009, 06:00 PM   #2
DC? Hmmm... surely there are some commercially available hardwired DC power supplies, that come in a NEMA type enclosure with a UL listing. I'm just drawing a blank at the moment. Maybe one of the emergency lighting manufacturers.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 10-09-2009, 06:10 PM   #3
I am probably wrong, but I thought that the prohibition against cords in suspended ceilings, 400.8(2), was for line voltage, low voltage or class 2 and 3 cables are in Article 725 and I do not recall any prohibition in that section for this install.
2005 NEC
wingz is offline   Reply With Quote
Old 10-09-2009, 06:57 PM   #4
Exhibit 725.2 show how to do this correctly. This is a class 1 power limited circuit.
Old 10-09-2009, 07:06 PM   #5
steelersman's Avatar
We used something similar to this in the Pentagon and mounted it on din rail inside of an enclosure above the ceiling and supplied it with 120 volts.
http://www.powersupplydirect.com/Pro...FeRL5QodfT1TiA
steelersman is online now   Reply With Quote
Old 10-24-2009, 10:42 PM   #6
Default Hardwireing DC power supplies
Glowmaster, I have not seen these. Are you powering a remote DC power supply and then running branch circuits
of DC voltage to the lighting?
Old 10-25-2009, 12:30 AM   #7
DC distribution panel with OCP and branch circuit wiring to meet NEC to each panel.
Or design a system with a Junction box that can hold the power supply and hard wire to the LED system with NEC approved wiring methods.
I void warranty's
Old 10-27-2009, 10:55 PM   #8
I would just do like Steelerman said put a DIN mount power supply in a NEMA 1 pull box. You could throw a mini breaker and some DIN terminal blocks in there too make it a clean and easy install. Also check out Hoffman Engineering, they make a NEMA 1 box with perfpanel (back panel with holes) so there are no screws sticking out the back.
power out? BryanMD Off Topic 14 04-26-2009 03:00 PM
Going online to buy supplies Rollin Tools, Equipment and New Products 4 04-17-2009 04:09 AM
Power Factor / Motor Load / What's the real power consumed? bairdjc General Electrical Discussion 5 03-06-2009 10:49 PM
i need help to power a tv and ps3, via solar power. jessekearney General Electrical Discussion 4 02-01-2008 09:21 PM
Segregation of supplies shoggy Services and Service Equipment 2 05-16-2007 03:30 PM
