Old 02-10-2009, 09:03 PM   #1
sir journeyman
Post high voltage low voltage
Am I able to pass telecom risers through the electric room?
dain is offline   Reply With Quote
Old 02-10-2009, 09:16 PM   #2
Able to? In as far as is it physically possible? Yes, you can. Most job specs will prohibit this, however. While others have the phone closet and the electrical closet all the same room. Just read the Division 16 specs, or if you're getting prints with the new division format, you'll need to read both Division 26 and Division 27.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 02-10-2009, 11:12 PM   #3
"A" inside wireman
randomkiller's Avatar
We do it in the city all the time in RMC, when the switching equipment isn't in the space.
"One Nation Under God"
Low Voltage/ High Voltage MikeD NEC Code Forum 18 02-19-2009 06:17 PM
High Voltage Cable Maintenance p_logix Off Topic 1 01-15-2009 08:58 AM
Low Voltage/ High Voltage MikeD Structured Wiring 1 07-09-2008 05:49 PM
Working with high voltage (warning, graphic) FAST LS1 General Electrical Discussion 39 05-24-2008 09:35 AM
High Voltage Cable Inspection alca82 Linework 4 03-21-2008 11:50 PM
