Light switch location - Electrician Talk - Professional Electrical Contractors Forum
Old 06-05-2011, 10:02 AM   #1
dotrat103's Avatar
Default Light switch location
I'm not sure if this would falls under the electrical or building code. I was wiring a new bathroom and family room the homeowners are putting in their basement. With the odd lay-out and the way the carpenter said he had to frame it, I had to put the light switch for the family room on the outside of the door. I've never seen nor can I find anything that says the switch has to be in the room of the lights it controlls, just that it has to be "readily accessable". Any info you have on this would be greatly appreciated.
-Jason
dotrat103 is offline   Reply With Quote
Old 06-05-2011, 10:07 AM   #2
Rewards Points: 568
You can have the switch anywhere you want-- It can be on the other side of the house as the NEC does not specify. Of course, a homeowner may complain.
I have seen many switches outside the are they serve- no issue.
I have heard of local amendments though- Boston may have one- not sure.
Old 06-05-2011, 10:11 AM   #3
BBQ
Salty Member
BBQ's Avatar
-Jason
Here is the code section.
210.70 Lighting Outlets Required. Lighting outlets shall
be installed where specified in 210.70(A), (B), and (C).
(A) Dwelling Units. In dwelling units, lighting outlets
shall be installed in accordance with 210.70(A)(1), (A)(2),
and (A)(3).
(1) Habitable Rooms. At least one wall switch–controlled
lighting outlet shall be installed in every
habitable room
and bathroom.
Notice that section requires the lighting outlet to be in the room but the switch just has to be on a wall.
As far as the NEC you could put the bathroom light switch in the kitchen closet. (I don't suggest it, it irritates customers)
The Following 2 Users Say Thank You to BBQ For This Useful Post:
jwjrw (08-06-2011), metalpats (08-16-2011)
Old 06-10-2011, 05:21 AM   #4
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
A hallway is still permitted to have a pullchain ?
Old 06-26-2011, 06:55 PM   #5
I would tell the homeowner you can p ut it anywhere but usually put in in the room. Check with them if it ok.
quietshane is offline   Reply With Quote
Old 07-11-2011, 11:35 PM   #6
Rewards Points: 25
A problem with bathroom light switches outside the bathroom is kids
turning the lights out when you are busy inside bathroom.
john120/240 is offline   Reply With Quote
Old 07-11-2011, 11:40 PM   #7
I own stock in FotoMat!
Rewards Points: 6,520
mV0GGspZAos
The Following 5 Users Say Thank You to 480sparky For This Useful Post:
CDN EC (08-18-2011), Chris1971 (08-25-2011), ColoradoMaster3768 (07-16-2011), JM2 (08-06-2011), metalpats (08-16-2011)
Old 08-06-2011, 02:25 PM   #8
Chris1971's Avatar
Rewards Points: 404
-Jason
That should be okay.
2014 NEC code
Chris1971 is online now   Reply With Quote
Location and distance for motor cutoff switch? swimmer NEC Code Forum 3 03-29-2011 11:24 AM
Light Fed Before Switch pudge565 NEC Code Forum 67 04-23-2010 09:12 AM
Furnace switch location. Mr. Sparkle Residential Electrical Forum 17 09-27-2009 10:09 AM
Old Light Switch DeeJayy Vintage Electrical 21 03-24-2008 04:51 PM
GFI/Light Switch Beerman General Electrical Discussion 1 12-15-2007 05:15 PM
