Closed Thread
Old 01-30-2009, 11:46 AM   #1
Wyome
Default lv in residential
Curious as to what the trends for tv and phone/data in houses are leaning towards now. For quite a while now I have been recommending at least one location in each room to have as minimum the following; 1-dual RG-6, and 2-cat5e cables. 1-dual coax and 1-cat5e to the tv locations. I personally would prefer 2-cat5e cables to every phone location in the house, but budget constraints sometimes don't allow that. I would also pull a dual RG-6 to a suitable location on the outside for a dish. All these cables go to a common location in the house, preferably close to the loadcenter.
Now, I know this setup doesn't address every configuration that someone could need, but it covers a good portion. Last year, on a 5000sf house we pulled the normal dual coax to the dish location. When the installers arrived, Dish Network, and I wasn't around, they told the homeowners that the electricians screwed up and they couldn't hook it up the way it was wired. They ran a single RG-6 out of the lv box, laid it on the floor of the equipment room, drilled outside, ran it on top of the ground, and up to the dish. The homeowners didn't see any problem with that.
I have had customers tell me that a dual coax to the dish wasn't enough for them. One couple actually had me come back twice to add a dual coax each time. They used 5 RG-6 wires at their dish(s). I don't know what was involved there. Impossible to anticipate something like that when prewiring a house unless there are specifics given.
Also, with the growing use of wireless internet devices and whatnot, is it still recommended to pull 2-cat5e, or better, to each anticipated data port? I am comfortable doing this if I can get the money for it, but I argue this point with a couple of my guys on each house. One in particular hates it for some reason and tells me that everything will go wireless and we are just spending money needlessly. I don't know enough about the standards or the installation end of this to be comfortable either way. Being an electrician, I am all for the hard wired version. I always thought security was better on a land line than wireless, and reliability was better. But what do I know? I know I'd like to know what everyone else is doing.
I am not talking low end spec houses here. Not necessarily high, high, high end custom homes either.
Thanks for any feedback, Jim
te12co2w is offline
Old 02-01-2009, 11:58 PM   #2
Direct TV HD with a triple LNB would require the 5 RG-6 drop. Currently most Direct tv dvr's would require dual rg-6 to enable recording while watching a different channel.
monitormix is offline
Old 02-03-2009, 09:15 PM   #3
Wanna be Guru
mikeg_05's Avatar
we always pull two RG-6 coax's and a cat 5 to the tv locations for PPV movies and what not. for an HD satellite we run 4 RG-6's from the location and a #10 ground to the media panel. Then individual phones to each bedroom and sometimes a data, all back to the media panel. Those dish network guys are lazy lazy lazy, they probably didnt want to ring out the tv's. IMO its hard to have a structured layout for low volt, id be nice to run that banana cable everywhere and call it good.
mikeg_05 is offline
Old 02-04-2009, 10:30 AM   #4
Wyome
We also have been running a #10 ground to the dish. I think maybe I will start doing 3-dual RG6 to the dish location now, after reading monitormix post. Sometimes this is a real pain. Seems like the dish is almost always way on the other side of the house from the media panel. Thanks
te12co2w is offline
Old 02-04-2009, 04:03 PM   #5
Speedy Petey's Avatar
Duplicate thread. Continue here: http://www.electriciantalk.com/newre...uote=1&p=57231
Speedy Petey is offline
Closed Thread
residential plugs! aNTOnio LuCaS General Electrical Discussion 2 10-30-2008 05:56 PM
residential service changes liverstos General Electrical Discussion 8 07-07-2008 07:07 PM
residential bonding Bkessler General Electrical Discussion 27 03-08-2008 08:52 PM
Residential bidding Irish7 General Electrical Discussion 16 11-30-2007 08:04 PM
Residential Transformer Houston General Electrical Discussion 2 05-22-2007 06:36 PM
