Old 03-22-2007, 09:51 PM   #1
Default MC cable and wood framing
Is it okay to use a staple, such as the Viking #125, to secure MC cable to wood framing? If not, what are some other easy, low-cost options for this application?
Thank you.
Rikki is offline   Reply With Quote
Old 03-22-2007, 10:22 PM   #2
I dunno. I use staples on MC that's in a wood framed building. Sometimes drive straps on the larger sizes. Even though we call them "NM staples", are they only supposed to be used on NM cable? Dang, you ask hard questions.
Old 03-23-2007, 04:25 AM   #3
Joe Momma's Avatar
We've always and only used 3/8's straps on MC in any installation. This may be because we didn't have staples readily available, or perhaps because we were too dumb to see an easier way......?
Joe Momma was here
Old 03-23-2007, 10:09 AM   #4
Ax grinder
raider1's Avatar
I have always used 3/8 straps also, but a staple would work just as well.
Chris
Old 03-23-2007, 12:22 PM   #5
I use 9/16" staples for MC/AC in wood framing. Other than that I use BX(AC/MC) straps.
Old 03-23-2007, 05:01 PM   #6
I was looking over some boxes of staples purposely today with this question in mind. The "regular" staples are marked on the box for NM cable only. The one's with long legs (9/16" and longer) are just marked "cable staples", so I guess that makes them okay for MC too. I've always used staples on MC when it's a wood framed building because it's quick and cheap. As with NM, you just don't need to bash them in like an idiot.
Old 03-24-2007, 05:10 PM   #7
Joe Momma's Avatar
Also instead of "wood framed"
Have you guys used the term "stick framed"?
Joe Momma was here
Old 03-24-2007, 05:53 PM   #8
No, because a building can be of wood framed construction that wasn't stick framed. Stick framing is a process by which wood framing is utilized. Stick framing implies that a pile of lumber got delivered to the job, and it was assembled stick by stick. Wood framing can by of modular components, such as panelized walls, factory fabricated trusses, etc.
Old 03-24-2007, 06:12 PM   #9
Joe Momma's Avatar
Didn't know that MD, so by that logic if there are factory trusses the building was not stick framed?
I've always heard the term in reference to any wood framed structure, or at least so I thought, but I may have assumed.
Joe Momma was here
Old 03-24-2007, 07:41 PM   #10
Around here it is called stick built, and the carpenters I know will add with a trussed roof if trusses were utilized.
And while I am not sure they are necessarily better, carpenters feel they are better, much like electricians would about a prewired assembly.
But one thing I have picked up as I travel the country for projects is the terminology, what we call a 1900 box, I have heard referred to as a 4 Square, standard square (as compared to an 11-B square?). Different areas have different names such as mineralacs or stand offs.
Old 03-24-2007, 07:55 PM   #11
Joe Momma's Avatar
I've heard "stand offs" reffered to as 'back-straps' but not mineralacs, but I've never heard a 4s called a 1900 box
Just wait till that 'hart lock' guy reads this and gets his panty's in a bunch.
Joe Momma was here
Old 03-24-2007, 08:18 PM   #12
Joe do you call them 4 square or a 4S? What about 4 11/16 Square = 11B or 3" round=8B?
Old 03-24-2007, 08:23 PM   #13
rod213's Avatar
We call 4 squares 4x4's. 4 11/16ths we call 4 11's.
How about strut. I've heard it called junior (7/8ths) and senior (1 5/8th's) strut. Normally we just call it by it's measurement though.
-Rodney
rod213 is offline   Reply With Quote
Old 03-24-2007, 08:55 PM   #14
How about strut. I've heard it called junior (7/8ths) and senior (1 5/8th's) strut. Normally we just call it by it's measurement though.[/quote]
You mean Kindorf (no matter who makes it or the color.)
Old 03-24-2007, 09:14 PM   #15
Joe Momma's Avatar
I call it 4s here for typing's sake, because I'm sure everyone knows what I mean. But in the real world I'll say the words four square.
For strut we'll call it deep and shallow, but typically call it by it's measurement.
Joe Momma was here
Old 03-24-2007, 09:45 PM   #16
I call a 4" square box a "4 square". I call a 4-11/16" square box a "4-11/16th box". I have a guy that calls them "five by fives", and it drives me batty.
I always knew an 8B to be a 4-1/8" octagon box, but I just call them an "octagon box".
Mostly I order by the Steel City or Raco part number, so that I can get the exact case of boxes I wanted. SC and Raco part numbers cross over to whatever brand any supply house carries. Last time I ordered a few cases of 4 squares by name only, I got deep welded one's and they're almost exactly 3 times more expensive than 1-1/2" drawn boxes. That's what causes me to order by part number.
Old 03-24-2007, 10:19 PM   #17
Here we call them 1900 or 1900 deep. I was once told Washington DC was the only area to call boxes by these numbers.
Old 03-24-2007, 10:21 PM   #18
I don't know... I've known guys who call them 1900 boxes, but I'm not far at all from DC. I know I've heard guys at the supply house asking for them by that name. I don't know what "1900" refers to, because they're closer to 21.00 cubic inches, as memory serves. Might have been an old part number.
I hear the term "Gem box" a lot too, and I have no idea what that is. I'm not ashamed to admit it either. I think it refers to a beveled corner metal wall box, but I'm not sure.
Old 03-25-2007, 12:10 AM   #19
Didn't know that MD, so by that logic if there are factory trusses the building was not stick framed?.
In that case, it would be a little of both. A stick framed building with factory built trusses.
Old 03-25-2007, 12:12 AM   #20
Joe Momma's Avatar
You've got me on the "gem box" name too.
Though for certain installations I do prefer the pressed boxes over the welded boxes.
Oh and 4 11/16 boxes are also called "4 11/16's" boxes here too
Joe Momma was here
Se Cable JO SMYYT General Electrical Discussion 9 05-24-2008 09:15 AM
Oily MC cable Speedy Petey General Electrical Discussion 18 04-28-2008 05:56 PM
best bit? (for wood) Tangible General Electrical Discussion 49 04-01-2008 05:33 AM
Drilling & Notching Framing Members Joe Tedesco NEC Code Forum 3 06-23-2007 09:09 PM
