Old 11-07-2007, 09:31 AM   #1
Wyome
Question minimun installation temp nm
I haven't seen it anywhere, but it seems reasonable to expect that there is a minimum temperature below which nm-b should not be pulled? Manufacturer specs? Certainly no nec requirements that I could find. I've found that at -20F to -30F the sheath can crack. Don't really like working that cold anyway.
Old 11-07-2007, 10:34 AM   #2
Ax grinder
raider1's Avatar
I am not aware of any mandated ambient temperature limitation as to when you can or can't install NM cable. I would say use common sense, if the insulation is going to crack then it is probably not a good idea to install the NM cable.
Here in northern Utah the winters get pretty cold so I feel your pain. (When it gets to -20f you usually don't feel much pain. )
Chris
Old 11-08-2007, 09:08 AM   #3
Wyome
Chris[/quote]
Right. Sometimes you don't even feel your fingers.
Old 11-08-2007, 09:16 AM   #4
Seen your member
I work in one jurisdiction that has a written code that NM cannot be installed in temps below 0°F.
Old 11-09-2007, 01:50 AM   #5
"Euro" electrician
IMO for NM romex wires anything colder than 10°F i try to preheat it keep in warm place for while until that get warm then string it out soon as possible before the cold get it again.
just want to head up with the new Simpull THHN-THWN's and NM both stated that do not pull if colder than 10°F [ if i recall the instrucations stated that ]
i allready pull few NM's little colder than that and feel it get more brittle with it so kinda like judgement call on what you can do with super cold weather even in super cold room like industrail frezzer [ walk in or drive in type ] same thing too
Merci, Marc
Old 11-09-2007, 05:47 AM   #6
JohnJ0906's Avatar
I sit here very thankful that temps that low are rare around here!
John from Baltimore
"One day at a Time"
Old 11-10-2007, 04:11 PM   #7
Cool
"I haven't seen it anywhere, but it seems reasonable to expect that there is a minimum temperature below which nm-b should not be pulled?"
Yea, it's 75 degrees F . . .
"I've found that at -20F to -30F" - are you daft, man?"
Best Wishes
Be Safe Out there
Old 11-10-2007, 08:58 PM   #8
kbsparky's Avatar
BELOW 20F we have had the outer sheath of romex crack open when pulling it in.
Its time to go home at those temps, or get some heat source going ...
Old 11-10-2007, 09:21 PM   #9
Been gone from Silver Spring, Maryland for forty years. Has it gotten that cold since I left. Brrrr . . .
75 degrees is my answer, and I'm stikkin' to it
Best Wishes
Be Safe Out there
Old 11-11-2007, 09:54 AM   #10
shazam's Avatar
Perhaps this is where "in a craftsman like manner" takes place.
If you pull it and inspect it and it is ripped, broken, or cracked.....you will be replacing it , that simple.
shazam is offline   Reply With Quote
Old 11-12-2007, 11:56 PM   #11
goose134's Avatar
On the bright side, at that temp. I think it almost qualifies as a superconductor.
Old 11-13-2007, 10:00 AM   #12
Wyome
Best Wishes
Apparently so.
Old 12-14-2007, 06:41 PM   #13
Cool Min Temp for NMB
In N Idaho if it is below freezing and no heat in building I look for cracking and separation of the outer insulation. If present I require replacement.
Idaho Abe is offline   Reply With Quote
Old 12-14-2007, 07:21 PM   #14
You'd hardly recognize downtown and up town you'd avoid.
Old 12-15-2007, 12:11 AM   #15
Mad Skills
Celtic's Avatar
A little tape will fix ripped, broken, or cracked sheath on NM...no problem...just keep the tape warm in your pocket
I have a Romex cable in a wall that got nicked. Only the outer sheathing was slightly damaged. Can I repair that damage with electrical tape and not replace that Romex cable?
Answer:
Although the purpose of the sheath of Type NM cable is to protect the inner conductors and Article 334 has requirements for the outer covering, there is no specific requirement to replace a cable assembly with a damaged outer sheath. Article 334 has requirements for protecting the cable from physical damage after it has been installed, and it is reasonable to assume that some minor damage will occur during installation.
Whether a length of Type NM cable must be replaced if the outer sheath is nicked will be a judgment call based on the extent of the visible damage.
http://iaei-western.org/Files/2005/2...Code_Panel.pdf
There is a letter/document from Southwire that details the "process" to repair a damaged jacket on their NM product.
The link I had for it is 404.
Anyone ever NOT have problems with temp power? Jeff000 General Electrical Discussion 5 10-19-2008 09:44 AM
Keeping others out of Temp Panels jculber Workplace Safety 29 07-09-2008 11:44 PM
3ph to single temp fireupyours2 Services and Service Equipment 14 06-09-2008 07:47 AM
domestic installation boots General Electrical Discussion 0 09-16-2007 03:24 PM
Billiard light installation? pip9ball General Electrical Discussion 1 08-30-2007 03:38 AM
