My first load calc - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
Old 05-12-2017, 08:27 PM   #1
WronGun's Avatar
Rewards Points: 294
Default My first load calc
Are there any cookie cutter forms/websites you guys use for doing in depth load calculations.. I'm doing my first one and something to follow would be a big help
Old 05-12-2017, 08:30 PM   #2
Rewards Points: 14,728
You lazy dogg.
Old 05-12-2017, 08:37 PM   #3
WronGun's Avatar
Rewards Points: 294
You lazy dogg.
Lol , I've honestly started it already using the code book .... it being my first one , it sure would be nice to see some sort of base worksheet... it involves large Commercial kitchen equipment and I want to check my work multiple times
Old 05-12-2017, 08:37 PM   #4
Glock23gp's Avatar
Rewards Points: 70
I doubt such a thing exists due to the complexity of each occupancy and bouncing between tables you can or can't use depending on certain loads.
Residential is the worst due to being able to derate your derates in certain circumstances.
Best way is to go slowly page by page in 220 breaking down each load by article and balancing your phases as you go (including neutrals).
Sent from my SAMSUNG-SM-N910A using Tapatalk
Using Tapatalk
Glock23gp is online now   Reply With Quote
Old 05-12-2017, 08:42 PM   #5
Click Here
Rewards Points: 1,512
For resi I just use this spreadsheet: https://www.mikeholt.com/documents/c...lculations.xls
The Following 2 Users Say Thank You to HackWork For This Useful Post:
Suncoast Power (05-13-2017), telsa (05-13-2017)
Old 05-13-2017, 05:52 AM   #6
WronGun's Avatar
Rewards Points: 294
Nice!
Old 05-13-2017, 06:32 AM   #7
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,718
Really?
I can smash out a residential load calculation in less than a minute.
Old 05-13-2017, 08:45 AM   #8
Click Here
Originally Posted by WronGun View Post
Nice!
That is older than I am, so hopefully it still works.
It's nice because you can add your company name to it and a job name. There is a town here that wanted a load calc when doing service upgrades, so I used to use that spreadsheet to include a load calc with every service upgrade permit application I submitted. All the inspectors liked it and a few made comments about how they didn't need to look closely at things because they are sure I did them right, based off of my going above and beyond with the load calc.
Old 05-13-2017, 08:53 AM   #9
Glock23gp's Avatar
Rewards Points: 70
Originally Posted by Suncoast Power View Post
Really?
Congrats.
I'm talking about commercial and industrial sizing load, wire and conduit from xfmr to each circuit including sizing additional transformers, motors and neutral loads.
My 3 year old can do resi calcs.
Using Tapatalk
Old 05-13-2017, 09:04 AM   #10
Click Here
Congrats.
In all fairness, you did say "Residential is the worst" which I also kinda wondered about.
Old 05-13-2017, 09:13 AM   #11
Glock23gp's Avatar
Rewards Points: 70
I meant like a multi family complex with different buildings (multiple xfmr calcs) and occupancies.
Say a residential over commercial with different occupancies downstairs to calculate different based on different lighting loads.
My bad.
As CS says.. I digress....
Using Tapatalk
The Following User Says Thank You to Glock23gp For This Useful Post:
HackWork (05-13-2017)
Old 05-13-2017, 09:16 AM   #12
Click Here
My bad.
I see what you're saying, makes sense.
Old 05-13-2017, 09:48 AM   #13
Glock23gp's Avatar
Rewards Points: 70
Here's an example that was used on my supervisors test.
Other questions are
What is the load in, in amps, on the grounded conductor for the office service
Same for multifamily building
What is min feeder conductor size for a dwelling unit using THWN-2 aluminum wire
What is minimum service rating for the multi family building if using the optional method.
What is the feeder neutral load in amps for each unit
Etc...
This is a good practice calc Wron
Using Tapatalk
Old 05-14-2017, 01:28 PM   #14
WronGun's Avatar
Rewards Points: 294
this isn't that easy for commercial. Do you guys do all your commercial load calcs yourselves? It just seems being my first time a mistake could cost me large on this type of job. Following the code book , but my numbers dont seem right...should i hire this out?
A commercial kitchen where everything could very well be running at the same time, along with lighting, receptacle and HVAC loads im looking at 325A with the potential for future additions, Im figuring 400Amps....
This just got a whole lot complicated especially when the service is 2'' underground pipe, This may put me out of this job because now it seems i may not be a big enough contractor to handle this
Old 05-14-2017, 01:58 PM   #15
Signal1's Avatar
Rewards Points: 732
Aren't you just starting out? One man?
If you're not comfortable with it, you may want to reconsider this job.
I don't think there's a guy on here that would look down on you for it, we've all been there.
I can see Bunker Hill from my house!
Old 05-14-2017, 02:05 PM   #16
WronGun's Avatar
Rewards Points: 294
I am just starting out...But this has the way its been this year....Ive been jumping in and grinding it out until i figure it out and get it..... And all those situations that were stressful are now a walk in the park because i never walked away. Im looking at this situation the same way, if i take it on the next one I will be experienced. I have the resources to pull it together....
Ive figured and designed the whole branch circuit layout...
Now that I just received more information on this job regarding the service. I need to make sure before i tell the GC we have a serious problem.
I didnt really do much calculation regarding the load...I have a list of equipment that may very well be running all at the same time day in and day out. I added up the amps and then did load calcs for the lighting and receptacles by SQ', then figured HVAC and left room for future expansion.
which is why i came up with 325 which im upping to 400.....This is a issue with a 2'' underground pipe
Old 05-14-2017, 02:31 PM   #17
Signal1's Avatar
Rewards Points: 732
It sounds like you're off to a really good start and I applaud your ambition for taking things head on. What you're doing isn't easy, I know first hand.
It sounded like you were apprehensive about taking on this job because of the size of your operation. All I meant is that sooner or later you may have to say no, and there's nothing wrong with that.
Growing too fast can be a killer, many small shops find themselves with hyper-extended credit, and little to no capital real fast this way.
What ever happens good luck with it.
WronGun and Sparky9868 like this.
Old 05-14-2017, 03:17 PM   #18
Glock23gp's Avatar
Rewards Points: 70
Did u do the calc page by page like I said in Article 220?
It looks intimidating at first but if you break it down step by step it simplifies it big time.
Lighting make sure it's all at 125%
Recep
AC heat
Equip
Why are you stuck with only a 2" conduit?
This is an existing building retrofit?
If it's 3 phase make sure you are diving kva by square root not the voltage.
Using Tapatalk
Old 05-14-2017, 03:21 PM   #19
WronGun's Avatar
Rewards Points: 294
Yes , I did a load calc... with all the codes and rules I'm not 100% sure I'm correct. It seems I figured larger....
but regardless that's my main coming up from the floor , even if I could get away with 325A Using copper I'm still undersized with my pipe.
Currently the main is 225A and I've added up 260A of equipment being installed in the kitchen... this is 100% rating of some pieces and 125% of a few others.
The code says 65% of more than 6 pieces of equipment in a non-dwelling kitchen which seems odd because my list of equipment could all very well be running together
Old 05-14-2017, 03:26 PM   #20
Glock23gp's Avatar
Rewards Points: 70
What's your final kva?
And
What did u divide it by?
Using Tapatalk
Two family load calc help Jimelectric Services and Service Equipment 2 04-09-2017 07:59 PM
Size of Main for Demand Load Azachi Canadian Electrical Code Forum 5 01-19-2017 11:03 AM
Do transformers draw a load by themselves? ggez General Electrical Discussion 12 09-21-2016 10:21 AM
Another Load Cell Question I&ETech PLCs, VFDs, Motors and Controls 3 03-31-2016 02:51 PM
Just would like someone to double check my Wye transformer load calculations. JasonCo General Electrical Discussion 7 03-09-2016 11:27 PM
