NEMA L6 - 20R wiring - Electrician Talk - Professional Electrical Contractors Forum
Old 06-30-2011, 01:48 AM   #1
Default NEMA L6 - 20R wiring
I would like to know what's the correct wiring for a Female connector L6-20R. This is twist connector for 250VAC and 20 Amps, 2 poles & ground, and is used on some machines designed for the EU market but when those machines ended here in the US they are connected to 120VAC and it is connected as: X Hot, Y Neutro & G Ground, but I believe that it should be connected as: X Neutro, Y Hot & G Ground.
[IMG]http://www.electriciantalk.com/data:image/jpg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBhQSEBUUExQUFBUVFyAVGBcYGRgaHBwfHBgdIBgcGx gbHCYeHx4lGhYdITAgIycqLiwsHB4xNTE2NSYtLCkBCQoKBQUF DQUFDSkYEhgpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKS kpKSkpKSkpKSkpKSkpKSkpKSkpKf/AABEIAH0AggMBIgACEQEDEQH/xAAcAAACAgMBAQAAAAAAAAAAAAAABwUGAQMEAgj/xAA7EAABAwIEAwcDAQYFBQAAAAABAgMRAAQFEiExBgdBEyIyUW FxgUKRoRQjUmJyscFDgpKi8DNTk9Hh/8QAFAEBAAAAAAAAAAAAAAAAAAAAAP/EABQRAQAAAAAAAAAAAAAAAAAAAAD/2gAMAwEAAhEDEQA/AHjRRRQFFFFAUVDcS8WW9i1nfXE+FAgrV/KmfzsKWCuZuK3alfo7aEEwkpaUsjU7rPcmB7UDomtL92hHjWlP XvED+vvSXc4ax+6guLcQPDBeDeh3JSg6/OtemeR924cz1w0DG/fcV6DWNPmgb9vjLC4yPNKzbZVpM+0HWuyaTj3IReXu3SCqDoWy BPTXMT7mK5Ty2xi3ILD+bLMZH1JA0/dXA9Pigd1FI9XEeO2JCnkOrQBrnbDiY9Vo1HvNMbgvmCxiCAAQ 2/EqaJ166pMDMNJ01HWgtVFE0UBRRRQFFFFAUUUUGCaonHPNNqzB aYyvXEwRPdb/AJyNz/CDO8xWrm5xkbVgMMqh58akTKUagkRsSdB8155dcs27ZCLi4Tnu FDMAoaNzBACT9Y6k7HbzIV/hfl5cYi8LzElKyqMhtUhawNgRpkR6bn0mabllYoZbS22kIQkQl KRAA9q30UGIrNFFAViKpXEHNe2s7pdu4h4qRllSQkjvQT1nRJn 12qbwjjOzuRLNw2r+EnKr/SqFfigmVIBEHUHSKWPGXKEKUbjDz2Lg73ZDupJHVtQ8B9Nvamf NLjhni69dxZdk6tlSWVOKWtKdVJEBCdDAIKgZ30INBG8Gc2Ftr/TYlKVAwHVDKQeiXEwI69/7+dNdp4KSFJIUkiQQZBB2IIqA4r4Itr9BDqAHACEOp0UDGkkeI ehmqNysxxy0unMLuSBlUez2gKGqkg+Sh3h8+dA26KBRQFFFFAV w43i6LW3cfc8LaSo+Z8gPUmAPeu6k5znxhxy5ZsW1d0hKlJHVa 1QgK1jQQQPWfYNHA2EOYviK7+5H7JtUhO6SoeBsA/SkQT56eZp1Co7h/BEWls2w34UCJ6k/Uo+pOtSNATXnOPOljze40KEiyt1HtXCO1KdCEmMqAfNRP296ir TkrdKaCnLvI4ROTvqAPQFWbp5gbzFA4lPpG6h9xXoGkRxTylet LZ183KXENAHLlUCQVAKG5A7xB9Yq78lblS8OUFLzZXlJSJJKRl SY16ayAOlBQsFwJq/x59p5a3G87q8wVqrKYAzDpr0jarJjnIpBzKtXyOobdEj27Qaj5 B96r44GxWxuVv2zRkKUEqQW1kpJ/dJ1BEdN6unA/NlFwexvMjD05Uq1CFnaNfCqeh/+UFUwHiq8wa67C+Di2VeZKoA0C2lHceafLyNMDhrgeyQtu7tVu KJKl9oHJDgWTKVCIIBO0AggT1qX4p4WZv2C06PVCx4kK8x/cdRSu4IxZ3B8QVZXeYNOqASfpBJhDiZ+lWxjbrqDQOs0tObnBx Wj9ex3XmAFLyjVSUkQqf3kRM+XsKZQNYcbCgQRIIgg9QdxQVjl 7xeMQtAtUB1uEOgecaKA8lb/AH8qtNIXBlHC8f7FJPZl0NEToUOgFBPTu50n4p9CgKKKKDBpF4 Ys3vE2ZQIyvKIAA2ZBCZ6fSNfWnFxPfliyuHUmFIaUpJ8jlOU6 +sUqeReGhdxcPqEltAQCR1WSVQdphOvvQOgVwY9jCbW2dfX4W0 lXufpHySB81oxLiy0t3OzeuGm1xOVSgDB20/5pJ2FVLna8sYcjKe6p5IXBiRBI06iQKCocrsGXf4iu8fhQbV2i tDCnFTljp3YmNdhTax7i61sikXLobK5yiFKJA3MJBIGu5qB5P2 KW8LbUkauqUtR8zmyj4hIpe8WWn6ziPsHCQhTqGtOiQgEgTsTr 8maCz8weY1lcWDrLLxWtwAABtYGi0kglQEaD8V2cjnicPcBiEv qA89UIJnXzrtHJvDv+25/5V/8AurPgXDzFm2W7dsNpKsxEkkk9SSSToAPYUEjFUbjnlczegutQ zcTmKgNHNNljz0HeHrM1eqwaBT8q+PXS8bG8USqSG1LnNmHibU eugME+UeVcvOjGLJ5KEIWldy0rdEKASZzJUoaTIBjcfNdHHXKh 9697ezyJS73l5lZci51UIEwd9NZmp/hHlJbWkLei4d81DuJP8KP7qn0ig7OVeLPP4c2XkrCkEtpWr60j wq11Ohyz1y1cKwExtWaBLc8rTs7u3fRopSCJEzLapSZ8+901+1 NzBb7trZl0EHtG0rkTGqQdJ1ql86sH7XDw6N7dYV8KhKvyQfiu rk/ihewxCTMsqU1J8h3k/ZKgPigu9FFFBB8b4YbjDrlpMlSmyQB1Ke8B8lMVQOQ18nJctaZ pS4PMgjL9gQP9XrTaUkEQdQdKRPAoFlxApjMcudxgdJ6okf5R+ KCW4pYct72/KrZdwblKCwtTJeQAIzNkToNhPTKNNakOY6XF4AwpaOzWktFaMp Tl0KYCdYiRoaaEVXOYeDm5w19tIJXlzpAMSUkGN9dtqCM5PvlW FNAx3VrSPhZ39dTVA4qc7DiVKwQT2zSjmEAZwkGY8gZn/hsfIvGwph62Ku8hXapH8KgAqPZQ/wBw865ed/DkdnfJUBGVlYiDMkoUD1OsfCaBuCs1U+XnGycQt5MJebhLiR+F J/hP4MirZQFFFRvEGPtWbCnnlZUp0G5KidkgDqaDvLokJkSRIE6w NzFe5r58tm8RxW7dvbcFK2vCQvLkH0toPUxvsD13q1cMc5ChfY YigoWklKnQmMpHRxsCQZmSPTSgbNFa2H0rSlSCFJUApJGxB2I+ K2UFH5xYn2WGLSJl5aWtCBpOZXTUQmCB5/fXyZw5TWGBSv8AGcU4PaAkffJNVvnzifetmArUZnVJ9+6gn7K/NMvhXD+wsbdo7oaQk++UT+aCVooooA0jeajKrTGGrpI8QQ6CUw kqbVChMa6BM9e8KeVVnmFwr+uslNpCe1T32iRsRuAemYafagsN tcJcQlaTKVAKSR1BEg/Y1tillyc4rU4hdk+VdozqjNM5BoUGeqFdPI+lM0UCK474dew7E Q/YhxCXAVpLaSrKTotMQRGsgHz9K923L7FcRUld44ptG8vKkgH91 pJ09jlp5UUFY4N4AYw4KLZWtxYyqWo9AZgJGgE/PrVnoooK1xzxonDmEuFtTilqypA0ExPeV0H9aWmF4Bf46tD105 ktkqMGAnQxmDSANdozK/OtMjmNw3+ssH***LiP2jf8yenymR80uOWPMZuzt3WblSsqP2jQ AJMnxIA2Gve1IGpoG7ZWTFjbBCcjTLY1JIA9SpR3JPXrSS4gnG sWKLVIyQEhcADKknM4r3J0mToKkMZ4lu8dWm2tmS2wFSokmPQu q2AG+USZ+KYnBmC2dhbhLTrayteRbpUmVubZN9CDsmgsljaJaa Q2nwoSED2Agf0rcazVV5icYCwtCoQXXO40PWNVeyRr7xQLfHiM S4jS2mFtoWhs+WRrvO/nOPXTzp4ilvya4X7K3VduBXa3HhzfuTIPuo6+0UyaAooooCsGs 0UCb5m4A5YXreJWwgFYK/JLnmR+6saH1nzFNDhvH2722Q+14VjUHdJHiSfUGujF8KbuWFsu iUODKR19CD5g60n3MIxLAnM7BNxak5lAAlMCJzo+hUfUNP6UDs oqpcIcyba/ASD2T3VpZ3/kVsofn0q2A0GaKKKApePcmLZd4t9a1FpaivsAMok7jODMSSdI9 6YdFBy4fhjbDYbZQltCdkpAA9/U+ppfW3ByUcQlYaX2HZ/qU6Hsw6e6Y+md1e59KZRNRHEfFdvYt533AkxKUDVavRKevvt60 EspQAM6CksGzjmNHWbS3I0OxQkgECI1cUCfQH0FarjGMRx14ts As2wMHUhAE/4ih41dcg+3WmhwZwc1h7HZt95aoU4s7qUB08kjWB0mgnWmwlIS kAACABoABsAPKvdFFAUUUUBRRRQFYis0UC64s5PM3BU7aq/TunXLH7Mn2GqTPUfaqlZ8wcTw3Pb3DRdKDOZ3OopG/wD1AYUnyMn+1PKvKkAiCAQdINAqrLn02SkO2qkie8pCwqB5hJA n71b8N5l4e9GW5QgnTK5KD/ujy3rsxDgqy***LZkxtCQn8piqrinJCzXmLS3WSdQAQtI08la/mgtmI8Z2bABduWgDtCgon4TJ+aqGJc8rVBUGmnXo2VohJ+/eA/y1xYdyKZCwXLhxaRulKAgn/NJq14fyxw5pIAtkrO+ZyVkx7mPiKBePc38RuAoW9ulMiAUIW4R rvOqZHtFSHC3KV19YuMTWpXUNFRKj176p0Enwj8U2mLdKEhKEh KRoAkAAewFbKDTa2aGkBDaUoQkQEpAAHwK3UUUBRRRQFFFFB//Z[/IMG]
Thank you for your inputs,
jhkilowatt
jhkilowatts is offline   Reply With Quote
Old 06-30-2011, 02:17 AM   #2
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,114
jhkilowatt
The plug and receptacle should be changed to L5-20's when operating at 120V, only use an L6 when you have 240V and no neutral, otherwise you would need an L14 for 120/240V.
I HAVE THE RIGHT TO OFFEND ANYONE I PLEASE. YOU HAVE THE RIGHT TO BE OFFENDED, YOU DO NOT HAVE THE RIGHT TO SHUT ME UP.
The Following 3 Users Say Thank You to TOOL_5150 For This Useful Post:
BBQ (06-30-2011), HARRY304E (06-30-2011), sparky970 (06-30-2011)
Old 06-30-2011, 02:21 AM   #3
Jlarson's Avatar
Rewards Points: 2,758
What that ^ guy said.
Old 06-30-2011, 03:25 AM   #4
Yes, you are correct, unfortunately that is the way that it is wired before shipping the machine.
Thank you for your input.
Old 06-30-2011, 03:28 AM   #5
Ambassador of Amps
TOOL_5150's Avatar
Glad I could help gangsta.
Old 06-30-2011, 05:24 AM   #6
BBQ
Salty Member
BBQ's Avatar
Well you can't install an L6-20 outlet in the USA supplied by 120 volts.
There is no 'correct way' to miswire a receptacle.
jhkilowatts (07-01-2011)
Old 06-30-2011, 05:32 AM   #7
BBQ
Salty Member
BBQ's Avatar
200.9 Means of Identification of Terminals. The identification
of terminals to which a grounded conductor is to be
connected shall be substantially white in color. The identification
of other terminals shall be of a readily distinguishable
different color.
Your X and Y are brass colored neither is silver.
110.3 Examination, Identification, Installation, and Use
of Equipment.
(B) Installation and Use.
Listed or labeled equipment
shall be installed and used in accordance with any instructions
included in the listing or labeling.
L-6 not listed or labeled for 120 volts.
The Following 2 Users Say Thank You to BBQ For This Useful Post:
HARRY304E (06-30-2011), jhkilowatts (07-01-2011)
Old 06-30-2011, 09:31 AM   #8
Rewards Points: 1,456
it is not hard to cut a cord an put new plug
The Following User Says Thank You to oliquir For This Useful Post:
Old 06-30-2011, 09:49 AM   #9
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
he's just looking for a way avoid paying for the L-5 20 twist locks that got to be the only reason he would ask that question.
Looks like he will be coughing up the bucks.
jhkilowatts,
Welcome to the forum..
Old 07-01-2011, 04:39 AM   #10
I want to thank you all for your input, I learned allot from all of you.
The situation is a little more complicated that what you might think, I can’t change the equipment without the proper documentation, it has to be approved by the engineer department. I tried to work with the engineer department but…... I need to get more information to present to them and they are who makes any decision.
Old 07-01-2011, 07:55 AM   #11
Speedy Petey's Avatar
Rewards Points: 1,622
And the engineers can't figure out this super simple solution???
Old 07-01-2011, 08:42 AM   #12
Jlarson's Avatar
Engineers don't deal in simple solutions.
Old 07-01-2011, 08:43 AM   #13
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 2,510
LoL, you can't change the equipment without an engineer permission, but you can change a national standard to fit their screwup.
Do everyone a favor and use a Sharpie and write all over the receptacle and on the wall what changes you have decided on.
You might save someone from getting shocked later.
Old 07-05-2011, 11:20 PM   #14
Part Time A hole
my thoughts are at least your not trying to make a 120v rec 220v that would be much more dangerous.. i would go with " hey dumbass i cant hook this up like that its not legit".... heck i would probly just change the end and no one be the wiser.. engineers usally don't notice the small thigs... most entertain ment ever was to put temp lighting using left hand thread pig tails up and let the smart guy try to change the bulb...
pistol pete is offline   Reply With Quote
Old 07-08-2011, 10:21 AM   #15
JH,
I believe you are over thinking this. Tell the engineers it cannot be connected as is and what the solution is. you should have your documentation shortly.
Jeff
greco is offline   Reply With Quote
Nema ve-2 GPB697 NEC Code Forum 1 06-30-2011 07:40 PM
NEMA AB-1 and NEMA AB-3. sheryl86_ann Other Codes and Standards 4 02-01-2011 12:46 PM
NEMA wc3 document nolabama Other Codes and Standards 0 09-23-2009 11:25 AM
Nema specification martinkulik Other Codes and Standards 2 04-22-2009 06:12 PM
My apt. has a nema 6-30 R receptacle, what should I do john newman NEC Code Forum 3 09-21-2007 10:44 PM
