Old 04-07-2009, 10:04 PM   #1
Adam12's Avatar
Default Smoke Detector clearance
How far away from a AC supply does a smoke detrector in a ceiling need to be? I have always thought it was 3', cant remember.
Adam12 is offline   Reply With Quote
Old 04-07-2009, 10:05 PM   #2
redbeard43's Avatar
yes 3 feet
You have the ring, and I see that your schwarz is as big as mine.May the schwartz be with you!
redbeard43 is offline   Reply With Quote
Old 04-07-2009, 10:10 PM   #3
Adam12's Avatar
Originally Posted by redbeard43 View Post
yes 3 feet
You are quick on the draw RB.
Old 04-07-2009, 10:17 PM   #4
redbeard43's Avatar
just came across the post 1 min after you made it...lol
Old 05-03-2009, 08:48 PM   #5
It would be nice to stay 3' away if you think it will effect the operation of the detector, but there is no code requirement. The 3' distance is only found in the annex of NFPA 72.
RonS is offline   Reply With Quote
Old 05-03-2009, 09:07 PM   #6
I am a RAT.
william1978's Avatar
How about 110.3 (B)
Old 05-03-2009, 09:07 PM   #7
Mac Hine's Avatar
I say 0' from the supply but 3' from the return air. At least that is what I thought but maybe from both. Never put one next to a supply grill.
Edit: Apparently NFPA 11.8.3.5 states from the supply grill- 36". Also 36" from ceiling fans- alot I didn't know in this section.
Mac Hine is offline   Reply With Quote
Old 05-03-2009, 09:08 PM   #8
I am a RAT.
Welcome to the forum RonS.
Old 05-03-2009, 09:17 PM   #9
William,
If it's in the instructions, then you are stuck with it ... you are correct.
Many detector instructions that I look at direct the installer to NFPA 72.
Old 05-04-2009, 12:05 AM   #10
redbeard43's Avatar
ive done FA for a while, it is 3 feet min away, trust me..doesnt have anything to do with returns.. duct detectors are placed in the returns on larger units, sometimes even the supply. its FA code
Working clearance. JohnJ0906 Code Violation Discussion 22 09-07-2009 10:47 AM
Microwave to stove clearance waco General Electrical Discussion 8 03-03-2009 10:33 PM
Smoke detector breaker locks crk1a General Electrical Discussion 13 09-25-2008 09:27 AM
NFPA Smoke & Heat Detector Clarification Needed Randy L Other Codes and Standards 4 06-27-2008 07:17 AM
