07-20-2012, 10:58 AM
UL Rating
Will the UL rating be voided if the CB in a meter main is bypassed?
07-20-2012, 11:01 AM
UL will say it is up to the AHJ to determine if the modifications effect the equipment to the point it would need a 'field evaluation'
Why would you want to do this?
07-20-2012, 11:47 AM
Electrical Simpleton
How exactly do you intend to "bypass" it?
Pete
Confidence is the feeling you have before you understand the situation.
07-20-2012, 04:29 PM
Registered Big Member
And it's UL listing, not rating.
Freshly manscaped for your motocross riding pleasure.
07-20-2012, 11:16 PM
Okay, UL listing. Your correct. Congratulations.
Pete,
I'm going to remove it and wire directly to the meter lugs. Exactly.
BBQ,
We have a line division where I work, and one of the linemen replaced a meter with a meter main on an existing home. The meter main, now the first point of disconnect, has created some code issues with the grounding. The easiest solution is to remove the breaker in the panel. Thanks for providing the only useful answer.
07-20-2012, 11:17 PM
not a union thug
Pete,
BBQ,
How does removing the breaker correct grounding issues?
07-20-2012, 11:38 PM
Heavily Armed Member
Because the lineman removed the old meter socket and installed a meter mane that makes the panel a sub panel so the neutrals and grounds must be separated Because the meter main is the first disconnect.
JakeW1;Welcome to the forum.....
07-21-2012, 08:55 AM
not a union thug
So what is the op going to do, remove the breaker in the meter "MAIN" not "MANE"
07-21-2012, 09:48 AM
976-EVIL
Yep. Sounds like a good solution
07-21-2012, 09:20 PM
Thanks, Harry.
The Following User Says Thank You to JakeW1 For This Useful Post:
07-21-2012, 09:23 PM
Thanks, Harry.
Your welcome..
07-21-2012, 09:28 PM
Yes he is going to bypass the breaker and go into a main breaker in the panel that makes it the main disconnect so the meter main becomes just a meter socket .
You spelling sissy...
08-11-2012, 06:18 AM
I had one AHJ inform me that he was empowered to be a field evaluator for UL
now i'm unsure as to just where, or how this authority was granted him, but i did get the impression it was not something done automaticaly, or via quick phone call
08-14-2012, 01:31 AM
bypass the breaker seems like a good plan, may want to remove it all together and blank off the opening in the enclosure for clarity. or at least label the breaker as not used. not sure how removing it would effect UL listing...
