Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Trade Topics > Linework
Old 01-28-2007, 01:09 PM   #1
Default Parking lot light installation
The following picture shows men installing parking lot lighting from a JLG boom lift. Special thanks to Derek Pasch, Staffing Specialist at Meisner Electric in Delray Beach, FL for the pictures. The fella on the left must have been on break. He appears to be asleep.
Old 02-01-2007, 10:41 PM   #2
Joe Momma's Avatar
Or perhaps just scared of heights and trying not to puke.
Were they raising the poles with the snorkel lift or just attaching heads?
We did them from a JLG once, but they wre on wood poles, normally we mount the heads on the ground and have a crane out for a couple hours to raise all the poles.
Joe Momma was here
Old 02-02-2007, 07:26 PM   #3
Originally Posted by Joe Momma View Post
Were they raising the poles with the snorkel lift or just attaching heads?.
Hard to tell.
I always bolt the heads on while on the ground, and go ahead and run the conductors down to the handhole and get everything wired up at the heads. That way, all you gotta do is stand them up and get them level. Myself, I generally get them all stood up and "eyeball level", then go back and fine tune level them all at once. Sometimes you need to tape a nickel to the end of your level to compensate for tapered posts. I know people have lots of different tricks for leveling tapered posts. Some guys hang a plumb bob at arm's length, and stand back and sight the post off that hanging plumb bob.
Old 02-02-2007, 08:30 PM   #4
Joe Momma's Avatar
We always hang them as fast as possible too, with crane costs and all. Last summer me and a JW I'm used to did 26 in less than 2 hours, we were pretty proud of ourselves. Then he leveled for the rest of the day while I wired (and fought wasps in one pole, I batted down at least 4 with a shovel I found).
I like that trick of taping a shim/nickel to the level. Once you get it set then all the poles will be the same.
Joe Momma was here
Old 03-08-2007, 04:50 PM   #5
Pinhead's Avatar
Wow, those are really good tips.
Pinhead is offline   Reply With Quote
Old 12-14-2007, 08:29 PM   #6
What we generally do (this is our 3rd Lowe's this year, and have done a few other styles of lights in the past) is level the lugs first on the concrete pads. Then just stand up the built pole with either the boom truck or rent a crane and set them on, and then all you have to do is burndy the leads together. Most of the lights we do are either 277 or 480, 2awg to the base, 4awg from the base to the heads. Longest pull for the parking lot lights was 760' of 4awg, that one took a while with the old tugger just a tuggin.
"Wire pullin', nut twist'n pipe bending light hanging crazy Mainah."
perley03 is offline   Reply With Quote
Old 12-14-2007, 08:50 PM   #7
Pinhead's Avatar
Thumbs up
Why such large wire? Voltage drop? Thanks for your reply, it was very informative. Oh, never mind, I just re-read your post and see the extreme lengths of the runs. :-)
Old 12-14-2007, 09:13 PM   #8
Use such wire because the engineers who designed the plans for Lowe's wanted to use them on the long pulls. On the shorter runs, I believe it's either 6 or 4awg to the base, 10awg to the heads. There is alot of overkill in these stores, I guess they didn't want to mess around.
Old 12-14-2007, 10:54 PM   #9
Pierre Belarge's Avatar
Larger conductors have less heat loss...hence a savings of some $ during the use of the lights, which probably burn for quite a few hours each day. Long term savings for Lowes.
Pierre Belarge is offline   Reply With Quote
Old 12-14-2007, 11:51 PM   #10
I did the parking lot lights for a Sam's/Lowes. MAN those were some long hard pulls.
perley's description is exactly how I do it.
Old 12-14-2007, 11:57 PM   #11
Seen your member
I've done some WalMart light runs that were fed with #0, #6 up the pole.
To anything!
Old 12-27-2007, 08:48 AM   #12
Default long pulls
have worked on several TV towers 2000Ft 4/0 pulls for strobe lites.
reddog552 is offline   Reply With Quote
Old 12-27-2007, 02:19 PM   #13
nap
a real PITA
was that mostly up?
Old 12-27-2007, 02:37 PM   #14
Mad Skills
Celtic's Avatar
Before we stand them up, we heat 'em up
If the bulb, ballast, etc turns out to NFG - it's a quick swap on terra firma
Old 12-27-2007, 02:40 PM   #15
nap
a real PITA
Not a bad idea there celtic.
Old 12-27-2007, 02:52 PM   #16
On that tower work:
Any work you can perform on the ground is a plus. How much can a few strobes consume, even considering the VD, the 4/0, must have been aluminum, and must have been spec. Enlighten me here gents . . .
"was that mostly up?".
Cannot imagine feeding from the top down . . .
Best Wishes
Be Safe Out there
Old 12-27-2007, 02:52 PM   #17
Mad Skills
Celtic's Avatar
While going up in the lift is "oh so glamorous"....being the "re-do crew" in freezing weather is for the birds
Old 12-27-2007, 03:06 PM   #18
nap
a real PITA
Originally Posted by HighWirey View Post
On that tower work:
Best Wishes
I was referring more to was most of that 2000' running the tower as opposed to getting to the tower.
Top down? How could you ever so that?
Old 12-27-2007, 03:17 PM   #19
Marc,
Meisner Electric came into central Florida like gangbusters, was awarded a large project from under us locals, learned their lession, then went back to Delray Beach. Seems it took ten years to settle their claims in court. My NASA contracting officer had a room full of court docs concerning that contact.
Correct me if it is not gospel.
Been incorrect before, and done that.
Best Wishes
Be Safe Out there
Old 12-28-2007, 09:22 AM   #20
Default tower lighting
yes its up. we pre assemble 250' runs,then raise them to tower. this is quite tricky. The 3" rigid will crack at couplings.the reason for 250' ft runs is a strain releaf box+ light is required.We use a special rigging,lifting at 3 points.
Need suggestions for installing parking lot receptacles personal General Electrical Discussion 13 10-13-2008 03:59 AM
domestic installation boots General Electrical Discussion 0 09-16-2007 04:24 PM
Billiard light installation? pip9ball General Electrical Discussion 1 08-30-2007 04:38 AM
Parking vs CT cabinet JohnJ0906 Services and Service Equipment 5 05-05-2007 07:13 AM
Parking lot light JohnJ0906 Code Violation Discussion 2 01-30-2007 08:18 PM
