Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Trade Topics > Linework
Old 12-28-2007, 10:29 AM   #21
nap
a real PITA
I honestly do not envy your work reddog.
work safe, be safe
Old 03-21-2008, 09:37 PM   #22
Originally Posted by reddog552 View Post
yes its up. we pre assemble 250' runs,then raise them to tower. this is quite tricky. The 3" rigid will crack at couplings.the reason for 250' ft runs is a strain releaf box+ light is required.We use a special rigging,lifting at 3 points.
Comsat RSI ?
scrooge is offline   Reply With Quote
Old 03-28-2008, 01:24 PM   #23
Default Scrooge
If you are referring to what company I work for. Theres been several, Comstat a little,Bell south,Crown,United Riggers,Edmiston Tower.RF SpecltiesOf Pa.I work as a Electrican/Rf Troubleshooter.
reddog552 is offline   Reply With Quote
Old 03-29-2008, 02:32 AM   #24
Joe Momma's Avatar
Originally Posted by Pinhead View Post
Why such large wire? Voltage drop? Thanks for your reply, it was very informative. Oh, never mind, I just re-read your post and see the extreme lengths of the runs. :-)
Sorry for draggin up an old post, but
The street lighting we did not long ago (though an overkill) was pulled with #4's to the j-box on a 40A breaker and #12's up the pole. The connection at the j-box had a 10A fuse on both phases up to the pole.
Wiring this way allows a lot more lights on a circuit to save on wire, but the weatherproof break away fuse holders had to cost a pretty penny each.
Joe Momma was here
Old 03-29-2008, 11:34 AM   #25
gilbequick's Avatar
If they're what I'm thinking of, those little suckers are about $30-$35 a piece.
You're right, not cheap!
Old 03-30-2008, 10:59 PM   #26
I used to work on some Comsat radar tower jobs and we lifted the 3'' the same. Not nearly to that scale though.
Old 06-13-2008, 05:43 PM   #27
Default electrical installation
any safety precaution about xxxxxxx
topak is offline   Reply With Quote
Old 06-13-2008, 07:01 PM   #28
Look, Listen and Live
BackInTheHabit's Avatar
The following picture shows men installing parking lot lighting from a JLG boom lift. Special thanks to Derek Pasch, Staffing Specialist at Meisner Electric in Delray Beach, FL for the pictures. The fella on the left must have been on break. He appears to be asleep.
I wouldn't use a JLG lift or other type simply for safety. I use the bucket truck I operate. Will either half-hitch or feed the rope, which is attached to a winch and jib, through the top of pole.
To each his own.
BackInTheHabit is offline   Reply With Quote
Old 06-18-2008, 03:44 PM   #29
If those poles are down here, they are probably direct buried concrete and are drilled anywhere from 8' to 10' down into the ground.
We generally like to get them set while site work is going on because of the raw conditions and the fact that you have alot of dirt to remove later.
Because of the size and weight of the poles, unless you are able to set them perfectly square (not) you can end up with some misaligned heads.
I just find it easier to mount brackets and heads after the poles are set.
Generally, you can get the poles faster than the heads so you end up installing the heads from a lift or bucket truck.
Unless they are small poles, most everything in South Florida is direct burial concrete.
I don't even recall the last job that had poured bases with anchor bolts.
dezwitinc is offline   Reply With Quote
Need suggestions for installing parking lot receptacles personal General Electrical Discussion 13 10-13-2008 02:59 AM
domestic installation boots General Electrical Discussion 0 09-16-2007 03:24 PM
Billiard light installation? pip9ball General Electrical Discussion 1 08-30-2007 03:38 AM
Parking vs CT cabinet JohnJ0906 Services and Service Equipment 5 05-05-2007 06:13 AM
Parking lot light JohnJ0906 Code Violation Discussion 2 01-30-2007 07:18 PM
