"Permanent" shunts in place of meter??? - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Trade Topics > Linework
Like Tree6Likes
  • 4 Post By HackWork
  • 1 Post By wildleg
  • 1 Post By HackWork
Old 04-18-2017, 02:21 PM   #1
Rewards Points: 12
Default "Permanent" shunts in place of meter???
So, here’s a new one to me… I’ve got a customer who wants to change out the FP load center in her home. Outside, I noticed that the meter base on the home had a clear plastic closeout. The triplex from the house’s mast is running to a mast on the shop/garage. This is connected to a 100A breaker in the shop’s load center (see pics).
https://drive.google.com/open?id=0Bzh2H9yHZ0uMbHBDVGxOYjBWdFk
https://drive.google.com/open?id=0Bzh2H9yHZ0uMRDZCckVGU0VYLXc
Looking through the houses meter base’s clear plastic closeout reveals two “shunts” in place of the meter. The meter base is essentially a junction box.
Should I leave it alone and just replace the home’s panel?
cdw904 is offline   Reply With Quote
Old 04-18-2017, 02:23 PM   #2
Switched's Avatar
Rewards Points: 5,352
Is there no meter at all on the property? Sounds like someone is getting some free power!
Old 04-18-2017, 02:34 PM   #3
Profiteer
Rewards Points: 1,518
By your diagram, everything looks fine. At one time the house was connected direction to the utility company and the meter was in use. But now the house is connected to the shop, so the shop's meter is metering the house. The house no longer needs a meter so it is bypassed.
You can remove the meter if you want, or leave it the way it is.
Navyguy, Switched, splatz and 1 others like this.
Old 04-18-2017, 02:36 PM   #4
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 600
it is unlikely that anyone would perform this work without seeing the situation. That kind of puts you on the hook with the licensing board, if they decided to throw you under the bus (for whatever reason), regardless as to whether it is a gray area or not under the licensing or ethics rules.
For that reason, you have a problem.
cdw904 likes this.
Old 04-18-2017, 02:38 PM   #5
Rewards Points: 12
Sorry for my haste. I didn't indicate that there IS a meter on the shop. It is the only meter serving the property.
Old 04-18-2017, 02:39 PM   #6
Switched's Avatar
I clicked on the link and only saw the meter bars.....
Old 04-18-2017, 02:42 PM   #7
Profiteer
I see 2 links. The top one goes to a diagram.
Try this: https://drive.google.com/open?id=0Bz...HBDVGxOYjBWdFk
Switched likes this.
Old 04-18-2017, 02:47 PM   #8
Rewards Points: 12
I should slow down when I post or be more clear. My bad. One is photo of my sketch/diagram and the other is a photo of what the "shunts' look like.
Old 04-18-2017, 02:48 PM   #9
Switched's Avatar
I can see them. They were so close together that when I clicked on it it just kept opening the picture, not the drawing.
Old 04-18-2017, 02:52 PM   #10
RePhase277's Avatar
Rewards Points: 4,692
Since the house is fed from two phases of a three phase system, is it 208 or is it 240? And if it is 240, you're not changing anything except the house panel right?
You should use a full sized neutral as well.
Old 04-18-2017, 03:03 PM   #11
Rewards Points: 12
^^ Doh! That's what I meant. 240VAC. I deal with 3-Phase so seldom that I didn't think it out before I typed 220. I believe the house is fed 240VAC via Phase A and C. The neutral is there.
Correct, only changing the house panel.
I'm just evaluating the setup at this point. Jealous that this residential has 3-phase available!!!
New Cottage Meter : PG&E billing onilozay General Electrical Discussion 17 07-08-2016 01:42 PM
Meter tamper tags - lying all around meter..... backen General Electrical Discussion 1 05-30-2016 08:40 PM
Non contact and clamp meter suggestions? 120ToTheFingers Tools, Equipment and New Products 21 05-25-2016 09:50 PM
Multi Family Residential Meter Bank Questions TheLivingBubba General Electrical Discussion 7 01-20-2016 09:07 AM
