Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Trade Topics > Linework
Old 05-01-2009, 07:24 PM   #1
Default Phase Rotation
Hope someone can lead me in the right direction:
Is there a way to find phase rotation (abc, cba) on high voltage (4160V, 12.47kV) lines? I looked for a meter but it seems that this doesn't exist.
mikeb is offline   Reply With Quote
Old 05-01-2009, 07:30 PM   #2
Zog
Zog's Avatar
Look for "phasing sticks" very common, if you cant fond it I will post some links but google is your friend. Dont look for high voltage, you are looking for medium voltage.
Old 05-01-2009, 07:32 PM   #3
Rat Extraordinaire
Here ya go.
Old 05-01-2009, 07:39 PM   #4
I was looking at something similar. Megger makes hot sticks. I called the factory and they told me that they will NOT give me phase rotation direction.
Zog, can you give me some links?
480sparky: Thanks for the link! I'm looking into this product.
-Mike
Old 05-01-2009, 10:03 PM   #5
Zog
Zog's Avatar
-Mike
Like I said, no rotation ,eter that I know of, only phasing sticks. http://www.hubbellpowersystems.com/p.../TN0604_11.pdf
You can take your readings to ensure you have the same rotation betwens 2 points but you dont really know what direction the rotation is, thats why marking is so vital in MV systems.
Old 05-02-2009, 11:42 AM   #6
Zog: Can you explain the "same rotation" between two points?
This sounds like phasing sticks would tell me if from "a" to "b" is 120deg or 240deg from each other?
Old 05-02-2009, 02:15 PM   #7
Ideal brand, Model 61-361, meter available at Home Depot for about $125. Has phase rotation checking feature. Rugged little unit. I've owned one for three years. Of course this won't work in your application because of the 500 Volt rating, but for others it's a handy piece.
safspir is offline   Reply With Quote
Old 05-02-2009, 02:29 PM   #8
I am a RAT.
william1978's Avatar
I'm sure that tester is good up to 600v the op is asking for 4160v and 12470v.
Old 05-02-2009, 02:30 PM   #9
I am a RAT.
BTW welcome to the forum safspir and mikeb
Old 05-02-2009, 02:38 PM   #10
William,
You are right: low voltage is easy to handle. I need to read rotation direction at med voltage (our applications are mostly 4160, 11.5kV, 12.47kV, 13.2kV, 13.8kV, 14.4kV).
Any other ideas. I was actually looking for a small med voltage motor to read rotation. I really need to make this happen.
Old 05-02-2009, 03:02 PM   #11
For 4160 try http://www.hotektech.com/StST109G0102.htm
Old 05-02-2009, 03:16 PM   #12
I am a RAT.
There ya go.
Old 05-02-2009, 03:59 PM   #13
Zog
Zog's Avatar
I mean you can tell if your 2 sources are both rotating the same direction, but not what direction they are rotating. If A1-A2=oV, B1-B2=oV, C1-C2=oV your rotations are the same, if you have voltages they are not (Or you possibly have a phase shift occuring).
But it looks like someone else found just what you are looking for, I may order one myself.
Old 05-03-2009, 11:30 PM   #14
Go to nearest PT/metering/service point, find the rotation with a regular rotation meter, and ride the line to where you are looking at. For a service, just install the bank and figure the rotation afterwards.
I guess the meter in #11 would be handy, but I've never had a situation where I needed one.
What is your application, if I may ask?
mivey is offline   Reply With Quote
Old 05-04-2009, 11:49 AM   #15
Downstream from some backup generators.
Old 05-17-2009, 12:06 AM   #16
I am currently working on a website for, and shortly will be going into business with a gentleman who represents several lines of equipment for every situation. Basically, and in his words, "There is absolutely nothing that we cannot test".
I assure you, he can help! I don't know if I am allowed on these forums to post contact information - if you PM me I can get you the direct contact information that you need. I would highly recommend contacting him before you jump in and buy something that you may not be able to use for your application.
www.faultlocating.com
Faultfinder1 is offline   Reply With Quote
Old 05-17-2009, 12:09 AM   #17
I can't help with the rotation thingy... but if this is a blender it must make one helluva mudslide...
Old 05-18-2009, 11:18 AM   #18
Hm, an Oscilloscope and a couple of High Voltage Probes?
warnerms is offline   Reply With Quote
Old 05-18-2009, 11:57 AM   #19
While that would be workable if you had PTs available it is not typically the method of choice.
I void warranty's
Old 05-18-2009, 12:42 PM   #20
Thanks for the hlep everyone. We are going to run through a piece of switchgear that has pt's and ct's that I can use as a test point.
rotation meter mattsilkwood Tools, Equipment and New Products 12 03-29-2009 04:05 PM
single phase to three phase escinola General Electrical Discussion 6 02-22-2009 02:05 PM
Line Phase rotation bobelectric Linework 5 07-01-2008 08:31 PM
three phase to single phase convertion. brick General Electrical Discussion 2 07-29-2007 08:55 PM
Phase rotation meters MDShunk Tools, Equipment and New Products 2 03-11-2007 09:51 PM
