Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Trade Topics > Linework
Old 06-03-2009, 11:52 AM   #21
Wink
Originally Posted by Zog View Post
Look for "phasing sticks" very common, if you cant fond it I will post some links but google is your friend. Dont look for high voltage, you are looking for medium voltage.
Go to bierermeters.com, they have a meter called a PDSeries 25kV or 50kV model that will phase sequence anything from 208Volts to 50kV and up if you add extension resistors.
JoeHVD is offline   Reply With Quote
Old 06-03-2009, 12:05 PM   #22
Smile
If you do any high voltage rotation get either a PD25 or PD50 meter from Bierer Meters. These meters will phase anything from 208 volts to 50kV. If you need to go higher than 50kV add extension resistors and you got it.
Old 07-07-2009, 03:04 PM   #23
PD800W from bierermeters.com, the best there is!!!
Old 07-07-2009, 07:16 PM   #24
Chris Kennedy's Avatar
Call me kookie, but why not check the secondaries of the LV transformer/s it serves?
Bulldozers and Dirt
Old 07-07-2009, 08:54 PM   #25
If you know what phase is what abc bca and cab are all clock wise rotation.
powerlineman78 is offline   Reply With Quote
Old 07-08-2009, 08:30 AM   #26
You can. You can check the low voltage side (anything 120/208V and above) all the way to 765kV. What I am saying is you dont have to waste your time going to a low voltage side.
Old 07-08-2009, 08:43 AM   #27
"Rotation" is a bad word anyway, "sequence" is better, it keeps people from arguing. If your in the field and nothing is labled a,b or c, the meter (PD800W) will tell you your sequence with LED's plus how many degrees of separation (LCD).
rotation meter mattsilkwood Tools, Equipment and New Products 12 03-29-2009 04:05 PM
single phase to three phase escinola General Electrical Discussion 6 02-22-2009 02:05 PM
Line Phase rotation bobelectric Linework 5 07-01-2008 08:31 PM
three phase to single phase convertion. brick General Electrical Discussion 2 07-29-2007 08:55 PM
Phase rotation meters MDShunk Tools, Equipment and New Products 2 03-11-2007 09:51 PM
