Old 06-04-2012, 06:38 PM   #1
Default 5 way with occupancy sensors
Have a situation where there is 4 switches controlling office hallway lighting. I'm truly behind in the whole OS thing and was looking for some advice. This hallway is pretty much a big square.
Old 06-04-2012, 07:11 PM   #2
Chief Electron Relocator
I can design anything you want, as long as you include a big enough check with your requirements.
Old 06-04-2012, 07:24 PM   #3
Will this do?
The Following User Says Thank You to GEORGE D For This Useful Post:
The_Modifier (06-05-2012)
Old 06-04-2012, 09:06 PM   #4
Can't Remember
I have done stairwells in apt buildings that had 3 or 4 ways at each landing for lighting. I replaced the switches with sensors at each doorway. Rewired it so the white was the neutral. The black fed the line all the way through and the red was the load all the way through. Sometimes overhead is the way to go. Leviton has wireless solutions that look tempting as well.
Old 06-04-2012, 09:40 PM   #5
Grabsumbuds's Avatar
Interrupt the switch leg with a low voltage power pack and you can put I believe 6 sensors off the one power pack
Grabsumbuds is offline   Reply With Quote
Old 06-04-2012, 10:16 PM   #6
watt stopper low voltage occ sensors mounted in the ceiling work the best for what you got. wire the 4 ways through if you're worried about tampering. actually id probably just wire all the switches through
D-Bo is offline   Reply With Quote
Old 06-04-2012, 10:41 PM   #7
After researching I could not find a 4 way capable in wall vacancy sensor rated 277 volts, however, wattstopper does make one 120 volts. The problem is, customer doesn't want to change or add any wiring , basically replace switches.
Old 06-04-2012, 11:23 PM   #8
yeah you might have trouble finding an in wall device style for that. i didnt know you were looking for a switch style occ sensor. if the ceiling is dropped i would reccommend putting in a ceiling mount occupancy sensor with low voltage contacts
Old 06-05-2012, 07:31 AM   #9
Can't Remember
I don't know that you need anything special. The ones I used weren't. I just paralleled everything. The last sensor to see anything keeps the light on till it times out. I tied all like colors together in the boxes. Use the blacks for line, the reds for load and whites for neutral. Seems to work well.
Old 06-05-2012, 08:17 AM   #10
Yeah I'm gonna call wattstopper today and see if they have suggestions.
Old 06-05-2012, 10:53 PM   #11
You can wire standard single pole sensors in parallel to accomplish this, but you cannot force the lights 'off' without going to every switch
Techy is online now   Reply With Quote
Old 06-05-2012, 10:56 PM   #12
i guess itd be prudent to ask if the switch locations are in a location that will give them line of sight for movement in the hallway i.e. not behind a door, around a corner, or in a vestibule
Old 06-05-2012, 11:50 PM   #13
This hallway is shaped kinda like a big square, nothing blocking either of 4 switches. Talked to wattstoppet today and did give me a model # for 277 volt multiway wall switch- PW103N- if memory serves me right. Only problem is, its rated for maximum 1200 watt ballast load and I believe there's more than that in hallway. Might need to incorporate contactor if they approve it.
Old 06-08-2012, 11:12 PM   #14
mbednarik's Avatar
sensor switch wsd. Wall switch replacement. 120-277vac. Hook them all up in parallel. BTW they do not require a neutral.
Occupancy sensors mikewardjr General Electrical Discussion 15 10-07-2011 10:40 PM
multiple occupancy sensors ikeberg9 Commercial Electrical Forum 8 05-01-2010 12:40 AM
HID occupancy sensors with T8's flyindawg Commercial Electrical Forum 19 04-29-2010 01:30 PM
Classroom occupancy sensors ElectricBill Lighting Design 5 01-06-2010 01:39 AM
Wall Mounted Occupancy Sensors In Bathroom crazyboy General Electrical Discussion 13 07-19-2009 11:22 AM
