Old 02-27-2008, 09:47 AM   #1
Wyome
Default Easy lighting fixtures to work with
We just finished the trim on a 4000sf house. The owner provided the light fixtures that were recommended by a lighting designer. Nothing high end but certainly not the cheapest picks from HD either. The recessed lights and 2 preformed tracks 4' long and the outside flood lights were all Progress. Kichler for the majority of the incandescent fixtures. Lithonia for the fluorescent. Haven't done the under cabinet ones yet as the cabinets are not installed. Even though most of this stuff was made in China it was all surprisingly easy to install. We didn't have problems with different size screws and parts that usually seem to plague the fixture hanging stage. I might even change my normal Halo cans to Progress and start recommending Kichler fixtures.
Old 02-27-2008, 12:13 PM   #2
Semi-Retired
BryanMD's Avatar
As you have learned, the phrase "you get what you pay for" actually works wrt light fixtures.
Even the best can have a learning curve but that curve is a LOT shorter.
November 2011: Relocated to Winston-Salem.
May have to change the username suffix.
Old 02-27-2008, 04:51 PM   #3
3rd Generation
MF Dagger's Avatar
I've found that the expensive fixtures from the high end stores are the ones that are a supreme pain in the ass. Murray Feiss fixtures can drive me absolutely nuts some days.
MF Dagger is offline   Reply With Quote
Old 02-27-2008, 06:51 PM   #4
gilbequick's Avatar
In my experience the more funky the light the more of a PITA it is. Most big box store lights are worse than lighting company supplied lights, especially the under cabinet lights. I don't have too many problems with Murray Feiss lights.
Old 02-29-2008, 07:04 PM   #5
JohnJ0906's Avatar
I agree absolutely. I did some imported fixtures years back (Italy I think) and I would have liked to pull my hair out. Butt-ugly too....
John from Baltimore
"One day at a Time"
Old 02-29-2008, 08:30 PM   #6
I hate installing european fixtures. You almost always have to modify them to fit on our boxes. A real pain in the .
a-bulb is offline   Reply With Quote
Old 03-04-2008, 09:20 PM   #7
100% Gungho Marine Parent
SEMPER FI's Avatar
I had to hang a $10,000.00 chandelier without all the parts one time. You talk about being paranoid.
OOHRAH
SEMPER FI
SEMPER FI is offline   Reply With Quote
Old 03-23-2008, 08:02 PM   #8
our lighting design houses are mainly dreamscapes. not sure of the cost but they can be a pain in the ass because you have to build them. another house we did used juno aculox cans. not a big fan of either. both had some problems with transformers coming loose. much rather bang up some 5" halo's
gcleary47 is offline   Reply With Quote
Old 03-24-2008, 08:29 PM   #9
cdnelectrician's Avatar
I think we can all agree on one thing...we all HATE installing fixtures!
Old 03-24-2008, 09:37 PM   #10
goose134's Avatar
I've always maintained (with a few exceptions) the more a fixture costs, the harder it will be to hang. This relationship is inverse for fans.
Old 03-24-2008, 09:47 PM   #11
Semi-Retired
BryanMD's Avatar
I'll stand by earlier post.
Brands like Kichler, Progress, and Lithonia (which the OP cited) are easier to work with than the cheaper off brand crap is.
That said, cndelectrician has it right too
"I think we can all agree on one thing...we all HATE installing fixtures!"
Old 04-23-2008, 02:38 AM   #12
Progress also has LED fixtures that look better than I've seen yet, although we have not installed them yet.
LeeB is offline   Reply With Quote
Replacing Recessed Lighting Fixtures Reseman Lighting Design 11 06-08-2011 10:01 PM
Easy Cheap Estimating Program davys Tools, Equipment and New Products 7 03-13-2008 12:11 PM
easy cert elite davidparry1 General Electrical Discussion 1 01-25-2008 02:14 AM
Adding New circut.... Easy Question Live2Die420 General Electrical Discussion 2 06-09-2007 11:20 AM
Easy way to .... calimurray General Electrical Discussion 4 05-06-2007 01:00 PM
