Old 10-05-2009, 10:05 AM   #1
Default Electrical raceways
Looking for a surface mounted electrical raceway similar to track lighting. This system allows you to mount a flex track on the wall and add snap on outlets. Siemens Canada manufacturers this track as a "electrostrip" #315W with Recepticals 3R3W, the issue is they are CSA listed only, not UL and I'm trying to locate a UL listed version. Graybar sold a similar product under the name "electrasource" until last year when it was discontinued.
The question is if anyone knows of a like UL listed product.
Thank you,
tdfidx
tdfidx is offline   Reply With Quote
Old 10-05-2009, 10:23 AM   #2
Bulldog lighting track. Siemens has the fittings and such in their line now (pretty sure it's siemens).
-Marc, ABC, XYZ, PhD, 1-2-3
Old 10-05-2009, 11:51 AM   #3
Thank you. I will work to see if I can locate them. I am only finding industrial lighting (lights stands) at the moment. Will continue to look.
Old 10-06-2009, 10:41 PM   #4
Floppy Member
+ standard track lighting.
idontknow is offline   Reply With Quote
residental service conductors in raceways I Conduit General Electrical Discussion 45 06-19-2009 09:42 AM
Electrical connection question --Over-head electrical works SarahJennifer UK Electrical Forum 6 03-02-2009 11:32 AM
National Electrical Code: Analysis & Explanation of the Underwriters' Electrical Code Joe Tedesco Vintage Electrical 3 12-29-2007 12:47 AM
230.53 Raceways to Drain Joe Tedesco NEC Code Forum 2 04-20-2007 05:59 PM
