Old 06-02-2009, 10:54 AM   #1
Default Emergency Lighting
Is there a watts per square foot calculation for fiqureing emergency lighting loads? I am trying to size a life safety panel for future EM lighting.
dawgs is offline   Reply With Quote
Old 06-02-2009, 02:32 PM   #2
for what kind of building?
hospital- 2 volt-amps psqft
schools- 3
office buildings- 3 1/2
sparkyboys is offline   Reply With Quote
Old 06-02-2009, 02:34 PM   #3
Seen your member
schools- 3
Those are general lighting loads used for calculations. They aren't for designing egress lighting.
Life Safety Code. Section 7.8.1.3 of NFPA 101 states, “The floors and other walking surfaces within an exit and within portions of the exit access and exit discharge designated in 7.8.1.1 shall be illuminated to values of at least 1 footcandle measured at the floor.”
Section 7.9.2.1, “Performance of Systems,” dictates the following: “Emergency illumination shall be provided for a period of 1½ hours in the event of failure of normal lighting. Emergency lighting facilities shall be arranged to provide initial illumination that is at least an average of 1 footcandle and a minimum at any point of 0.1 footcandle measured along the path of egress at floor level. Illumination levels may decline to 0.6 footcandles average and a minimum at any point of 0.06 footcandles at the end of the emergency illumination lighting time duration. A maximum to minimum illumination uniformity ratio of 40-to-1 shall not be exceeded.”
Uniform Building Code. Section 1003.2.9.1 of the UBC states, “Any time a building is occupied, the means of egress shall be illuminated at an intensity of not less than 1 footcandle at floor level.”
International Building Code. Section 1006.2, Illumination Level, of the IBC states, “The means of egress illumination level shall not be less than 1 footcandle at the floor level.”
Section 1006.4, Performance of Systems, states: “Emergency lighting facilities shall be arranged to provide initial illumination that is at least an average of 1 footcandle and a minimum of any point of 0.1 footcandles measured along the path of egress at floor level.”
Source.
Old 06-02-2009, 03:30 PM   #4
lectricboy's Avatar
Source.
This is what I was always taught.
lectricboy is offline   Reply With Quote
Emergency Calls brian john Business, Marketing, and Sales 14 11-19-2008 10:42 AM
Contact & Emergency #'s BryanMD Business, Marketing, and Sales 8 05-20-2008 05:32 AM
Emergency lights Speedy Petey General Electrical Discussion 11 03-29-2008 03:21 PM
Hello and emergency lightening terayon General Electrical Discussion 21 02-03-2008 11:18 PM
emergency call out frank General Electrical Discussion 0 04-20-2007 08:51 AM
