First Lotus LED install. - Electrician Talk - Professional Electrical Contractors Forum
Like Tree15Likes
Old 10-17-2016, 08:22 PM   #1
EC & CI
Kaffeene's Avatar
Rewards Points: 574
Default First Lotus LED install.
So after reading about the Lotus LED's here I had a job that I wanted to put 4" recessed lighting in all the bedrooms on a second floor with insulation
The ceiling joists are only 2x6 and there is hard duct work & an air handler laying on top of the joists where many of my recessed lighting would go.
I just decided it might be easier to try out the Lotus. I found a place near me that I could order from and got the 4" round slim 3000K and put 16 of them in.
I like them. I bit more money than buying a can and LED trim, but I think the installation went just a little quicker and they look good.
I used my new Hole Pro X https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 to make the 16 holes and what a big help that was.
I'm kicking myself for not getting one a long time ago.
I don't think I will be using the Lotus all the time, however they have their uses and I'm satisfied with the installation.
HackWork and PlugsAndLights like this.
Kaffeene is offline   Reply With Quote
Old 10-17-2016, 08:27 PM   #2
Going_Commando's Avatar
Rewards Points: 296
I have a house I am roughing right now that the customer wants cans, but there is a TJI in the way in a hallway. I am pitching lotus lights, and will most likely give them a go.
Old 10-17-2016, 08:37 PM   #3
Click Here
Rewards Points: 1,410
Did you have any that ended up being right under a joist?
How did the 3000K look? People often prefer 2700K in bedrooms.
Old 10-17-2016, 08:42 PM   #4
Rewards Points: 8,162
For the 4", you have to put them a little off centre from the joist to fit the driver through the hole. I use mostly 3000K with no issues.
Old 10-18-2016, 07:18 AM   #5
Yeah Toast!!
Roger123's Avatar
Rewards Points: 1,228
Does the driver just sit on top of the finish ceiling?
Old 10-18-2016, 07:32 AM   #6
Yes. Although the drivers are supposed to be good in thermal insulation, I'm suspicious. I have a callback this week to look at two burnouts. They're Lotus knock offs, though, not the real thing.
Roger123 (10-18-2016)
Old 10-18-2016, 09:24 PM   #7
EC & CI
Kaffeene's Avatar
Rewards Points: 574
No I measured everything and used a beam finder and it all worked out in open bays.
The 3000K looked pretty good. I noticed they ramp up a little when you first turn on the dimmer switch. I used a Lutron Diva CL dimmer.
I usually like to go for 2700K, but a few customers have wanted the brighter white. This customer was happy with the color.
Oh and I purchased these from Grant in Hackensack.
The Following User Says Thank You to Kaffeene For This Useful Post:
HackWork (10-18-2016)
Old 10-18-2016, 09:32 PM   #8
Click Here
I am curious why you used the beam finder, it seems like you were trying to avoid the joists. I thought the whole point of using the slim models was so that you can put them anywhere, even under the joists?
I'm just curious is all.
Oh and does the Grant in Hackensack always stock them? Cause I just asked at the Grant in Belleville and they don't have any in stock nor could he give me a price for them
Old 10-18-2016, 10:46 PM   #9
Big nosed attic troll
Majewski's Avatar
Rewards Points: 1,696
I can't seem to find these anywhere local, only online.
Old 10-19-2016, 09:40 AM   #10
EC & CI
Kaffeene's Avatar
Rewards Points: 574
The slim model is an 12W model that is 1" thick, this is what I used. The other size is the ultra thin model that is 9W and a 1/2" thick.
I had to order from Grant, took about a week and are $50.70 for this model. Cooper Electric also has them for order, but the Grant price was slightly better.
HackWork (10-19-2016)
Old 10-19-2016, 10:48 AM   #11
Click Here
Gotcha. Thanks.
If I ever install Lotus, I think I am going to use the ultra slim and not worry about joists at all.
Majewski likes this.
Old 10-19-2016, 12:47 PM   #12
Gotcha. Thanks.
9W have lots of punch for an 8' ceiling.
Old 10-30-2016, 08:53 PM   #13
NDC
NDC's Avatar
Rewards Points: 434
I will never never push to install cans again.
I found a really good quality Lotus knock off for $20 CAD.
12 Watt, 3000K or 5000K 780 Lumens, 5 year warranty, ETL approved, energy star and IC rated.
The Following 2 Users Say Thank You to NDC For This Useful Post:
splatz (10-30-2016), telsa (11-27-2016)
Old 10-30-2016, 09:03 PM   #14
Click Here
You Canadians get all the good stuff.
The_Modifier, Majewski and Max C. like this.
Old 10-30-2016, 10:11 PM   #15
Majewski's Avatar
I'm super jelly.
Old 10-31-2016, 05:18 AM   #16
Rewards Points: 118
Which brand if I may ask? Also, what are the available finishes?
Max C. is offline   Reply With Quote
Old 10-31-2016, 08:49 AM   #17
NDC
NDC's Avatar
Rewards Points: 434
I dunno some generic chinese name like dayslim or something. They come in white only. 3000k and 5000k. A 6" is also available.
I built a small box with a dimmer that displays the two options they can choose from.
Give a customer too many choices and you're asking for problems. I'm an electrician not a mobile lighting showroom.
If they want something fancier I will go with a Liteline or Lotus and charge a premium for it.
The Following User Says Thank You to NDC For This Useful Post:
zac (11-28-2016)
Old 10-31-2016, 09:00 AM   #18
Click Here
This is odd. It's a bit harder to find on their website, but Lotus makes an "economy" line. But it's odd because it doesn't seem economy. It's the super slim model but the wattage is almost as high as the thicker one.
9w Super Thin: https://www.lotusledlights.com/reces.../9w-super-thin
11w Economy Super Thin: https://www.lotusledlights.com/reces...und-super-thin
12w Full Size: https://www.lotusledlights.com/reces...-slim-standard
So why is the 11w Super Thin the economy model? It seems like it should be the premium model since it's both super thin and higher wattage. No need for the thicker model.
Old 10-31-2016, 09:13 AM   #19
NDC
NDC's Avatar
Rewards Points: 434
Longer resi warranty on their 12W and it looks like it has a better heatsink. I think the 12W or original has a larger OD last time I put one in I had to buy a larger hole saw. I have only installed Lotus 12W. I'm sure its just built better overall.
Old 10-31-2016, 09:16 AM   #20
I never noticed that. I dunno. I always use the 9's (except on one occasion where I had a higher ceiling).
Help with this pool heater install NDC Canadian Electrical Code Forum 9 08-06-2016 12:32 AM
What would you install in this application? carryyourbooks General Electrical Discussion 12 06-29-2016 03:40 PM
when would you say it is a good idea to install a capacitor bank anylettuce Services and Service Equipment 4 06-01-2016 04:50 PM
