Old 10-06-2009, 06:10 PM   #1
Default fluorescent lights
Hi guys and girls
I am installing a fluorescent light above the door in a storage closet ( no clothing), according to artical 410.24a I do not have to install a fixture box is this correct, just the romex and a connector going into the back of the 24in fixture. I am doing the rough wiring job for a basement.
Or should I just go with a reccessed light with a lens cover?
Thanks
artisanelec is offline   Reply With Quote
Old 10-06-2009, 06:16 PM   #2
Hack and Rat all in one
Peter D's Avatar
Assuming this is a strip fluorescent or undercabinet fluorescent, yes, it can be directly wired without a box.
I prefer a fluorescent over recessed as with the shower or fully enclosed trims you are limited to a 40 watt bulb in most cases. A fluorescent will be much brighter.
Old 10-06-2009, 06:32 PM   #3
I always use a fluorescent strip above the closet door trim unless there's a special request otherwise. I use a strip as long as the door opening for best results.
If you run a 3-wire to that closet light, it's also a good place to mount the chime transformer on the one end.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 10-06-2009, 06:43 PM   #4
Peter D's Avatar
Or you could just mount in on the panel in the basment like most normal people do.
Good tip though.
Old 10-06-2009, 06:54 PM   #5
Good tip though.
He's doing a finished basement. That panel is likely to end up flush. Hard to say. It's a good tip for apartments, condos, homes without basements, and homes with highly finished basements. Sometimes there's just no "good" place for the chime transformer, and on the end of one of the closet lights is the next best place that nobody will ever notice.
Old 10-06-2009, 06:55 PM   #6
Thank you for the fast response,this is a great site with great information. What did we do 15 years ago with out the internet.
keep them coming...................
Old 10-06-2009, 06:56 PM   #7
Rat Extraordinaire
I just stick the db trans on the box I install for the furnace switch. That will never get covered up.
Old 10-06-2009, 06:58 PM   #8
The transformer is in the ceiling, it will be a drop ceiling 6 inches below upper joists.
Thanks.
Old 10-06-2009, 07:00 PM   #9
Thanks.
That's cool. I really hate to see a drop ceiling in a basement remodel (for aestetic's sake), but for functionality, it can't be beat.
Old 10-06-2009, 07:04 PM   #10
Hey it's my basement.
Well it's cheaper and I am sure I will be adding lights and who knows what else in the futher.
Old 10-06-2009, 07:06 PM   #11
Awesome. So... you'll be putting in some T8 parabolics?
Old 10-06-2009, 07:15 PM   #12
No just some cheap reccessed lights.
Old 10-06-2009, 07:40 PM   #13
Wait I have another question, I will have 4 dimmers for all the lights I am thinking of using two 2 gang boxes instead of one four gang box. I think this will allow more room ( dimmers take up alot of space ) in the boxes, plus dimmers give off lots of heat.
ANY COMMENTS
Old 10-06-2009, 08:02 PM   #14
JohnJ0906's Avatar
ANY COMMENTS
You would only have to remove one side of each dimmer that way, instead of both sides of the 2 inner dimmers if you used a 4 gang, so I think that would be a good idea.
John from Baltimore
"One day at a Time"
Old 10-06-2009, 09:28 PM   #15
Rat Bastard
NolaTigaBait's Avatar
That would be the last place I looked for a transformer. You come up with some stuff.
Old 10-06-2009, 10:53 PM   #16
Floppy Member
When I worked for another company years ago they would mount a 3 gang box either in the garage or the utility room. Come time for the trimout they would take a LV divider, mount the transfomer to it and slide it in the box. The thoery was to isolate the low voltage from the high voltage and hide everything behind a 3 gang blank plate. Nowadays I just mount the transformer to the outside of the panel. Sooo much quicker and nobody notices.
idontknow is offline   Reply With Quote
Old 10-07-2009, 03:47 AM   #17
Master RAT!!!
Shado's Avatar
Ditto...same way here, or at least in the mechanical room.
- Dave ........
"Beware of the Rat....he has no Master...he works how & where he wants...."
Shado is online now   Reply With Quote
Old 10-07-2009, 09:11 PM   #18
zen
electrican
zen's Avatar
we usually set a 1g box below the heat unit switch and getting power from the heat unit circut.take a handy box cover with a half in knock out in the center or make my own with a unibit then fasten the trans. to the h.b. cover with a lock ring connect the power ,then screw the plate on.
if i knew half as much as i thought i knew i might know something
zen is online now   Reply With Quote
Old 10-07-2009, 09:13 PM   #19
Peter D's Avatar
It's as easy as 1-2-3.
Old 10-07-2009, 09:26 PM   #20
Rat Extraordinaire
Gee, I wonder where Peter learned to count.........
2 Pin Compact Fluorescent Lights Simux Lighting Design 15 10-11-2009 12:21 PM
fluorescent ballasts BuzzKill General Electrical Discussion 11 04-28-2009 02:48 AM
Recommendation: AC lights off of Inverter, or DC rechargeable lights mhl General Electrical Discussion 4 09-30-2008 07:27 AM
Fluorescent lighting NoFinway General Electrical Discussion 2 06-11-2008 08:51 PM
Fluorescent Lighting jerryd General Electrical Discussion 4 11-11-2007 07:50 PM
