G24 2-pin to G24 LED problem - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By telsa
Old 12-17-2016, 02:52 PM   #1
Default G24 2-pin to G24 LED problem
Good day all,
I'm a maintenance tech for the Postal service and I'm having an odd problem trying to retrofit new G24 LED bulbs into a 2 bulb G24 fixture in a lobby. The new bulbs fit the sockets just fine and work with the OLD ballast setup flawlessly. The old ballasts are Robertson HP28P's... Specs can be found here, http://www.ballastshop.com/media/import/pdf/r_HP28P.pdf
The problem arose when I had to remove two dead ballasts from one of the fixtures. I replaced the (2) Robertson ballasts with (1) Philips Advance H2Q26TPBLSM ballast, specs can be found here, https://www.1000bulbs.com/product/57...FRyewAodMGoGGw ...
I have tried various wiring methods (shunted/ non shunted/ direct 120v line voltage) and no matter what I do the new LED g24's burn up and stop working within a few minutes of applied power. The LED's come on nice and bright with the new ballast but after a minute or so they begin to smoke and sizzle eventually burning out and failing.
I must be missing something in translation here so I'm hoping you guys can get me back up and running. Thanks a ton!
RobbySals is offline   Reply With Quote
Old 12-17-2016, 03:45 PM   #2
Rewards Points: 13,588
Originally Posted by RobbySals View Post
Good day all,
You're cooking them with excess heat.
You need to find a compatible driver.
Kyrton likes this.
Old 12-17-2016, 06:37 PM   #3
NRA Member
backstay's Avatar
Rewards Points: 790
The old ballast is for a two pin, the new one is a four pin. I'd say it's the wrong ballast.
Old 01-02-2017, 02:01 PM   #4
I agree with backstay, Check and make sure the ballasts are compatible with the new LED lamps. Most of the time the LEDs will come with a spec sheet listing their compatible ballasts. if they didn't shoot an email off to the manufacturer.
Samtheman is offline   Reply With Quote
Staple problem trungtran4177 Electrician Apprentice Forum 47 01-14-2017 07:45 PM
how you guys trouble shooting the loose connection problem? mike883 General Electrical Discussion 87 12-05-2016 10:47 PM
Problem with stereo equipment ProjectSunlight Residential Electrical Forum 4 09-06-2016 09:05 PM
Av hum problem Anathera General Electrical Discussion 20 04-08-2016 06:49 PM
Got a problem Flytyingyaker Residential Electrical Forum 11 01-20-2016 09:02 PM
