Old 04-11-2012, 04:47 PM   #1
Default HID Pulse Start Ballast Failure
HELP!
1) what causes pulse start ballasts to fail (w/o the lamp)?
2) how long does the pulse start ballast take to wear out/fail?
lighting123 is offline   Reply With Quote
Old 04-11-2012, 10:42 PM   #2
What causes ballasts to fail? Use and time.
How long? God, I bet they last 20 years some of them.
kaboler is offline   Reply With Quote
Old 04-11-2012, 11:08 PM   #3
erics37's Avatar
Originally Posted by lighting123 View Post
HELP!
If you take the lamp out the igniter will sit there trying to pulse-start the atmosphere and burn itself out. That's why you gotta disable it or put a capacitor across your meter leads if you're testing open circuit voltage on the socket.
Old 04-11-2012, 11:22 PM   #4
Heavily Armed Member
HARRY304E's Avatar
HELP!
It is usually two lamp cycles that will do it ,If you allow the lamps to completely burn out but if you change them before they reach the end of life the ballasts will last longer.
When you have to change a ballast change it as a kit with a lamp the matches the ANSI rating.........
Welcome to the forum enjoy the ride....
Old 04-24-2012, 02:36 AM   #5
Light Emitting Decoration
Electric_Light's Avatar
HELP!
1.) The ballast usually doesn't. The igniter. The igniter is only activated until the lamp is struck. But missing lamp will cause the igniter to continuously retry. The igniter can be made fail safe by including duration/attempts limit into each unit, but that would increase cost. The ballast doesn't need to be replaced if the external failed.
2.) That depends on operating temperature. Excess temperature will reduce life. This is not an easy question to answer. Core and coil ballasts aren't as likely to have sudden failure from surge and spikes like electronic ballasts.
Electric_Light is offline   Reply With Quote
Flourscent luminaire ballast failure frenchelectrican General Electrical Discussion 17 03-21-2012 08:13 PM
Std 400W lamp in a pulse-start fixture amptech General Electrical Discussion 11 10-03-2011 02:03 PM
Pulse-start Metal Halide failure kbsparky General Electrical Discussion 12 01-06-2011 12:23 AM
Pulse Start MH Light fixture Question KEI Lighting Design 2 06-24-2009 10:12 PM
Pulse or Probe start M.H. lighting bobelectric Lighting Design 4 03-31-2009 03:15 PM
