Old 10-23-2009, 07:48 PM   #1
Ohmslawman's Avatar
Default I ndication light
I have a customer that wants to install some security lights on her house.She wants to have some kind of light that goes off in her house to let her know what light has turned on.Does anyone have an idea on how would be the best way to do this?
Ohmslawman is offline   Reply With Quote
Old 10-23-2009, 08:09 PM   #2
Originally Posted by Ohmslawman View Post
I have a customer that wants to install some security lights on her house.She wants to have some kind of light that goes off in her house to let her know what light has turned on.Does anyone have an idea on how would be the best way to do this? I have installed plenty of security lights but have never had a request for a setup like the one mentioned.
Are you saying that she wants an indicator light for each security light, for example 4 indicator lights for 4 security lights and she wants to know which security light is activated?
2005 NEC
wingz is offline   Reply With Quote
Old 10-23-2009, 08:22 PM   #3
captkirk's Avatar
Your gonna need to run a three wire to to each light. Use the red to turn on your indicator light which is wired to the lights.It will only trurn on the indicator light when the motion sensor sends power to it. It will remain lit as long as the flood is lit. You can use leds cut into a blank plate or some how install leds in the same plate the switches are in. Its not that hard but probably more trouble than its worth.
captkirk is online now   Reply With Quote
Old 10-23-2009, 08:36 PM   #4
Ohmslawman's Avatar
Thanks for the replies .Now to figure out what to buy for the led board .At least the weather is cooling off for attic work.
Old 10-23-2009, 08:50 PM   #5
captkirk's Avatar
The black from the three wire obviously goes to the black on the motion and the red from your three wire connects to the lights( which is also connected to the red from the motion). Im pretty sure you get some small leds that would fit on the same plate as the switch plate (it you drill out a hole for them but im pretty sure you will be violating 110.3. But in a sense dont we all violate that one every once in a while...
New Outside Light Fixture; light flickers chev General Electrical Discussion 3 03-25-2009 09:29 PM
Sky Light 480sparky Workplace Safety 9 05-04-2008 12:03 AM
Old Light Switch DeeJayy Vintage Electrical 21 03-24-2008 05:51 PM
BBQ light heel600 General Electrical Discussion 14 03-22-2008 12:50 PM
60 bucks for a can light Bkessler General Electrical Discussion 19 12-18-2007 01:07 AM
