Old 10-13-2009, 11:12 AM   #1
Lighting Contractor
Lighting Retro's Avatar
Default Installing fuses in Metal Halide fixtures?
Ok, I had a new request today, and curious to know if any of you guys have any input on this one.
Here is the language of the request:
Please install fuses before the ballasts. All 88 fixtures may not require a fuse but all 88 fixtures will need inspected for either installation of new fuse or confirmation of pre-existing fuse. Where fuse is existing, no action will be required. Please identify and quote appropriate fuse.
This is for a relamp project that is moving from 175W MH lamps to 150W Pulse Start. No ballast change is required, but I have to say I have no idea on the fuse issue. I don't have details, but I'm assuming some dirty electricity is causing premature failures and high maintenance costs? So now a fuse will just be popped instead of a lamp or ballast?
Any suggestions on type of fuse, pics of what they look like, links, etc would be appreciated. I have requested more info, but these type of bids come to us without a ton of details sometimes. Out of state, so need to make sure we get it right the first time. Thanks.
Lighting Retro is offline   Reply With Quote
Old 10-14-2009, 07:31 AM   #2
Wouldn't you just use a simple in-line fuse? That's what it sounds like they are asking for.
http://www.galco.com/scripts/cgiip.e...&pnum=HHT-BUSS
Ima Hack is offline   Reply With Quote
Old 10-14-2009, 11:36 AM   #3
Lighting Contractor
Apparently this is what is in there:
Yeah, not a biggie. Just had not had a call for these before. We rarely do any repair on what we consider "legacy" equipment, so this was simply something we had not had a request for. Thanks.
Tags
fuses, metal halide, pulse start
277 Metal Halide light to work indoors mpdegn Lighting Design 3 02-13-2009 03:45 PM
277 Metal Halide light to work indoors mpdegn Lighting Design 5 02-13-2009 03:22 PM
Lighting Metal Halide jhanth General Electrical Discussion 7 05-26-2008 08:46 PM
The saving fuses m.s.j General Electrical Discussion 0 07-24-2007 04:47 AM
Metal Halide fixture InControl General Electrical Discussion 8 04-16-2007 10:34 PM
