LED bulb surface temperature - Electrician Talk - Professional Electrical Contractors Forum
Like Tree22Likes
Old 12-10-2016, 09:53 AM   #1
wcord's Avatar
Rewards Points: 602
Default LED bulb surface temperature
Had a customer ask an interesting question.
If the fixture is rated for, lets say, a 60 watt bulb, could he use a 13 watt LED which is the equivalent of a 100 watt incandescent?
We know the restriction on the wattage is due to the heat radiating off the incandescent. And the heat is primarily centered around the glass.
Whereas, the heat off the LED is centered on the heat sink, not as large of an area as the glass.
Anyone have any information as to whether installing a larger LED would be a fire hazard?
Be careful what you wish for, you just may get it.
Old 12-10-2016, 11:12 AM   #2
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 1,340
I'd say the fixture rating is for real watts (ie 13W) not equivalent watts
(ie 100W). So they could put a 200W equivalent in there if they wanted
to as it's only about 36 real watts......if it fit.
P&L
The Following 2 Users Say Thank You to PlugsAndLights For This Useful Post:
MCasey (12-10-2016)
Old 12-10-2016, 11:24 AM   #3
daveEM's Avatar
Rewards Points: 474
I'm still looking for a LED bulb that can be put in an enclosed fixture.
wcord and PlugsAndLights like this.
They say if opportunity isn't knocking,
...Build a door.
I like perfect.
Old 12-10-2016, 11:34 AM   #4
Rewards Points: 2,196
P&L
I ain't buying that, but if you do it's wonderful, because I prefer you to be the test monkey on behalf of myself . Let us know how it works out please. Oh and thanks for your sacrifice and service to the public. I mean it
Majewski likes this.
Old 12-10-2016, 11:45 AM   #5
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 250
Heat is measured in power absorbed over time. Watts is a measurement of power, so the amount of wattage something consumes is directly related to how much heat it generates.
It's literally impossible for something using 13Wh of energy to put out more heat, or even the same heat, as something using 60Wh of energy.
Old 12-10-2016, 11:49 AM   #6
That's terrific. Now please explain scientifically how 50 watt halogen puck lights wont burn down a kitchen cabinet because after all it's only a 50 watt lamp.
Majewski (12-10-2016)
Old 12-10-2016, 02:13 PM   #7
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 250
Halogen lights are hot because FEMA fills them with chemtrails.
Old 12-10-2016, 02:40 PM   #8
Click Here
Rewards Points: 1,382
What if the 13w device is much, much less efficient than the 60w device?
What if, for example, the 13w device is putting only 1w towards it's intended purpose (let's say light) and 12 watt to heat, while the 60w device is putting 55w towards it's intended purpose and only 5w to heat?
Old 12-10-2016, 02:47 PM   #9
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 250
What if the 13w device is much, much less efficient than the 60w device...?
The ratings are based on expected heat load from an incandescent bulb, and incandescents are fantastically inefficient: The average incandescent converts <5% of the power to light; they are space heaters that also happen to glow in the dark. So it's practically impossible to exceed the fixture thermal rating by accident.
Ty the electric guy (12-10-2016)
Old 12-10-2016, 02:51 PM   #10
Click Here
I have to admit, this is above my head.
The wattage ratings on bulbs (incan, CFL, or LED) are how much power they use, no? So I don't understand your above statement.
I'm still not understanding how a very efficient 13w device can't put out more heat than a super efficient 60w device.
Old 12-10-2016, 03:11 PM   #11
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 250
...I'm still not understanding how a very efficient 13w device can't put out more heat than a super efficient 60w device.
In theory it could. But incandescent bulbs are so inefficient that to make things simple we can pretend that all of their power rating gets turned directly into heat.
That means if you've got a fixture rated at 60W, then it is designed to tolerate 60Wh of heat energy continuously. So any other bulb that either
A) uses less power or
B) uses the same power more efficiently
will expose that fixture to less heat.
Majewski and PlugsAndLights like this.
HackWork (12-10-2016)
Old 12-10-2016, 04:18 PM   #12
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 298
efficiency is an actual quantity, even though it is used in everyday language.
the efficiency of a mechanical/electrical device is usually defined as the percentage of work performed divided by the total energy used.
in the case of the incandescent bulb, the efficiency would be:
Watts of light energy/watts supplied on the circuit.
now, one could find the light energy by measuring, or more easily measure the amount of heat output along with the heat lost in the conductors (voltage drop).
so the Watts of light energy = Watts supplied - Heat loss of bulb - heat loss of conductor resistance.
and the efficiency would end up being something along the lines of what John said, or in other words, you would lose 80 to 95 percent of the energy supplied doing work other than that which was intended (ie. lighting).
hope that helps.
Old 12-10-2016, 05:35 PM   #13
Safety Pin Member
The numbers vary by brand etc but they're roughly like this:
Incandesent -> 2.5% eff -> 60W@2.5% -> 1.5W light and 58.5W heat
LED -> 10% eff -> 13W@10% -> 1.3W light and 11.7W heat
While the location of the heat will be different between the two, 11.7W
of heat is very unlikely to cook the wires etc the way 58.5W will.
@daveEM made a good point in post #3 re; enclosed fixtures. AFAIK, this
is related to lamp life only, not overheating of wires etc..
P&L
Old 12-10-2016, 05:53 PM   #14
Big nosed attic troll
Majewski's Avatar
Rewards Points: 1,144
P&L
Lol..... sometimes my motto is "if it fits, I sticks".
Majewski is online now   Reply With Quote
Old 12-10-2016, 06:11 PM   #15
Rewards Points: 220
Very much so, if not we'd have seen LED heater infomercials coming out the ears.
MCasey is offline   Reply With Quote
Old 12-13-2016, 05:45 PM   #16
Rewards Points: 107
Isn't that comparison of saying a 13W LED being the same as a 100W incandescent only equivalent in the amount of lumens it produces, not the amount of energy.
!Tom is offline   Reply With Quote
Old 12-13-2016, 05:55 PM   #17
Rewards Points: 26
Yes, and unlike the case of an incandescent bulb the color temperature of an LED is not tied to its thermal temperature.
Sent from my XT1585 using Tapatalk
!Tom likes this.
inetdog is offline   Reply With Quote
Old 12-13-2016, 06:00 PM   #18
Rewards Points: 107
You mean you can't switch to cool lighting during the summer to beat the heat?
Old 12-13-2016, 06:04 PM   #19
Rewards Points: 26
It might be subjectively more comfortable
BTW, I have one bathroom in my house that is not tied to the HVAC system.
I put in a heat lamp bulb in the can next to the shower for winter and replace with an LED trim each summer. Does that count?
Old 12-13-2016, 06:09 PM   #20
Rewards Points: 107
Just use a red LED, same redness, less wattage.
Temperature Rating KeithAnBr Introductions 7 11-16-2016 05:48 PM
Thermal temperature readings on breakers Sparky Mcgregor General Electrical Discussion 5 10-22-2016 01:35 PM
Which company's LED Bulb is best ? Paultaylor1235 General Electrical Discussion 13 06-29-2016 12:04 AM
New 4 bulb ballast - only 2 positions work at a time! sam11i General Electrical Discussion 3 03-02-2016 12:21 PM
U/G conduit under Arena ice surface CreeperXO Canadian Electrical Code Forum 6 03-02-2016 11:45 AM
