LED still on with no power? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
  • 1 Post By HackWork
  • 1 Post By frenchelectrican
  • 4 Post By Big John
  • 3 Post By daveEM
Old 11-13-2016, 10:59 AM   #1
Rewards Points: 7,154
Default LED still on with no power?
I'm sure this has been talked about already but I couldn't find anything.
I put in some Lotus knockoffs and the customer says one produces a little bit of light even when it's shut off. He can only see it at night. It isn't leakage through a dimmer because it's on normal 3 way switches. There are four fixtures on the switch leg and the others are okay.
Ideas?
Old 11-13-2016, 11:02 AM   #2
Click Here
Rewards Points: 4,948
Lighted switches?
Old 11-13-2016, 11:05 AM   #3
Lighted switches?
Nope, just normal (P & S I think).
Old 11-13-2016, 12:43 PM   #4
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 154
Adjust your pot on the side of the LED compatible switch.
Old 11-13-2016, 12:52 PM   #5
Click Here
That would only be on a dimmer. Are dimmers in use $.99?
Moddy, I will reply to your PM when I get home.
The_Modifier likes this.
The_Modifier (11-13-2016)
Old 11-13-2016, 12:54 PM   #6
No dimmer.
Old 11-13-2016, 12:58 PM   #7
Rewards Points: 630
Ideas?
Hey 99.,
I may know but the issue is how long it stay on after it shut off on the light ?
if it was on very dim for few minuites then it go out it may have some resdueal charge in there. unless it is near one of unswitched circuits sometime it can pick up inducted voltage which I know it is super rare but it can happened.
Old 11-13-2016, 01:49 PM   #8
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 262
Put a high impedance multimeter at the lamp socket with the switch turned off. If there's enough leakage to light a bulb, you'll see voltage.
I'm guessing you won't, and what he's seeing is the result of either capacitor bleed-down in the LED driver or some sort of phospheresence from the way the bulb makes white light. Either one of those will eventually go away after a few minutes.
backstay, GrayHair, telsa and 1 others like this.
Old 11-13-2016, 06:15 PM   #9
daveEM's Avatar
Rewards Points: 740
Change the switches.
They say if opportunity isn't knocking,
...Build a door.
I like perfect.
Old 11-20-2016, 06:20 PM   #10
Rewards Points: 114
Speaking from experience:
Old (and worn-out) Pass & Seymour three-way switches can leak enough current to dimly illuminate an LED bulb. Also, if the fixture's driver circuit entails a capacitor, a dim after-glow is to be expected (especially from a budget-oriented design).
Max C. is offline   Reply With Quote
Old 11-27-2016, 02:04 AM   #11
You get the same thing with cfl.
TrArKi is online now   Reply With Quote
Old 11-27-2016, 09:03 PM   #12
Cl906um's Avatar
Rewards Points: 1,048
Most residential three ways will bleed through. Put your tick tracer up to a half switched receptacle and it will glow. Meter will read 75 volts.
Old 12-03-2016, 04:34 AM   #13
rjuergens's Avatar
Rewards Points: 12
Shared neutral is the likely cause of this result. Had to figure this out myself once on recess lights in a bathroom that I installed a dimmer on and got a call the next day about LED trims that don't go off totally. Customer had changed bulbs to led trims. He said, no problem with the bulbs but led trims continue to glow very dim when turned off. Had him turn off breakers to isolate the issue. He told me a totally different circuit turned off the glow. That is when I concluded the shared neutral issue.......
rjuergens is offline   Reply With Quote
Old 12-03-2016, 09:14 AM   #14
Just a followup - customer said the light faded out over time. These were Lotus knockoffs. Someone said that cheaper drivers can discharge over time. Maybe that's what's going on.
Lotus tells me they use a two stage driver. I have no idea what that means but I have never had this issue with Lotus.
Is this the correct power supply for this computer equipment? jordanoye General Electrical Discussion 11 10-27-2016 07:54 PM
Power Surge on One Leg with high amp appliances crum2243 General Electrical Discussion 1 09-20-2016 02:24 AM
Lights Flicker when initial power the disposal crum2243 Residential Electrical Forum 1 09-20-2016 02:22 AM
Power metering after high amp breaker sanpompon NEC Code Forum 3 03-08-2016 04:56 PM
Wind power mpetro PLCs, VFDs, Motors and Controls 13 01-24-2016 10:44 AM
