Old 08-15-2012, 08:47 PM   #1
Default Low voltage to control lights??
I looked at a shop today 80x100 they used 12v to control the t5 lights. I've never done this and I'm wondering how reliable it would be long term with the switches being that far apart
anyone have any experience with this??
midwesterner is offline   Reply With Quote
Old 08-15-2012, 09:22 PM   #2
We do this quite a lot and have good luck with the relays, very simple to hook up and we haven't had many callbacks, we put all the relays in a box near the contractors usually
ohiosparky99 is offline   Reply With Quote
Old 08-17-2012, 08:42 PM   #3
thanks for the reply sparky. is there a certain brand you stick with? aslo do you just run t-stat wire between the switches
Old 08-17-2012, 09:42 PM   #4
Here's one similar to what we have used, normally our supply house stocks hubbell, but this is very similar
Old 08-17-2012, 09:44 PM   #5
Also can do the same thing with a ice cube relay
Old 08-17-2012, 09:56 PM   #6
Here's a wiring diagram to show exactly how simple they are
Old 08-18-2012, 04:00 PM   #7
so if i have 3 switch locations, i don't tie the swithes together like standard 3 way switches. I would run 3 wires ( power in and 2 switch legs 1 for ''on'' coil and 1 for ''off'' coil) to each switch location. then splice them all to the relay. Is that correct??
Old 08-19-2012, 01:30 PM   #8
You could do it that way, or daisy chain the switches, we also use momentary switches, no need for voltage on the relay all the time since its a latching relay, just needs a pulse
Old 08-19-2012, 03:21 PM   #9
we use them at some country clubs, etc where they have indoor court lighting, remote ballasts and multiple switching locations.
Yes you could use an ice cube, but you need to build a control box, have a latching circuit etc.
with these relays you pop them into a 3/4' KO and have your high(er) voltage inside a regular j box and your low voltage is outside the box.
Bbsound is offline   Reply With Quote
LV control for lights truelight General Electrical Discussion 10 08-15-2011 10:41 AM
Low voltage puck lights Chris1971 Lighting Design 13 02-07-2011 06:23 PM
Low Voltage lights 5-10 ft from pool ElectricBill General Electrical Discussion 5 07-12-2010 08:11 AM
auxiliary contacts for control voltage isolation sqi Services and Service Equipment 0 06-24-2009 06:14 AM
Remote control lights/sockets philip657 UK Electrical Forum 0 09-01-2008 09:28 AM
