Old 04-10-2012, 02:24 AM   #1
Light Emitting Decoration
Electric_Light's Avatar
Red face Philips EnduraLED 48"T8 apparently 32% less efficient than mercury gas technology
Available in 11W 825lm and 22W 1650lm.. 40,000 hrs/85% maintenance(over how many hrs, I don't know)
Can't be used with shunted instant-start sockets. It's wired like a glow-starter type fluorescent lamp with a jumper in place of the glow starter. No idea why it needs a shunt going from one end to the other.
http://www.usa.lighting.philips.com/..._End_Users.pdf
With the starting efficacy only being 75LPW and mean of only 64LPW, there is much to be desired when two lamp T8 can get 92new/90mean system LPW. Mean efficacy is 30% less than the modern T8 and that's simply unacceptable. Initial lumen is only good for the wow effect for sales demo.
Premium T8
3100new/2915 rated mean
2 lamps at 77% drive reduced output
AC 277v 48W
4490/48 = 93.5 sustained LPW, 99.5 LPW new
(2915mean lamp lumen x 2 lamps x 77% ballast output)=4490lm. 4490/48 watt input yields 93.5 lumens per watt.
LED 1400 lm mean (1650 x 85% maintenance)
4490lm/1400lm =3.21 lamps
so 1400 x 3 lamps = 4200 lm
6.5% reduction in output
22W x 3 = 66W 37.5% increase in power use.
32% reduction in efficacy
1400 mean lumen x 3 lamps = 4200 lm. 4200 / 66W lumen yields 63.4 lumens per watt.
63.4/93.5 = 0.678
(1-0.678) x 100 = 67.8... so, the LED setup is the 68% the efficiency of fluorescent system, which can also be stated as 32% less efficient.
Not sure what they're using in the sell sheet, but the above calculation is based on GE UltraMax-L 2 lamp and Philips F32T8/ADV835
Electric_Light is offline   Reply With Quote
Old 04-10-2012, 02:26 AM   #2
Edrick's Avatar
I started reading this then said hmm why does this sound like a post from that guy who hates LED. Sure enough...
Although I am curious as to how well these works as one of my clients is getting a swap out done to these.
Edrick Smith
ES Productions - Entertainment Solutions
»edricksmith.com
Edrick is offline   Reply With Quote
The Following User Says Thank You to Edrick For This Useful Post:
electricmanscott (04-15-2012)
Old 04-10-2012, 02:29 AM   #3
Philips make both LED and fluorescent, so there's no more conflict of interest than comparing their HIDs to fluorescent.
All the numbers are from catalog. The exception is that they didn't include value for the T8 system or if they actually tried to match output lumen.
Here I combined high lumen F32T8 in a two lamp setup against three 48" T8 shaped LED tubes, so that the final mean output by the book is within 10%.
Old 04-10-2012, 04:33 AM   #4
BBQ
BBQ's Avatar
But who do you work for?
BBQ is online now   Reply With Quote
Old 04-10-2012, 10:04 AM   #5
erics37's Avatar
Sylvania
Old 04-10-2012, 05:04 PM   #6
I didn't name Sylvania products once in the comparison.
There's minimal difference in performance between OSI/GE/Philips fluorescent lamps anyways
Old 04-10-2012, 08:33 PM   #7
Cletis's Avatar
Default Shang
Those lamps are all made in same factory in Shanghi anyway
www.cletiselectric.com
Old 04-10-2012, 11:08 PM   #8
mbednarik's Avatar
Premium T8
AC 277v 48W
63.4/93.5 = 0.678
Where do you get 48 watts? Wouldn't the input be 64 plus ballast loss?
Old 04-10-2012, 11:29 PM   #9
Cletis's Avatar
Default ..
Maybe 2-28 watt bulbs driven at 0.77 = 48 watts (ballast loss not included)
The Following User Says Thank You to Cletis For This Useful Post:
mbednarik (04-15-2012)
Old 04-15-2012, 06:36 AM   #10
The ballast specs.
T8 lamp book specs are based on 60Hz operation. When they're operated at 50KHz like electronic ballasts do, the lamp itself becomes 10% more efficient.
So, it only takes 29W to produce catalog value. Now, catalog value assumes lamps are operated to provide 100% of rated output. If they're actually driven at 32W each, they actually produce 100% output...
Standard T12 magnetic ballasts, now out of production typically only came in one type. 95% rated output.
Commercially available T8 ballasts typically don't drive them to produce 100% output. Standard ones drive them at 87%. Low output ones (like the one I used above) drive them at 77% with corresponding reduction power usage.
Old 04-15-2012, 08:16 AM   #11
k_buz's Avatar
At over $65 bucks a lamp, I can't believe this is going to be an easy sell.
k_buz is offline   Reply With Quote
Old 04-15-2012, 10:09 AM   #12
mbednarik's Avatar
i installed 4 of these. The main thing i did not like about them besides the cost was the head sink on the back side of the lamp. It would effect the photometrics of fixtures.
Old 04-16-2012, 04:07 PM   #13
Not here at the moment
Dnkldorf's Avatar
never mind..............
Dnkldorf is offline   Reply With Quote
Old 04-16-2012, 06:34 PM   #14
Who's idea was it?
As long as it's legal, customer's request trumps everything.
If you're selling cars and someone is determined to buy a V10 truck against your personal opinion, why bother persuading them into something inferior?
Old 04-20-2012, 12:15 PM   #15
Now, one of the old guys!
Just so you know I work in GE's main T8 lamp plant for worldwide production here in Ohio! We actually ship T8 lamps all over the world from here.
gesparky221 is offline   Reply With Quote
Old 04-20-2012, 12:54 PM   #16
Cletis's Avatar
Default ?
Do you inject the mercury and phosphors at the plant in ohio? How is it living in ohio anyhow? I've heard good things...
Old 04-22-2012, 12:55 AM   #17
I love factory tours.
Old 04-22-2012, 04:43 PM   #18
Our plant takes the clear tube and assemble it, adding phosphor, mercury, making the mount, that holds the lead wires and lamp cathode add gas, and test each lamp. It is highly automated. We have 4 main lines, an older T12 line which runs 6000 lamps per hour, and 3 T8 lines that run between 7000-8000 lamps per hour. Our shop runs 24/7. Living in Ohio is ok most of the time. I have worked at this plant for 27 years. We just added a new line to our plant, which was moved from Canada to our location.
Old 04-22-2012, 04:54 PM   #19
1,000,000th Poster
Big John's Avatar
How on earth do y'all add the mercury? Is there a mercury pumping system? That's gotta be nuts.
-John
Big John is online now   Reply With Quote
Tags
downgrade, fluorescent, led, leed, pr stunt
My Klein #2 Philips works. Gear Head Tools, Equipment and New Products 97 09-22-2012 08:26 AM
"electricians" advertising "recession pricing" "super low prices to fit your budget" lovethetrade General Electrical Discussion 17 11-30-2011 11:44 PM
Incredible 3-D Robbery Scene by Philips jrannis Off Topic 13 05-28-2010 07:04 PM
Philips Lighting lamp catalog has too many errors Electric_Light Lighting Design 7 04-29-2010 06:07 AM
Philips #2 holding screwdriver MNservicetech Tools, Equipment and New Products 11 06-09-2008 10:33 PM
