Old 04-23-2012, 10:20 PM   #1
Little-Lectric's Avatar
Default Photo Cell to Photo Cell
Any problems connecting a light that has a built-in photo cell to a central photo cell? I need to replace some fluorescent wall packs that are controlled by a central photo cell. The current lights don't have built-in cells, but the new ones do. Other than the photo cells detecting at a different level/time I can't think of any other reason why they wouldn't work, can you?
Little-Lectric is offline   Reply With Quote
Old 04-23-2012, 10:23 PM   #2
Ddill's Avatar
Reason number one is it's a hack thing to do. Good luck servicing them. If your installing new fixtures, why don't you just unhook the new photo cells?
Ddill is offline   Reply With Quote
Old 04-23-2012, 10:24 PM   #3
animal lover /rat bastard
wildleg's Avatar
it will turn them off (if I am understanding that the central photo cell operates a contactor which powers the lights ?), but it won't necessarily turn them on at the same time, and some will turn themselves off early
why don't you just defeat the built in photocells ?
Big John (04-23-2012)
Old 04-23-2012, 10:26 PM   #4
erics37's Avatar
When I run into that I just bypass the wall pack photocell. Probably a listing violation but whatever, at least it'll work right.
Old 04-23-2012, 10:36 PM   #5
Heavily Armed Member
HARRY304E's Avatar
The master photo cell will turn on with 1 to 5 lumens of light left at that point power will go to all the lights.
When there is no power the photo cells are in the normally closed position if the individual photo cells sence enough light then they will shut off after the time delay setting till it is dark enough for them to turn on again.
So you really don't have to do anything with the individual photo cells unless you want all of them to turn on and off at the exact same time.
When the master photo cell turns on all the lights will have power at the same time same when it shuts off.
Old 04-23-2012, 10:43 PM   #6
Resi Service Electrician
electrictim510's Avatar
Originally Posted by HARRY304E View Post
The master photo cell will turn on with 1 to 5 lumens of light left at that point power will go to all the lights when there is no power the photo cells are in the normally closed position if the individual photo cells sence enough light then they will shut off after the time delay setting till it is dark enough for them to turn on again so you really don't have to do anything with the individual photo cells unless you want all of them to turn on and off at the exact same time.
Not trying to be the grammar police, but damn that's a huge run-on sentence.
"Understand one thing every one has a place in this trade, and no matter what your skill set I doubt you know it all." brian john
electrictim510 is offline   Reply With Quote
Old 04-23-2012, 10:48 PM   #7
HARRY304E's Avatar
Yeah i got a little carried away...
I split it up a little....
electrictim510 (04-23-2012)
Old 04-24-2012, 12:15 AM   #8
Thanks to you all!
I haven't got the new lights yet and don't know how they are wired. I thought about bypassing the inclosed cell but didn't know if it would be easy to get to the wiring from the sensor.
The lights do not have to come on at the exact same time, just sometime before morning.
Old 04-24-2012, 01:28 AM   #9
erics37's Avatar
Thanks to you all!
Most of the CFL wallpacks I've dealt with just have a little button-type photocell mounted in there. Just cut some zip ties and you'll find the power and switch leg leads.
The Following User Says Thank You to erics37 For This Useful Post:
Little-Lectric (04-24-2012)
Old 04-24-2012, 02:32 AM   #10
Light Emitting Decoration
Electric_Light's Avatar
If the master control can work regardless of load level (i.e. can work with ballast loads) then the downstream photo cell shouldn't matter. If the master cell is the type that requires magnetic ballast or incandescent load, the downstream cell will cause a malfunction.
Opaque tape would bypass the cell without voiding any listing.
Electric_Light is offline   Reply With Quote
Old 04-24-2012, 09:18 AM   #11
Master control will work with or without ballast load.
Old 04-24-2012, 09:29 AM   #12
HARRY304E's Avatar
That would not make one bit of difference the down stream photo cells are just single pole switches in the circuit.
Old 04-25-2012, 03:51 AM   #13
it'll work fine. why void a warrenty by altering the fixture. future troubleshooting may be more involved, but that's only a problem for the inexperienced.
noarcflash is offline   Reply With Quote
Where's My Cell Phone? Little-Lectric Off Topic 4 09-08-2011 08:23 PM
Photo cell / Occ sensor Dnkldorf Lighting Design 4 07-20-2011 05:06 PM
Photo-cell not working moonjacks General Electrical Discussion 14 07-25-2010 12:16 AM
Need a new cell phone cobra50 Business, Marketing, and Sales 25 10-06-2009 11:29 PM
photo cell problem DHB General Electrical Discussion 7 05-18-2008 05:23 AM
