09-10-2009, 07:27 PM
Preagnant MH lamps
One of our crews went out to troubleshoot some fixtures (10 total) and found 9 with the lamps deformed as follows:
I have never seen a lamp do this, just shattered lamps. What would cause them to do this? BTW they are indoors, 5 ballasts are no good either, and one fixture remained working.
09-10-2009, 07:42 PM
Heat and gravity?
09-10-2009, 07:48 PM
Originally Posted by BadSplice
Heat and gravity?
Very wise grasshopper  What I'm wondering is why they heated up in that fashion instead of burning up or shutting off. Is it a defect of the lamp or can that happen at end of life?
09-10-2009, 08:28 PM
too much sex ?
That tiger ain't go crazy; that tiger went tiger! You know when he was really crazy? When he was riding around on a unicycle with a Hitler helmet on! - chris rock
09-10-2009, 08:32 PM
Rat Extraordinaire
Originally Posted by wildleg
too much sex ?
I wish I had that problem, but once is all it takes.
09-10-2009, 08:37 PM
too much sex ?
should've had the tubes tied first huh?
09-10-2009, 08:40 PM
Rat Extraordinaire
That's what happens when the lights go out........
09-10-2009, 08:43 PM
I bet it was cheap glass the Chinese use since we stopped buying their sulfur impregnated drywall
09-10-2009, 08:44 PM
Rat Extraordinaire
I thought it was lead-laced toys.
09-10-2009, 08:46 PM
That was after the lead laced toothpaste
09-10-2009, 09:07 PM
Rat Extraordinaire
Well, that certainly would explain a lot!
09-10-2009, 09:09 PM
Service Tech
Who is the manufacturer of the lamps?
09-10-2009, 09:10 PM
Rat Extraordinaire
Yeah, well, that's the 'before' picture. I took this of myself yesterday:
09-10-2009, 09:15 PM
LMAO.. you always find a way to "better" yourself
09-10-2009, 09:18 PM
Rat Extraordinaire
I just can't wait until tomorrow, cause I get better looking every day!
09-10-2009, 09:36 PM
To be honest I didn't look. I just loaned the other tech a 12' ladder when he went back to install the new lamps
09-10-2009, 10:53 PM
#18
Floppy Member
too much sex ?
Valtrex might help clear that up. And help keep it from coming back.
09-11-2009, 07:09 AM
#19
Ratus Maximumus
My first guess is simply lamp / ballast incorectly matched.
My second would be a lamp was used outside of its operating range.
Some lamps are horizontal burn, some are vertical burn and others are univerasl burn.
EFFECTS FROM IMPROPER ORIENTATION
The Arc tube may become bulged or swollen. After extended operating hours some bulging is normal, especially in the off-vertical burning position. If a lamp bulges prematurely, this condition may indicate the lamp is operating at a higher-than-rated wattage due to miswiring, using the wrong lamp on specific ballast or the fixture optical system is directing too much heat onto the arc tube. This problem must be corrected or else the lamp may unexpectedly shatter.
http://www.geappliances.com/email/li...rientation.pdf
Bob Badger
Electrical Construction and Maintenance
MA, RI, CT
09-11-2009, 05:08 PM
#20
Lighting Contractor
Looks like it's worth check lamps and ballasts, and voltage. Yikes.
