Old 09-22-2007, 10:07 PM   #1
Default Recessed light drilling tip
I have a little bit of trouble with the pilot bit in the hole saw mandrel when I use big hole saws to cut 5 and 6 inch recessed light holes in old work drywall. Before the holesaw has a sufficient groove cut in the drywall, the pilot bit starts to wallow out the pilot hole and it makes it hard for the saw to "track" nice. To solve this, I've started to just drill the pilot hole first with a seperate drill, and then replace the pilot bit in a dedicated mandrel with a piece of smooth 1/4" rod. It's solved the problem entirely, and I've never had better looking holes in drywall.
Old 09-22-2007, 11:20 PM   #2
You can also use an aircraft or "phone installer" type bit that has about an inch of flutes then a smooth shaft. Cut to length so the flutes clear the drywall before the cutter hits the surface. If you use jobber length bits and have a sharpener a broken bit can be re-habbed for cutter duty as well.
Either way makes a world of difference.
Old 09-23-2007, 08:28 AM   #3
I really don't use hole saws for recessed, but I have been doing this for years with my hole saws.
That is one the most frustrating things when using one.
Here's another tip, although pretty common these days:
When drilling 1/2 & 3/4 conduit hole saws (7/8" & 1 1/8"), put a big 1/4" fender washer between the saw and the material. This way when the pilot bit goes through if you can hold it back the teeth do not "grab" the material and break the pilot bit. The washer just spins.
Also:
This stuff is AMAZING to me. Use Lenox cutting oil!!! This stuff is great!
It comes in small squirt bottles and is usually right near the holes saws on the rack.
Old 09-24-2007, 10:51 PM   #4
Bkessler's Avatar
For the 3/4" hole saw I have been using a actual 1" 0.d. hole saw instead of the 1 1/8th. those 3/4" connectors fit in there real tight! It's so nice. As for the recess light hole saws, I use my skinny flat head for my starter hole. and a longer than normal 1/4" bit when it time for the hole saw, and of course my half a basketball between the drill and the hole saw bit. bk
When ls lunch
Old 10-02-2008, 02:42 PM   #5
Usually for a buck more you can get tungsten carbide pilot bits that hold up a lot better with sheetrock and especially plaster - which is basically cement. I use an adjustable hole cutter from holepro.com and it has double tungsten carbide blades that cut great through sheetrock and even button board. I used the high speed steel blades that also came in the kit to cut 18 holes in 5/8" T&G for light cans and was done in under an hour. With plaster I used to worry about cracking it when using a saber saw and going through a blade per hole. With the hole pro cutter it get through a lot more holes with the blades and no more worries about delaminating the plaster. cheers
Johnpaul is offline   Reply With Quote
Old 10-02-2008, 02:53 PM   #6
Seen your member
Another tip with the carbide-grit blades: Run the drill in reverse. They cut both directions!
Old 01-30-2009, 08:38 PM   #7
I usually cut these in with my RotoZip. I don't do a real lot of them and I learned a long time ago to be very carefull with a RotoZip. They can get away from you!
iaov is offline   Reply With Quote
Old 01-30-2009, 08:51 PM   #8
"A" inside wireman
randomkiller's Avatar
I have been using that technique on sheetmetal for a long time for hole saws, it makes a huge difference.
"One Nation Under God"
Old 01-31-2009, 02:25 PM   #9
I use pilot bits on all of my hole saws that are long enough so I can just flip them over after the hole is started. The pilot retainer screw has a rounded base that holds snuggly in the flutes of the pilot bit without damaging them.
When using the Hole-Pro type cutter on the other hand, it cuts so quickly in drywall, that there is no time or need to reverse the pilot bit.
Old 02-03-2009, 07:17 PM   #10
I use a drywall circle cutter to score the drywall,then use a drywall saw.Never mastererd my Rotozip enough.
Old 02-04-2009, 08:24 AM   #11
"A" inside wireman
I don't trust a rotozip in my hand upside down and dust flying. Last cans I did were in a 3/4" thick faux stone soffitt, had the installers cut the holes for us.
Old 02-04-2009, 09:28 PM   #12
Wow you guys have the right tools for the job! I find myself reduced to bending ceiling wires to the radius of the circle, tracing out the hole, and drywall-sawing it.
Dembones is offline   Reply With Quote
Old 02-05-2009, 12:09 AM   #13
"A" inside wireman
You have heard of that new fangled circle maker thingy called a compass? It makes them perfectly round and you can even tune it in to a center mark pretty quick.
Old 02-05-2009, 12:01 PM   #14
Why, yes I have. I sure don't remember seeing such a thing on my tool list. You will notice from my last post that I know there are hundreds of available hole making options, but none have been made available to me on the job.
Old 02-26-2009, 09:22 AM   #15
try asking for one or buy one yourself its 5 bucks
JPRO2 is offline   Reply With Quote
Old 02-26-2009, 09:41 AM   #16
Mad Skills
Celtic's Avatar
None made available to you?
A piece of cardboard, 2 holes and a pencil is a compass.
Old 02-26-2009, 09:51 AM   #17
Seen your member
Geez, Celtic, you get all the good tools.
I'm stuck with two nails and a scrap of 14 wire.
Old 02-26-2009, 09:59 AM   #18
Mad Skills
Celtic's Avatar
LOL
At least I didn't bust out with the rotozip, circle cutter, vacuum act for once
Old 02-26-2009, 10:18 PM   #19
"A" inside wireman
Whatever it takes, I'd be damned if I was gonna try and make a circle out of ceiling wire. I would make a compass from anything available.
Old 06-28-2009, 10:51 PM   #20
kawaikfx400's Avatar
Default hey
http://www.lightolier.com/products/i...N&CAT_ID=25896
Thats what you guys need. MY company just got one, i think it was like 70 bucks. Catches all the dust and the blades are replactable. Pays for itself, first job, just throw it on your cordless drill.
kawaikfx400 is offline   Reply With Quote
Elco recessed light fixtures Slider Lighting Design 9 03-15-2010 07:23 PM
mast drilling tool R Squared Tools, Equipment and New Products 19 09-04-2008 06:57 PM
Drilling holes... twintask Tools, Equipment and New Products 28 04-07-2008 10:31 PM
What kind of recessed? te12co2w Lighting Design 5 01-08-2008 01:44 PM
Drilling & Notching Framing Members Joe Tedesco NEC Code Forum 3 06-23-2007 09:09 PM
