Replacing 3" mr16 pots with something new - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 1 Post By PlugsAndLights
  • 1 Post By sbrn33
  • 2 Post By 99cents
Old 10-21-2016, 09:23 PM   #1
NDC
NDC's Avatar
Rewards Points: 434
Default Replacing 3" mr16 pots with something new
Some client of mine wants 17 or so 3" pots replaced or repaired. The transformers have gone bad on half of them but i'm not going to bother sourcing out and replacing transformers.
The hole diameter is 3.5" so I'm debating on whether to pick up some 3" slim led panels which fit in a 3.5" hole. Remove the transformer and rewired to the slim led jbox. These are small looking panels though and the actual illuminated part is only about 2" in diameter.
My second option would be to make a 4" slim fit in the hole by boring the hole out. The hole saw within a holesaw trick to make the holes 4-1/8 or so.
I would have to holesaw through the newwork plate though which might be a pain but the end result would mean bigger brighter potlights.
What do you guys think? What would you charge per potlight?
I'm thinking .5 hrs per light + material.
Some other suggestions would be great too!
Old 10-21-2016, 09:51 PM   #2
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,556
That sounds like a real pain since they're likely only attached on
1 side. Maybe they can be bent up out of the way.
P&L
NDC likes this.
Old 10-22-2016, 10:47 AM   #3
NDC
NDC's Avatar
Rewards Points: 434
P&L
I don't think they are those rough in pot light plates. if this is the case then I'm laughing. These are new work cans I think that were installed before the drywall went in that get nailed on 4 corners.
Gonna avoid going the 4" route anyway, it would be messy. Going to drop the can out, get to the wiring, install 3" slim led.
I have done this before but with 4"
Old 10-22-2016, 11:24 AM   #4
still in business
sbrn33's Avatar
Rewards Points: 2,744
Just find a remodel can to fit the hole and use LED lamps. Pretty sure someone makes a 3 inch remodel.
If you have to upsize that hole your not doing the whole install in half an hour. Maybe if it is drywall.
Those existing cans are going to be a pain in the ass.
NDC likes this.
Old 10-22-2016, 11:26 AM   #5
NDC
NDC's Avatar
Rewards Points: 434
You're right I am quoting .5 hrs to replace with slim 3"
if I had to make the hole larger it would take far more time.
Old 10-22-2016, 11:31 AM   #6
Rewards Points: 8,150
That's what I would do. Drop the can and see if something like a 3" Lotus would work.
sbrn33 and NDC like this.
Mr16 halogen problems gu7 base type dham206 Commercial Electrical Forum 1 05-18-2016 07:40 PM
Lutron Grafik Eye replacing 3 Diva dimmers and Two (3 way) switches Anon512 General Electrical Discussion 2 05-04-2016 08:07 PM
