Old 04-08-2009, 05:10 PM   #1
That Guy
Mr. Sparkle's Avatar
Default Strip lights for a cold workshop.
Anybody here have any recommended manufacturers of some 4ft. fluorescent strip "shop" lights that will work well in colder temps?
I have a customer who is sick of the flickering lights in his workshop during the colder times of the year here.
Thanks.
Old 04-08-2009, 05:20 PM   #2
I am a RAT.
william1978's Avatar
Any zero degree ballast would work just fine.
Old 04-08-2009, 05:22 PM   #3
Thanks.
They make low temp. ballast. I am not sure what the electronic ballasts are rated for but the old ballast didn't work well below 50 degrees.
Alice
Old 04-08-2009, 05:22 PM   #4
I am a RAT.
Here is a part # for one of the ballast that I have laying around. Advance RCN-2P32_SC this takes T8 lamps. This is a electronic ballast.
Old 04-08-2009, 05:23 PM   #5
That Guy
Thanks man.
Regular T8 bulbs?
Old 04-08-2009, 05:26 PM   #6
I am a RAT.
Regular T8 bulbs?
Yes.
Your welcome.
Old 04-08-2009, 06:10 PM   #7
Hack and Rat all in one
Peter D's Avatar
Thanks.
There's some "Depot Cheapo" shop lights that are T8 cold weather rated. Or, as the others have said, a regular T8 industrial or strip would work fine too.
Old 04-08-2009, 08:16 PM   #8
Pretty much any T8 ballast will work in the cold nowadays.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 04-08-2009, 08:19 PM   #9
I am a RAT.
I was thinking the samething,but wasn't sure.
Old 04-08-2009, 08:48 PM   #10
seo
Many of the electronic ballasts with T-8's have a min starting temp of 0 degree F.
seo is offline   Reply With Quote
Old 04-08-2009, 10:51 PM   #11
Peter D's Avatar
My thought is that pretty much any T8 ballast will work in the cold nowadays.
Old 04-08-2009, 11:08 PM   #12
That Guy
Yeah I was just a little confused because I think it was specs on a Lithonia strip that I read that said 0 degree starting temp with T12 bulbs, 60 degree with T8. But I'll take your guys words for it.
Thanks!
Old 04-09-2009, 12:14 AM   #13
drsparky's Avatar
0 degrees is not cold, up here we call that a warm day! Here cold means <-30, at that temperature not many people spend time in an unheated garage. Some use two light switches and two lights. One is set up with a couple of incandescent bulbs for a quick trip to the garage. The other is for summer use, it controls florescent shop lights.
Old 04-09-2009, 12:20 AM   #14
NO high voltage here
i use LEDS. much brighter, last almost for ever, and never freeze
Old 04-09-2009, 01:17 AM   #15
That Guy
Mike,
What brand LED's do you use? Just wondering, not for this job but future reference. I've had a hard time making a sale thus far due to the price of LED lighting these days.
Old 04-09-2009, 01:41 AM   #16
You loaded?
Old 04-09-2009, 10:35 AM   #17
Out of curiosity, I always use high output ballasts and lamps in cold places like michigan barns and garages. Most of my experience has been with T12 unfortunately, but on that note, I don't recall running across T8 H.O. ballasts or lamps, and as for T5 all I can says is I held a lamp, once lol. So do these newer generations have an H.O. option or do you just have to refer to the ballasts name plate for a starting temp?
Greenblinker is offline   Reply With Quote
Old 04-09-2009, 06:41 PM   #18
I am a RAT.
You loaded?
Old 09-10-2009, 07:20 AM   #19
I use a glanz high frequency/ quick start ballast with t8's and i fitted them into garages carports and the likes. and i have never seen them flicker my life, (maybe they do would towards the end of lamps life) i get my glanz stuff here..
http://www.amptecs.net/product_info.php?cPath=32_40&products_id=623
this is a vapour proof i use, very affordable. these boys will despatch same day, but they only take orders online. That one there holds 2 lamps
Oh and nice work on the BS Meter
thefixer is offline   Reply With Quote
Old 09-10-2009, 09:02 AM   #20
Lighting Contractor
Lighting Retro's Avatar
The next generation of lamps work great. The new ballasts come in several options for ballast factor. .77 to 1.7 pretty much, and nearly everything in between. The HO seems to be more reserved for T5 as far as product description, but a 4 lamp T5 would be major overkill for most garages. A 4 lamp T8 would do great.
Also, be aware that manufacturing of 8' T12 lamps and ballasts must cease by 7/10 because they do not meet efficiency standards. They won't be making 8' T8's either. Might as well get used to the T8's now. They smoke T12's in brightness and energy use. Last longer too.
Lighting Retro is offline   Reply With Quote
UK: What do you use to strip cable? Trimix-leccy UK Electrical Forum 5 01-06-2009 05:52 PM
cold paul d. Off Topic 25 09-06-2008 09:12 PM
How cold do you go? JohnJ0906 General Electrical Discussion 23 11-15-2007 08:59 AM
Toggle switches on power strip casemods General Electrical Discussion 1 10-13-2007 09:52 AM
Plug strip installation faber307 General Electrical Discussion 23 03-30-2007 03:00 PM
