Suggestion on LED replacement light - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
Old 05-18-2017, 09:44 PM   #1
Click Here
Rewards Points: 1,512
Default Suggestion on LED replacement light
I have to replace a bunch of 2' fluorescent lights in the basements and laundry rooms of multiple apartment buildings. They don't want to have to keep changing lamps and ballasts. They aren't picky about the light fixture, they just want it to be LED and give off the same amount of light as what's there now:
Suggestion on LED replacement light-img_0508.jpg The picture is sideways, the lights are on the ceiling.
They are all the same, installed in surface mounted 4" round boxes like in the picture.
Any suggestions for LED fixtures?
Old 05-18-2017, 09:54 PM   #2
NRA Member
backstay's Avatar
Rewards Points: 1,438
Can you just change the lamps?
https://www.eledlights.com/led-lamps...l#.WR5QgFROmhA
Or a fixture.
https://www.eledlights.com/led-lamps...l#.WR5R_1ROmhA
backstay is online now   Reply With Quote
Old 05-18-2017, 11:31 PM   #3
Jlarson's Avatar
Rewards Points: 3,008
LED tubes
Old 05-18-2017, 11:43 PM   #4
Glock23gp's Avatar
Rewards Points: 70
Pop the covers off
Remove the ballasts
Rewire power to one side, neutral to the other side
Install new led tubes
Wipe windex on cover
Reinstall
You will get down to less than 10 min per fixture and I bid them at 30 min. each.
If your really greedy resell the lamps you removed on CL..lol
Great money, especially if your poco has rebates it's an easy sell.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Using Tapatalk
Glock23gp is online now   Reply With Quote
Old 05-18-2017, 11:47 PM   #5
still in business
sbrn33's Avatar
Rewards Points: 3,242
Originally Posted by Jlarson View Post
LED tubes
Are just plain DIY.
Old 05-18-2017, 11:55 PM   #6
Rewards Points: 1,304
It may worth it and I did read the specs and they claim it last 50,000 hours life so it be good for most area plus add some motion sensors too that way the tentents dont have to fool around with switches or majorty of them forgot to turn it off that what happend many places I know.
But I havent check the specs on LED tubes itself but I think they are right on par as the whole lumainire so it can go either way.
Old 05-19-2017, 12:02 AM   #7
Rewards Points: 9,214
Rip that old junk out. It looks like someone scabbed in troffers where they don't belong. I'm sure Cooper or Lithonia make a nice two lamp wrap. A shop light could even work.
Old 05-19-2017, 12:06 AM   #8
RePhase277's Avatar
Rewards Points: 4,126
So, is there just an octagon box above the light where all those pipes meet? If so, just toss up a porcelain keyless and use a bunch of socket doublers with LED flood lamps.
Old 05-19-2017, 12:24 AM   #9
After looking closer at the photo, those ARE a wraparound. 2' wraps aren't common. Hopefully four footers work.
Old 05-19-2017, 12:45 AM   #10
Glock23gp's Avatar
Rewards Points: 70
I totally missed the 2' part also
These are outdoor canopy fixtures but would work well in your situation.
They come in dimmer and brighter styles
What's the ceiling height?
Using Tapatalk
Old 05-19-2017, 12:51 AM   #11
Jlarson's Avatar
Are just plain DIY.
Go paint something.
sbrn33 and RePhase277 like this.
Old 05-19-2017, 12:59 AM   #12
I dont know if this work in this situation but let me post a link .,,
http://www.e-conolight.com/indoor-li...5271#configtop
I am not sure if it will have same light level as old one is.
Old 05-19-2017, 01:01 AM   #13
I would see if a four foot shop light works on a short chain. I think even Home Creepo sells them in LED (cheap HO crap, though).
Old 05-19-2017, 03:27 AM   #14
Click Here
Thanks for the replies. Yeah, those are 2'.
The ceiling height is 8'. These are in basements.
The LED tube idea is pretty damn cheap, I overlooked that. I will run it by the management. But incase they still want new fixtures, I'd like to find something.
I could hang any light by chain as recommended, but since there is currently a small 2' light there and a typical 4" octagon box above it, I was looking for a surface mounted LED light for ease of installation. The main stipulation is that it gives out as much light as the existing fixture (which probably isn't much, but I don't want to screw it up).
Old 05-19-2017, 06:05 AM   #15
Check out the Rab GUS two footer.
Old 05-19-2017, 06:54 AM   #16
I'm picturing old, dusty fixtures with brittle acrylic lenses. For me, fixture replacement is the better option. The only advantage to tube replacement is you don't have to worry about fixture disposal. If they have a dumpster you can use, it could be a nice little in/out job.
sbrn33 likes this.
Old 05-19-2017, 08:34 AM   #17
MikeFL's Avatar
Rewards Points: 1,148
Send a message via Skype™ to MikeFL
When people ask me which fixtures to use, I always suggest they go to their local supply house and talk to the counter guys. If there's a problem, they're going to make good on it and they have it in inventory so any problems are easier to fix than if you go to some online e-tailer. Those counter guys know what the good products are and which ones have problems.
You're in NJ with supply houses all around you. Tell them what you told us and see what they say.
Michael Gookin, President
GPS LightLock Astronomical Timers
www.GPSLightLock.com
(239) 848-6675
Old 05-19-2017, 08:37 AM   #18
My counter guys (and girls) are as dumb as fence posts.
Old 05-19-2017, 08:38 AM   #19
still in business
sbrn33's Avatar
These are retail prices but this is a kick ass fixture. It may be to bright though.
http://www.morrisproducts.com/pc_pro...6893559D689EFA
Old 05-19-2017, 08:52 AM   #20
Click Here
To be honest, this isn't really a RAB or expensive light type of apartment complex lol.
I was thinking more along the lines of $30-50 surface mounted ceiling fixtures that you may find in a kitchen. I just want to make sure that the light output is similar.
I'll see what the supply house has to offer.
Replacement light for Panasonic bath fan HackWork General Electrical Discussion 60 05-17-2017 08:00 PM
Help plz.. Can't get 3way light working awabizzle General Electrical Discussion 1 11-20-2016 11:35 PM
3 way light trouble awabizzle Residential Electrical Forum 2 11-20-2016 11:33 PM
Outdoor Light Works Intermittently BowtoEd General Electrical Discussion 2 11-18-2016 06:36 AM
