Old 04-23-2012, 10:58 AM   #1
Default T8 Lamps installed on a T12 ballast
What would happen if you installed T8 lamps onto a T12 ballast? They are 2 lamp 3' and 4' luminaires.
1joeyj is offline   Reply With Quote
The Following User Says Thank You to 1joeyj For This Useful Post:
Chris1971 (05-26-2012)
Old 04-23-2012, 11:56 AM   #2
Podagrower's Avatar
I did it once a long time ago. We had a construction trailer with 4' lights missing bulbs. There was a case of t-8 bulbs in the back. Some turned into wicked awesome strobe lights, some didn't work, some were very dim, but kind of lit.
I recently replaced a t-12 ballast in a 8' fixture with a t-8 ballast. The fixture already had t-8 bulbs in it, it kind of worked.
Podagrower is offline   Reply With Quote
Old 04-23-2012, 01:05 PM   #3
Not here at the moment
Dnkldorf's Avatar
Depends, you have to look at the ballast. Some will run T12, T10, and T8.
Dnkldorf is offline   Reply With Quote
Old 04-23-2012, 07:36 PM   #4
Probably reduced lamp life would be one symptom.
Old 04-23-2012, 08:07 PM   #5
Cletis's Avatar
Default End
There would be a catastrophic explosion of biblical porportions
www.cletiselectric.com
The Following User Says Thank You to Cletis For This Useful Post:
3rdgenwireman (04-24-2012)
Old 04-23-2012, 09:02 PM   #6
Light Emitting Decoration
Electric_Light's Avatar
T12 is 0.43A (or thereabout) and T8 is 0.265A.
The operating voltage is much higher on T8.
On magnetic T12, the lamps either won't start/flash obviously or if it manages to remain lit, either the ballast or lamp will fail soon.
On electronic T12, the ballast will have enough voltage to strike a T8. The ballast will operate at higher wattage than intended, because the voltage is higher while providing the same current, its likely that ballast will fry.
on the other hand, running T12s on T8 ballast will cause them to operate as if a 25W 2' lamp was fitted in place. They will simply run at reduced power. On an instant start without cathode heater, the cathodes may not stay hot enough and ends may blacken rather early.
Electric_Light is offline   Reply With Quote
The Following User Says Thank You to Electric_Light For This Useful Post:
Signalservice (08-10-2012)
Old 04-24-2012, 05:34 PM   #7
MarkyMark's Avatar
They will work for awhile and then fry the ballast. Judging from the gym where I replaced about 30 ballasts a couple of years ago, about 75% of them will burn out within three months. This, after an enterprising gym manager changed out every T-12 lamp in the place to T-8's to "save money."
MarkyMark is offline   Reply With Quote
The Following User Says Thank You to MarkyMark For This Useful Post:
Chinese Ballast / Mexican Ballast Lone Crapshooter General Electrical Discussion 1 02-23-2013 02:31 PM
changed 2k f32t8 lamps to the energy saving 25 watt lamps mbednarik Lighting Design 20 04-24-2012 10:23 PM
How much emt should be installed in a day? Crazed Rhetoric General Electrical Discussion 68 10-07-2010 12:11 PM
Replacing 8, 2 lamp magnetic ballast lighting with electronic ballast and t8 lamps phish1985 General Electrical Discussion 4 03-02-2009 02:57 PM
ballast with wrong lamps JohnJ0906 General Electrical Discussion 1 08-05-2007 10:01 AM
