Old 03-03-2009, 08:49 PM   #1
Default Track lighting without using a box?
just saw a track light with wiremold going to a ceiling fan... is this a code violation? or can you splice in the track inclosure?? just wondering..
hayan453 is offline   Reply With Quote
Old 03-03-2009, 09:00 PM   #2
Most tracks I have seen have a live end fitting in which you can bring your power to. I assume the wiremold is entering this enclosure. The enclosure usually has three terminal screws for neutral, hot and ground.
Old 03-03-2009, 09:14 PM   #3
Mad Skills
Celtic's Avatar
Most TL JB's have barely enough room for one cable...forget two.
They do make larger TL JB's, but there should be a box behind that point......as I recall
Old 03-03-2009, 09:18 PM   #4
You could also feed into one end of the track and use a live end on the other side to feed out. Legal? I don't know for sure.
Old 03-03-2009, 10:20 PM   #5
Seen your member
Not legal because they are polarized and will only fit into one end of the track.
Old 03-03-2009, 10:30 PM   #6
oh i see so it terminates in the en of the track like terminating in a panel? same kinda screw type lugs?
Old 03-03-2009, 10:35 PM   #7
electricista is right they do have the opposite side so you can daisy chain the TL.. thank you google haha.. and thanks guys for the help
Old 03-04-2009, 05:12 PM   #8
Professional Nit Picker
If I came across this on an inspection I would ask to see verification from the manufacture that the track light is approved for this set up. I'm willing to bet that it is not.
Old 03-04-2009, 05:23 PM   #9
I believe 480 sparky hit the nail on the head.
I have seen , in the past, a track manufacturer that made the end fitting so that you break off a tab on one side-- basically you could decide which terminal was neutral or hot. I guess you would have to reverse the screws on the far side.
I also agree with manchestersparky, the track is probably not listed for this install. It is a bit atypical.
Old 03-04-2009, 05:24 PM   #10
Do you have a link to the part you are talking about.
Old 03-04-2009, 06:04 PM   #11
Seen your member
How can you 'decide' which terminal is hot and which is neutral? The lampholders on the track must be kept polarized to satisfy 200.10(C), 410.50 and 410.90.
Old 03-04-2009, 06:16 PM   #12
This is true but I do recall this system. I am thinking it was an old juno vector system but am not certain. I may be wacked about this--it was 15 or more years ago.
Old 03-04-2009, 06:21 PM   #13
I'm not even sure I understand this setup. Track light... got it. Track light with Wiremold... okay, with you so far. I guess the Wiremold is feeding the track, eh? Track light with Wiremold going to a ceiling fan... this is where I get lost. I just can't picture what is is you're describing. What feeds the fan, exactly??? Are you saying someone somehow hung a fan off track?
Old 03-04-2009, 07:45 PM   #14
Wyome
I don't know if this is what you guys are talking about, but Halo makes what they call a conduit continuation kit, #L979. Designed as two live end connectors with a 1/2" conduit ko. Feed in a track and feed out the other end to go to another piece of track, or in this case, wiremold then out to a ceiling fan.
Old 03-04-2009, 08:34 PM   #15
I believe you are correct
They are made as right and left end conduit continuation kit. This helps you get around obstacles.
Here is the link
Old 03-04-2009, 09:01 PM   #16
MDshunk there was an exsisting ceiling fan and the track lighting was put in later so they got power from the fan.. im guessing 12/3 to the fan and instead of having a fan/light setup they just had a fan.. and i shouldve copied the link... i'll try to find it again electricista..
Old 03-04-2009, 09:16 PM   #17
Seen your member
Interesting. How did the wiring get from the ceiling fan box into the Wiremold?
Old 03-04-2009, 09:30 PM   #18
How about the old notch in the canopy trick.
Old 03-04-2009, 09:33 PM   #19
Seen your member
That would be my assumption..... hack work as it is.
Old 03-04-2009, 09:41 PM   #20
JohnJ0906's Avatar
You mean like that?
John from Baltimore
"One day at a Time"
low voltage track lighting nolatune General Electrical Discussion 1 02-18-2009 04:34 PM
Help with lighting verve UK Electrical Forum 0 03-12-2008 08:15 AM
Finished Lighting Job frank Lighting Design 29 12-10-2007 09:08 PM
Lighting Snags - Please help oll1e General Electrical Discussion 8 12-01-2007 10:43 PM
Track Joiners faber307 General Electrical Discussion 7 03-24-2007 12:41 PM
