11-02-2009, 07:38 PM
Transformer 12v halogen
Hey guys I have a simple question when wiring an electronic transformer for a 12v halogen lamp do I need to use a box when wiring the primary side or can I get use sj cord and wire nuts.
Thanks again
11-02-2009, 10:41 PM
Stiff Member
skip wire nuts, just butt splice the connections
11-02-2009, 10:55 PM
Stiff Member
300.15 doesn't specifically mention a jbox is required when using sj cord.
So, switch to NM and use a box
11-04-2009, 02:46 PM
Thanks guys, I might just place the transformer in a 4 or 5 inch box and make all my 110v connections in the box using sj cord with a plug.
anymore suggestions would be great.
01-05-2010, 03:08 PM
I have given up on low voltage halogen lamps. If needed I opt for the GU10 mains type. I take them out when I can advise a custome to spend the cash. Have tried LED's also but light level output is not up to value yet.
01-05-2010, 05:32 PM
Stiff Member
I gave up on em as well. Half the time when the kids would slam a cabinet door shut with the light on, it would pop the filament. Should've given up on the kids instead.
01-05-2010, 06:16 PM
Thanks again
I am very confused by all the responses. What kind of trany is it. If you have primary wires just sticking out of the trany then it must be in a box. Wac transformers have a special box you buy to house the trany.
4 Out Of 3 People Have Trouble With Fractions
01-19-2010, 07:15 PM
Stiff Member
thermal sensors
01-19-2010, 09:53 PM
any 12volt transformer with 120 or 110 on the primary side should be in a box
01-20-2010, 01:19 PM
Thanks again
Yes, the primary side should be in a box. Are you looking to plug it in? Is this why you have SO cord? You can get 12V plug-in transformers. Personally, I prefer hardwired enclosed 120v lights whenever possible. 12V stuff can be very problematic.
01-20-2010, 04:37 PM
mr-16s get too hot.. And they don't like vibration.
The transformers burn out too fast and are normally hard to get at though that small hole. (pot light)
 Don't fight .. Play nice!
01-20-2010, 07:03 PM
Not to mention that when used in the bulb-down orientation as in a can light or on a track, the heat causes oxidation and failure of the terminals in the socket, everybody I know who has these lights eventually seems to have this same failure (cheap socket terminals?).
02-10-2010, 12:12 AM
Yes, he is right. 12volt transformer with 110 or more, on the primary side should be in a box.
03-08-2010, 09:00 AM
Thanks for your suggestion dude. This would be helpful for me,,,,
03-20-2010, 03:49 AM
Hi all, thanks for your replies with good suggestions. I think this will keeps going on for a long while
