Old 08-02-2009, 10:41 PM   #1
Default Wall Sconces
When using wall sconces for the primary lighting, how do you lay it out? Tricks? Pointers?
Thanks.
SideWorker is offline   Reply With Quote
Old 08-02-2009, 10:42 PM   #2
Speedy Petey's Avatar
This depends greatly on the type or fixture being used IMO.
Old 08-02-2009, 10:50 PM   #3
That kinda complicates it... lol
Old 08-02-2009, 10:50 PM   #4
Thanks.
1fc/ft is legal. One fixture anywhere will do that.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 09-11-2009, 11:47 PM   #5
CADPoint's Avatar
Send a message via AIM to CADPoint Send a message via Yahoo to CADPoint
I don't beleive thats not a correct statement, if an emergency light it's 15fc/Ft at an exit sign the minimum light is only 1fc/ft. The broadcast of an exit sign should still be 15 fc/ft.
Old 09-11-2009, 11:53 PM   #6
I agree with his statement, and not yours. The last restaurant I did, they tested egress path at a min of 1fc/ft.
Old 09-12-2009, 02:43 AM   #7
Mad Skills
Celtic's Avatar
I think they look best on walls.
Old 09-12-2009, 11:03 AM   #8
I like them with a cup of tea with lemon.
Wait thats scones. Never mind.
Jim Port is offline   Reply With Quote
Old 09-12-2009, 03:16 PM   #9
captkirk's Avatar
I personally like to include sconces in lighting layouts when ever I can. But to use only sconces...? Thats really old school. I like to layer the lighting with ceiling fixtures or High hats and sconces on the walls. this will give you a nice even lighting. And if you just want a softer light you can just turn on the sconces.
captkirk is online now   Reply With Quote
Old 09-12-2009, 04:31 PM   #10
Rooms that have sconces only always appear to me to be "dark". Sometimes that's the effect they're going for.
I try to leave the lighting design to the lighting designers. Takes the heat off me.
Old 09-21-2009, 02:40 PM   #11
Convince the customer to add can lights on a seperate dimmer switch for primary lighting and the sconces as filler. The effect will be more even and you will have a happy customer.
got2climb is offline   Reply With Quote
Old 09-21-2009, 10:24 PM   #12
eds
I like to use sconces as a way to get back at the sheetrocker, put a sconce on the wall and I can almost bet you will see all the tape joints on that wall. I also like to use them going down stair ways, usually eaiser to change lamps out in the future and their are some pretty trick sconces out there.
eds is offline   Reply With Quote
Old 09-23-2009, 08:30 PM   #13
Ima Hack's Avatar
Thanks.
Depends the dimension of the room you're lighting. Is it 10'x10' or 50'x50'?
Ima Hack is offline   Reply With Quote
Splices in wall guschash NEC Code Forum 31 06-14-2009 12:22 AM
Shower wall fixtures Joefixit2 General Electrical Discussion 6 05-21-2009 12:51 AM
Wall Lights fry80657 General Electrical Discussion 15 01-23-2009 10:06 AM
looking for a wall plate Handyman General Electrical Discussion 5 01-11-2009 11:27 AM
What is behind wall #1 curranelectric Code Violation Discussion 2 08-14-2007 07:09 PM
