1000 Amp Residential service - Electrician Talk - Professional Electrical Contractors Forum
Old 03-23-2010, 06:29 PM   #1
Tool Junkie
Rewards Points: 25
Default 1000 Amp Residential service
Thought I would post a pic of the 1000 amp service I am working on.
FragElectric is offline   Reply With Quote
Old 03-23-2010, 06:32 PM   #2
william1978's Avatar
Rewards Points: 2,000
Condo's???
Old 03-23-2010, 06:33 PM   #3
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,536
That must be one big ass meth lab for a 1000 amp service.
Old 03-23-2010, 06:33 PM   #4
Where are the myers hub's?
Old 03-23-2010, 06:34 PM   #5
sparks134's Avatar
lets see the back up genny!
sparks134 is offline   Reply With Quote
Old 03-23-2010, 06:34 PM   #6
There are several house's around here that have up to 1600 amp services.
Old 03-23-2010, 06:36 PM   #7
Rewards Points: 3,855
He might be using sealing rings. I've done that a time or three, when space is tight.
Old 03-23-2010, 06:37 PM   #8
I own stock in FotoMat!
Rewards Points: 6,520
Six condos/apartments/townhouses, plus a house panel.
Old 03-23-2010, 10:10 PM   #9
Tool Junkie
Rewards Points: 25
It is an existing 5000 square foot house that is getting an 8000 square foot addition. The existing house has a 400 amp service. The 5-200 Amp disconnects will be feeding the 2 existing 200 amp panels in the existing house, 1-200 amp panel for the detached pool house and detached 2 level garage, 1-200 amp panel to provide additional circuits to the addition, and 1-200 amp panel for the 22 tons of geothermal units. There will be 3-45 kw generators, 1 for the 2 existing panels, 1 for the additional house panel and pool house/garage panel and 1 for the geothermal panel.
No myers hubs are required as the trough and disconnects will be externally bonded with the 4/0 copper from the footer.
The back side of the bottom trough has a square cut out where a second trough enters from the other side of the wall. The trough on the other side of the wall sits under a CT cabinet.
Old 03-23-2010, 10:19 PM   #10
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Are you designing the service or following a print?
Keep posting pics
Old 03-23-2010, 10:26 PM   #11
Rewards Points: 220
Around here, the POCO would set a 15 KVA transformer on the pole, and feed the 1000 amp service with #6 tri-plex.
Nah, maybe they'd go to a 25 KVA, and use #4. It's a big service y'know!
Rob
P.S. Nice-looking work!
Old 03-23-2010, 10:30 PM   #12
Originally Posted by Black4Truck View Post
Keep posting pics
Yea Frag we like pictures.
Old 03-23-2010, 10:36 PM   #13
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,114
Rob
Oh, they install fusable links huh?
~Matt
I HAVE THE RIGHT TO OFFEND ANYONE I PLEASE. YOU HAVE THE RIGHT TO BE OFFENDED, YOU DO NOT HAVE THE RIGHT TO SHUT ME UP.
Old 03-23-2010, 10:37 PM   #14
Tool Junkie
Rewards Points: 25
Keep posting pics
Not a single electrical print to be had. The home owner is the GC. So its design build in the field.
Working on more pics, all the ones I have left have my employees in them. Can't post those on the net.
Old 03-23-2010, 10:40 PM   #15
B4T
B4T's Avatar
Dam.. your good and so far it ALL fits like a glove
FragElectric (03-24-2010)
Old 03-23-2010, 10:57 PM   #16
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 290
nice looking work (might be my eye, but looks like a slight violation of 110.26 A 3 - 6" rule ?)
Old 03-23-2010, 10:59 PM   #17
Rewards Points: 346
Very interesting. I have never seen a service that big for a residential application. In Quebec a 400 amp service is common, they primarily use electric heating. I have heard of, but have never seen, a 600 volt (30~40 amps) service supplied to large custom home to supply the electric heat / cooling loads and this kept the remainder to 120/240 volt 400 amp.
In this neck of the woods, I would suspect that we would be splitting up that with individual drops to the locations and use a central metering pole.
Any residential service that is more then 200 amps requires special permission by the utility and the inspection authority anyway according to our code.
Cheers
Old 03-23-2010, 11:37 PM   #18
danickstr's Avatar
Rewards Points: 540
I am thinking he left room for the next 3000 Sq. ft. addition or bedroom grotto pumps to the left.
e: send me the pics with the employees- I will put donny darko bunny heads on them so they cant be recognized and return them to you for posting.
danickstr is offline   Reply With Quote
Old 03-24-2010, 01:50 AM   #19
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Lookin good!
Replies based on NEC 2014
Old 03-24-2010, 01:55 AM   #20
Curious what product you used between the two back-to-back gutters?
Residential service i b e w N PHILLY KID Union Topics 6 08-04-2012 04:20 PM
residential service question BuzzKill General Electrical Discussion 14 01-08-2009 10:25 PM
residential service changes liverstos General Electrical Discussion 8 07-07-2008 07:07 PM
Residential service dilema sparkysteve Services and Service Equipment 3 07-05-2008 07:49 PM
Residential Service Question tahoewire Services and Service Equipment 8 01-13-2008 11:49 AM
