Closed Thread
Old 08-24-2009, 09:51 PM   #1
#6 copper fan
Magnettica's Avatar
Default 200 Amp Upgrade (w/ SEU)
Don't sweat it, I fixed the crooked section at the top.
The infamous "5th jaw" required by Public Service Electric & Gas.
Old Westinghouse 100 MB, not your typical residential service panel. The deceased husband I am told was an engineer.
Ughck! Water damage to the buss and grounding bars.
Square D QO 200 amp MB 40 circuit panel
Magnettica is online now
Old 08-24-2009, 09:51 PM   #2
#6 copper fan
Magnettica's Avatar
Finished product.
Old 08-24-2009, 09:54 PM   #3
Looks good, what happened to the gray painted plywood? I thought that looked pretty sharp.
Kevin J is offline
Old 08-24-2009, 09:55 PM   #4
#6 copper fan
Magnettica's Avatar
I had some leftover black paint on the truck I wanted to use up.
Old 08-24-2009, 10:04 PM   #5
Good reason.
Kevin J is offline
Old 08-24-2009, 10:22 PM   #6
Black4Truck's Avatar
Nice job with the service.. good to see you are finding work
Black4Truck is offline
Old 08-24-2009, 11:11 PM   #7
#6 copper fan
Magnettica's Avatar
I'm finding work but not getting the prices I want. What I mean is, I am making "that number" I need but working a lot more hours to get it. I chalk it up to just starting out and being hungry.
Old 08-24-2009, 11:18 PM   #8
You're not painting your backboards ahead of time?
Curious what you attached it to the foundation with?
-Marc, ABC, XYZ, PhD, 1-2-3
MDShunk is offline
Old 08-24-2009, 11:23 PM   #9
#6 copper fan
Magnettica's Avatar
I painted it yesterday it does look shiny though doesn't it? Not sure what the deal was with that. For this service, I just went right over the existing board that was there, strong like a bull.
Old 08-24-2009, 11:25 PM   #10
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
Id like to see a better picture of your temp power setup.
Good looking job BTW.
~Matt
TOOL_5150 is offline
Old 08-24-2009, 11:30 PM   #11
Methinks you used black railing paint. It's normally gloss or semi-gloss. I like to use flat or eggshell sheen.
My cut plan for a full sheet of plywood normally is (3) 24"x48" pieces, (1)24"x30" piece, and (1)24"x18" piece. I just strategically buy the cheap mis-mixed paint as I run across it. Mix a few gallons in a new 5 gallon pail and it normally ends up grey. You'll have paint for the next 5 years or so. My last batch ended up brown, so I've been putting up brown boards for a while.
MDShunk is offline
Old 08-24-2009, 11:32 PM   #12
#6 copper fan
Magnettica's Avatar
I don't have a shop yet.
Typically, I go to the Depot and buy it and paint it the day before.
When I get a shop believe me, I'm gonna have reels and reels of wire and buy stuff in bulk, especially romex when it's cheap.
Old 08-24-2009, 11:37 PM   #13
#6 copper fan
Magnettica's Avatar
~Matt
12/3 SJO cord, meter, (2) 20 amp circuit breakers (lugs are jumpered so only 120 volts to ground is available, (2) quads.
The breakers or outlets really should be GFCI protected.
Old 08-24-2009, 11:41 PM   #14
unless you are doing lots of resi new construction, it's not worth it...for service work, your price can easily flucuate to cover any cost increases...so why tie up capital?
oldman is online now
Old 08-24-2009, 11:47 PM   #15
#6 copper fan
Magnettica's Avatar
Because I worked for a company (mostly service) that did that and the owner was quite wealthy. Buy low, sell high. We did mostly service and tons and tons of A/C split systems.
Old 08-24-2009, 11:53 PM   #16
Burger Flipper
TOOL_5150's Avatar
does the meter actually spin with 120v through it? I thought they do not.
~Matt
Old 08-24-2009, 11:53 PM   #17
I've observed the largest EC in my part of the state at Lowe's from time to time loading up pallets and pallets of THHN and MC cable on their stake body. Must be a reason. My total material order will always be cheaper at the supply house than Lowe's or Home Depot. If I wanted to run two places, I could probably save a few dollars, but I just don't have it in me. At least the supply house won't give me broken THHN reels or a pallet of romex that's been speared in the middle with a forklift.
MDShunk is offline
Old 08-24-2009, 11:54 PM   #18
ok....lets say you bought 10,000 feet of 14/2 romex at $20/250 ft....or $80/1000...you tie up $800,000?
if you use the romex fast enough, the price won't go up before you use it...if you don't use it fast enough, that's a lot of money to be sitting on the shelves...
if you do new construction, on fixed price contracts....go for it...if you are doing small service jobs, why bother?
Old 08-24-2009, 11:59 PM   #19
In my case, I stock up simply so that I don't have to deal with fetching material nearly so often. Lets me concentrate on other things. I'm not buying 800 grand worth of romex, but I might get a few pallets at a go if it's a good deal. I usually don't stock more than I used last year, in total. For instance, if I'm running low on 2-1/8" deep handy boxes, I might buy 6 or 8 cases. I know I'll use them in a year. QuickBooks is pretty slick, in that I can look that sort of stuff up pretty quickly. I actually don't care that I have that money tied up, because having the inventory all situated is a stress reliever for me. You can't really put a price on that. In some situations, I'm forced to stock things. When I use a sufficient amount of a certain special order item, I feel compelled to stock it. Matter of fact, if I want to continue using it, I almost must stock it.
MDShunk is offline
Old 08-25-2009, 12:04 AM   #20
Rat Extraordinaire
I can't see being a one-man shop and sinking thousands into just wire. Have enough on hand to handle service calls, the rewires/updates/additions you know are coming. But beyond that, it's not worth spending the money. I doubt I have more than 500' of NM between my garage and van right now.
ANYTHING you buy and don't use right away costs money. Not only to buy, but to have a place to store it.
If you sign a contract to wire a new house, use the deposit to purchase the copper & steel for the job. Then if the price goes up, you're covered.
480sparky is offline
Closed Thread
200 AMP upgrade Magnettica Services and Service Equipment 88 08-08-2009 01:15 AM
Upgrade from 200 to 400 amp problems lambopower Services and Service Equipment 4 05-19-2009 08:14 AM
T - 12 upgrade Black4Truck General Electrical Discussion 16 03-05-2009 12:41 AM
200 amp upgrade Absolutetruthz Services and Service Equipment 28 07-20-2008 11:03 AM
Upgrade Help IceNine Tools, Equipment and New Products 11 01-25-2008 06:33 AM
