300 amp service dilemma - Electrician Talk - Professional Electrical Contractors Forum
Old 09-21-2010, 02:00 PM   #1
SPINA ELECTRIC's Avatar
Rewards Points: 156
Default 300 amp service dilemma
Bidding on a job I'm a little confused I never did a 300 amp service do I need a CT cabinet or can I just get a 320 amp meter pan with a 300 amp main breaker raintight enclosure I was gonna put a trough up and two 150 amp panels with main lugs or should I make them main breakers on the print I see a small elevator It is a house being converted into exam rooms can that elevator be single phase or do I have to bring 3 phases into this place Ive done a ct cabinet but it was for a 400 amp service with two 200 amp main panels a trough and a meter all indoor. What is the best way to do this I'm thinking 300 amp meter outside to a trough inside with two 150 amp square d panels with mains and call it a day. It is a basement first and second floor nothing in attic Do I need a main disconnect outside.
SPINA ELECTRIC is offline   Reply With Quote
Old 09-21-2010, 02:11 PM   #2
Rewards Points: 2,050
I would not buy or plan a thing before talking to the power company or at least get their requirements from their web site.
Where I am they will only accept certain meter sockets.
Old 09-21-2010, 02:16 PM   #3
Rewards Points: 156
Thanks Bob as long as the area provides 300 amps its available I talked to poco this morning
Old 09-21-2010, 02:16 PM   #4
Rewards Points: 5,198
I agree with Mr. Badger. Also get more information about the loads you will serve. Ask about the elevator,too.
Old 09-21-2010, 02:20 PM   #5
Rewards Points: 156
Yes I agree I am looking into the elevator if it is 3 phase that effects my price but ty
Old 09-21-2010, 02:34 PM   #6
Rewards Points: 3,855
An elevator on the prints, but not enough information to know if it's 3 phase or not? This is going to be a fun job. I can tell already.
hardworkingstiff (09-21-2010)
Old 09-21-2010, 02:39 PM   #7
I have to admit, I've led a sheltered life. The vast majority of the jobs I've been on have had drawings. I have not had to engineer a large job. It's got to be rough.
Old 09-21-2010, 02:42 PM   #8
Rewards Points: 156
It's always fun ELECTRICITY IS MY LIFE Lol If I didn't call him this morning I would not know what I know so far
Old 09-21-2010, 02:44 PM   #9
Did the POCO send a locator to tell you where the service HAS to be, and what was available?
Old 09-21-2010, 03:22 PM   #10
Rewards Points: 156
No riveter once I find out my information I will give him my bid if I get it I will have my poco take a look at it
Old 09-21-2010, 03:35 PM   #11
It is pretty important that you talk to the locator because I have had situations where the service could not go where it seemed obvious because he knew of future changes in their distribution system. I would have had to tear it out and relocate it to the other side of the building if I hadn't asked.
Old 09-21-2010, 03:48 PM   #12
Rewards Points: 12,288
If I bid a job with prints and the service is not allowed to go where it is shown on the prints, I usually get a change order.
Giving up on unbiased truth.
Old 09-21-2010, 03:54 PM   #13
Yeah. I guess if the job is pre-engineered and your bid is taken that's what you gotta do.
Old 09-21-2010, 05:52 PM   #14
Fried Bologna um um good!
jwjrw's Avatar
Here we can use a 320a can or a ct cabinet. I usually only use a ct if it's
400a. If you go back to back no main needed outside. I would get a double lug meter and feed two 150a panels.
Old 09-21-2010, 05:53 PM   #15
jwjrw's Avatar
Until poco tells you what you can use how can you bid it?
Old 09-21-2010, 11:38 PM   #16
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Not really. The things that aren't on the prints you simply don't put a price tag on. I would call the architect listed on the plans and ask him about the elevator. Then I would I call the GC and inform him that I need to know about the elevator name plate data because i am planning the service for this particular dwelling unit. Three-phase equipment is much, much more expensive than single phase. An elevator is a wide variable, that's for sure.
Replies based on NEC 2014
Old 09-22-2010, 12:44 AM   #17
Rewards Points: 534
The last time I did work on elevator on the resdentail site the motour itself is single phase it was big engouh to handle the elevator requrement.
That was 7.5 HP motor and the elevator company told me that if any bigger than that you will end up get in three phase supply or run thru the PC { phase converter } one of the two. I did told that guy some of newer units they use the VSD instead of standard PC set up.
Merci.
Marc
Old 09-22-2010, 01:08 AM   #18
Rewards Points: 2,000
I doubt the POCO is going to install a three phase transformer for one elevator. If they do, the customer better pull out thier pocket book. In my area a 300 amp service is uncommon. Goes in steps of 200 amps for the most part.
Old 09-22-2010, 05:17 AM   #19
jwjrw's Avatar
I see 320a services here often. Most residential elevators I've seen here will work without upgrading to a bigger service. Assuming you have a 200a.
Old 10-13-2010, 12:56 AM   #20
Midnitel's Avatar
Rewards Points: 162
300 amp upgrade from 200 amp
Midnitel is offline   Reply With Quote
Blue Box Dilemma BobBob General Electrical Discussion 41 08-14-2010 09:32 AM
TV listing dilemma... BuzzKill Off Topic (Non Trade) 14 11-03-2009 01:11 PM
Personal appearance dilemma MDShunk Business, Marketing, and Sales 99 09-20-2009 06:56 PM
Addition dilemma kbsparky NEC Code Forum 30 09-12-2009 06:56 PM
UK: AWA Bonding dilemma Trimix-leccy UK Electrical Forum 2 06-11-2008 05:34 PM
