600 amp service Gutter or no gutter - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By Dennis Alwon
Old 12-28-2016, 06:26 AM   #1
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,900
Default 600 amp service Gutter or no gutter
I have a service upgrade coming up, one 3 phase 400 amp disconnect with 250 amp fuses and one single phase 200/ 200. all outdoor.
The engineer is calling out a 12x12 line gutter with parallel conductors. This is the only way I have ever done it.
I will need three 4 hole and one three hole polaris taps in the gutter for the line side make up.
What would be the violation if we just put a conduit up from each of the two disconnects for the service drop?
One with 250 amp conductors and one with 200 amp conductors.
It would eliminate the gutter and a few splices.
Old 12-28-2016, 07:03 AM   #2
Rewards Points: 12,664
I think the way you are thinking about doing it is a better job myself. Did you ask the engineer if he would accept it?
Also, I've seen gutters installed like I believe you are explaining, but I don't understand how they are getting by not complying with 314.28 as referenced from 366.58(B). I guess the AHJ did not consider it a "pull box"? IDK.
Giving up on unbiased truth.
Old 12-28-2016, 08:41 AM   #3
still in business
sbrn33's Avatar
Rewards Points: 3,506
Do you need to CT it? If so just put some lugs in the cabinet.
but this is the economically depressed South and we're just a bunch of barefooted cousin humpers.
Old 12-28-2016, 08:50 AM   #4
Rewards Points: 578
If there are CT's remote from there than I don't see the problem. If you have to have ct's in a cabinet then this won't work. You would have to come out of the ct cabinet
Old 12-28-2016, 08:52 AM   #5
Rewards Points: 15,898
A HOT gutter ?
Is that your scheme ?
Old 12-28-2016, 01:17 PM   #6
ponyboy's Avatar
Rewards Points: 709
That's how I've done it in the past for retail/apartment spaces. Make it the poco's problem. They preferred that to a ground level line side tap in a tamper prone gutter.
Old 12-28-2016, 05:21 PM   #7
zap
tates1882's Avatar
Rewards Points: 822
I don't see a problem until you have 6+ disconnects. I really don't like having line taps in a gutter.
Old 12-28-2016, 06:07 PM   #8
Semper Fidelis
It will just be the utility meter, no CTs
Old 12-28-2016, 06:33 PM   #9
Rewards Points: 578
So you have 2 or 3 meters??? I have never seen a 600 amp meter base without CT's. I am still not understanding where the meter's are located
sbrn33 likes this.
Old 01-07-2017, 06:43 PM   #10
Semper Fidelis
The final design will be a 400amp/320 continuous meter
The 3 phase fused disconnect will be a 400/250
The single phase disconnect for the two apartments will a 200/200
The two parallel risers will terminate in a 12x12 x48 line gutter.
Ill scan the drawing and post it when I go back out.
Old 01-07-2017, 06:47 PM   #11
still in business
sbrn33's Avatar
This is a place for a CT cabinet and an Iline 18 space panel. Cheap and easy peasy.
Hiring Service Techs emahler General Electrical Discussion 0 11-30-2016 01:08 PM
7-unit CLUSTER-F: one service or two? mikewillnot Residential Electrical Forum 8 10-01-2016 09:11 AM
Electric Company Service Drop Upgrade MustangRider6688 Services and Service Equipment 12 07-11-2016 05:03 PM
Changing my service AK_sparky General Electrical Discussion 30 06-22-2016 09:48 PM
600 volt service metering hydro Services and Service Equipment 1 01-20-2016 01:50 PM
