Old 10-19-2009, 11:26 PM   #41
captkirk's Avatar
Originally Posted by BCSparkyGirl View Post
thats cool, enjoy the gramma time man, you will appreciate it when she hits, oh, 2........I was the same way with daycare, but I find the 2 days that I do have her in daycare is good for her, as she gets the social interaction with other kids, at least until I can give her a sibling........she learns to share, and hopefully we avoid the "MINE" phase. Yes, a year paid is fantastic.......
Oh yea totally agree for when she gets a little older.Plus who wouldnt want a little "ME" time. I know how single childeren can be.Its very important they interact with other people. We're gonna try for another one soon.
Old 11-03-2009, 08:08 AM   #42
Default RE: Another Service!
Which type of another services wants. In this forum you get all type of Electrician and Electricity related thread. So, keep your suggestion and get solved.
Thanks
Adil Mania is offline   Reply With Quote
Old 11-03-2009, 09:45 AM   #43
Magnettica, i'm curious. Do both tenants have access to the panels? In VA, if the panels were located in the downstairs apartments, you would have to give the downstairs tenant 24 hours notice to enter. This, odviously wouldn't fly here. Thus, not being readily accessible to both tenants. How is the neighborhood zoned? mutifamily?
Old 11-05-2009, 10:25 AM   #44
Thanks
Old 11-05-2009, 01:51 PM   #45
#6 copper fan
Magnettica's Avatar
This was a basement, a common area with a laundry room. It passed inspection 2 weeks ago.
classicelectriconline.com
Old 11-05-2009, 05:04 PM   #46
Originally Posted by Magnettica View Post
Why does the riser amperage need to be larger than the conductors feeding the panel?
A 100 amp riser could feed a total of (6) 100 amp MB panels if you wanted to.
Is it a good design? No...
as long as TOTAL load doesn't exceed 100amp,
prldrp1 is offline   Reply With Quote
Old 11-05-2009, 07:17 PM   #47
steelersman's Avatar
total of what?
steelersman is online now   Reply With Quote
Old 11-05-2009, 07:25 PM   #48
#6 copper fan
Magnettica's Avatar
Originally Posted by steelersman View Post
total of what?
Total load of the branch circuits in the 100 amp MB panel.
Old 11-05-2009, 09:33 PM   #49
cdnelectrician's Avatar
Everything looks great, no offence, but I don't like the idea of threading a PVC TA into an aluminum meter hub. It's against code here...we have to use a PVC meter hub OR a PVC FA with a steel close nipple. I've seen some services where the PVC has expanded/contracted and broken the TA off the meter base.
Old 11-05-2009, 09:35 PM   #50
Hack and Rat all in one
Peter D's Avatar
It's never been a problem here. I wonder what the reasoning is behind that code rule?
Old 11-06-2009, 12:21 AM   #51
Probably because it gets so damn cold here...but the rule makes total sense to me. I have seen a lot of TA's snapped off when threaded into metal enclosures. It also has to do with the fact that metal conduit threads are tapered whereas PVC threads are not.
Old 11-06-2009, 01:59 AM   #52
Don't worry, it never gets to -55 here...
Old 11-06-2009, 02:07 AM   #53
Ugh I DREAD the winter, but here it comes...again...
Old 11-06-2009, 05:35 PM   #54
sparks134's Avatar
I never actually knew that. I've never dealt with a meterstack like that. Oh well I just learned something today. I guess this has to do with the "no more than 6 throws or switches rule" eh?
i whould have ran 3/0 for the riser! then #3 for each 100A unit, but thats just me!
sparks134 is offline   Reply With Quote
Old 11-10-2009, 10:33 PM   #55
#6 copper fan
Magnettica's Avatar
That's fine, but isn't necessary (T310.15(B)(6)). No electric heat, no central air, this house will likely never even reach anywhere near 200 amps.
Old 11-10-2009, 10:47 PM   #56
sparks134's Avatar
NEC says you need 2/0 cu!!!
